Land Pride Rotary Cutters RC3614 RCM3614 Operation Manual 330-918M
Brand: Land Pride
Model: Land Pride RC3614, RCM3614 Rotary Cutters
Part Number: 330-918M
Publication Date: 2023
Number of Pages: 68 Pages
Important Safety Information
Safety at All Times
Look for the Safety Alert Symbol
Safety Labels
Introduction
Application
Using This Manual
Owner Assistance
Section 1: Assembly & Set-up
Tractor Requirements
Torque Requirements
Before You Start
Hitch Types
Hitch Assembly
Park Jack Assembly
Driveline Assembly
Tractor Shutdown Procedure
Standard Clevis Hitch Hook-Up
LP Performance Hitch Hook-up
Bar-Tite Hitch Hook-up
Driveline Hook-up
Driveline Hanger Adjustment
Driveline Clearance Check
Hydraulic Hook-up
Rephasing Lift Cylinders & Plumbing
Wing Folding Cylinder & Plumbing
Remove Shipping Crossbar
Unfold Wing Deck
Relocate Wing Lift Cylinder Mount
Purge Hydraulic System
Hook-up LED Lights
Unhook Rotary Cutters
Section 2: Adjustments
Park Jack Angle Alignment
LP Performance Hitch Pin Diameter
Level Cutter Decks
Adjust Deck Cutting Height
Section 3: Operating Instructions
Startup Checklist
Safety Information
Avoid Extreme Turning Angles
Tractor & Cutter Inspection
Blade Operation Inspection
Transport Lock
Transporting
Road Side Cutting
Field Set-up
Section 4: Options & Accessories
Safety Guards
Tire & Axle Arrangements
Hitches
Selector Control Valve Kit
Section 5: Maintenance & Lubrication
General Maintenance Information
Tires
Skid Shoes
Cutter Blades
Drivelines With Slip Clutches
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque & Tire Inflation Charts
Section 10: Warranty
