702,169
Land Pride Rotary Cutters RC3615 RCM3615 Operator Manual 330-502M-FRC FR
Language: French
Brand: Land Pride
Model: Land Pride RC3615 RCM3615 Rotary Cutters
Serial Number: 945023+
Part Number: 330-502M-FRC
Publication Date: 2018
Number of Pages: 64 Pages
Important Safety Information
Look for the Safety Alert Symbol
Safety at All Times
Safety Labels
Introduction
Application
Using This Manual
Owner Assistance
Serial Number
Section 1: Mounting and Setup
Tractor Requirements
Horsepower
Drawbar Configuration
Hydraulic Outlets
Before You Begin
Torque Requirements
Hitch Types
Standard Clevis Hitch
Land Pride Performance Hitch (Optional)
Bar-Tite Bar Hitch (Optional)
Ball Hitch (Optional)
Pin Hitch (Optional)
Hitch Mounting
Parking Stand Mounting
Spring Hose Loop Mounting
Tractor Shutdown Procedure
Standard Clevis Hitch Connection
Hitch Connection LP Performance
Bar-Tite Hitch Connection
Hydraulic Hitch
Side Axle Idler Setup
Folding the Fenders
Driveshaft Installation
Driveshaft Connection
Driveshaft Bracket Adjustment
Driveshaft Freeplay Check
Hydraulic System Bleeding
Side Articulating Cylinder
Deck Lift Cylinder
LED Light Connection
Shipping Pin Removal
Rotary Trimmer Disconnect
Section 2: Adjustments
Parking Stand Angle Alignment
Leveling the Cutting Units
Leveling the Center Cutting Unit
Leveling the Side Cutting Units
Adjusting the Cutting Unit Height
Hitch Pin Diameter LP Performance
Section 3: Operating Instructions
Starting Checklist
Information Safety Instructions
Tractor and Brushcutter Inspection
Avoid Extreme Turn Angles
Blade Operation Inspection
Transport Locks
Travel
Roadside Cutting
Field Setup
Field Inspection
Unfolding the Wings and Adjusting the Cutting Height
Float Wing Lift
Setting the Wing Lift Device
in the Float Position
Speed Range Selection
Blade Engagement
Blade Disengagement
Section 4: Options and Accessories
Safety Shields
Tire and Axle Arrangements
Hitches
Mechanical Wing Lift
Wing Lift Device Installation Instructions
Hydraulic Attachments
Hydraulic Wing Control Kit
Selector Control Valve Kit
Section 5: Maintenance and Lubrication
General Maintenance
System Hydraulic
Tires
Spring Shock Absorbers
Skids
Side Skids
Center Skids
Axle Gearbox Shaft Guard
Brushcutter Blades
Friction Clutch Driveshafts
Type A Clutches
Type B Clutches
Long-Term Storage
Ordering Spare Parts
Lubrication Points
Section 6: Specifications and Capacities
Section 7: Features and Benefits
Section 8: Troubleshooting
Section 9: Torque and Tire Inflation Pressure Chart
Section 10: Warranty
