702,019
Land Pride Rotary Cutters RC3615 RCM3615 Series 2 Operation Manual 330-502M
Brand: Land Pride
Model: Land Pride RC3615, RCM3615 Series 2 Rotary Cutters
Serial Number: 945023+
Part Number: 330-502M
Publication Date: 2023
Number of Pages: 68 Pages
Important Safety Information
Safety at All Times
Look for the Safety Alert Symbol
Safety Labels
Introduction
Application
Using This Manual
Owner Assistance
Section 1: Assembly & Set-up
Tractor Requirements
Torque Requirements
Before You Start
Hitch Types
Hitch Assembly
Park Jack Assembly
Spring Hose Loop Assembly
Tractor Shutdown Procedure
Standard Clevis Hitch Hook-up
LP Performance Hitch Hook-up
Bar-Tite Hitch Hook-up
Hydraulic Hook-up
Wing Axle Turnbuckle Set-up
Unfold Wings
Driveline Assembly
Driveline Hook-up
Driveline Hanger Adjustment
Driveline Clearance Check
Purge Hydraulic System
Hook-up LED Lights
Remove Shipping Lugs
Unhook Rotary Cutters
Section 2: Adjustments
Park Jack Angle Alignment
Level Cutter Decks
Adjust Deck Cutting Height
LP Performance Hitch Pin Diameter
Section 3: Operating Instructions
Startup Checklist
Safety Information
Tractor & Cutter Inspection
Blade Operation Inspection
Transport Locks
Transporting
Road Side Cutting
Field Set-up
Section 4: Options & Accessories
Safety Guards
Tire & Axle Arrangements
Hitches
Mechanical Wing Lift
Hydraulic Accessories
Section 5: Maintenance & Lubrication
General Maintenance
Tires
Spring Shock Absorbers
Skid Shoes
Spindle Gearbox Shaft Guard
Cutter Blades
Drivelines With Slip Clutches
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque & Tire Inflation Chart
Section 10: Warranty
