Land Pride Parallel Arm Rotary Cutters RCPM2660 RCP2660 RCPM3060 RCP3060 Parts Manual 316-111P
Brand: Land Pride
Type of Machine: Parallel Arm Rotary Cutters
Model: Land Pride RCPM2660, RCP2660, RCPM3060, RCP3060 Parallel Arm Rotary Cutters
Part Number: 316-111P
Publication Date: 2023
Number of Pages: 170 Pages
Section 1: Introduction
Using This Manual
Manual Replacement Information
Manual Revisions
Touch-up Paint
Hardware Legend
Replacement Hardware
Serial Numbers
Part Number Service Coding
Section 2: Frame
Main Frame S/N 635575-
Main Frame S/N 635576+
Parallel Arm S/N 615123-
Parallel Arm S/N 615124+
RCP Lights
SMV Sign
Section 3: Deck
Blade Drive
Chain Guard Front
Chain Guard Rea
Deck Link
Spindle Hub Assembly (826-110C)
Section 4: Hydraulics
Hydraulic Breakaway Cylinder
Hydraulic Breakaway Cylinder Seal Kit (500- 090B)
Hydraulic Cylinder (810-198C) Midway
Hydraulic Cylinder (810-200C) Midway
Hydraulic Cylinder (810-200C) Red Lion
Hydraulic Cylinder (810-522C) Midway
Hydraulic Cylinder (810-535C) Midway
Hydraulic Cylinder (810-535C) Red Lion
Hydraulic Cylinder (810-546C) Midway
Hydraulic Cylinder (810-546C) Red Lion
Hydraulic Cylinder (810-576C) Cross 2500 PSI
Hydraulic Cylinder (810-576C) Cross 3000 PSI
Hydraulic Cylinder (810-577C) Cross 2500 PSI
Hydraulic Cylinder (810-577C) Cross 3000 PSI
Hydraulic Cylinder (841-341C) Red Lion
Hydraulic Cylinder Arm
Hydraulic Cylinder Arm With Solenoid Valve
15 GPM & Less
16 GPM & Greater
Hydraulic Cylinder Breakaway Shear Bolt
Update (S/N 455189-)
Hydraulic Frame S/N 635575-
Hydraulic Gear Increaser 1000 RPM (826- 138C) Bondioli
Hydraulic Gear Increaser 1000 RPM (826- 138C) Comer
Hydraulic Gear Increaser 540 RPM (826- 108C) Bondioli
Hydraulic Gear Increaser 540 RPM (826- 108C) Comer
Hydraulic Motor (810-314C) Ultra
Hydraulic Pump (810-208C) Ultra
Hydraulic Pump Stacked (810-656C) S/N 635576 to 826735-
Hydraulic Pump Stacked (810-925C) S/N 826736+
Section 5: Drivelines
Driveline (826-140C) Eurocardan
Driveline (826-373C) Comer
Driveline (826-373C) Eurocardan
Driveline (826-877C) Comer
Driveline 1000 RPM (826-139C) 1 3/8-21
Spline Eurocardan
Spline Eurocardan (S/N 434703+)
Driveline 1000 RPM (826-168C) 1 3/4-20
Spline Eurocardan
Driveline 540 RPM (826-107C) Eurocardan
Section 6: Decals
Decal Placement
Land Pride Touch-up Paints
Section 7: Options & Accessories
Control Box (823-100C) (S/N 533941-)
Control Box (823-100C) (S/N 533942 to 563392)
Control Box (823-233C) Float Deck W/
Gauge Wheels S/N 563692-
Control Stick (823-325C) W/O Float W/ Deck Motor Shut-off
Control Stick (823-326C) W/ Float W/ Deck Motor Shut-off
Control Stick (823-459C) W/O Float W/ Deck Motor Shut-off
Control Stick (823-460C) W/ Float W/ Deck Motor Shut-off
Control Stick W/ Float (823-285C) S/N 563693+
Control Stick W/O Float (823-284C) S/N 563693+
Control Stick W/O Float (823-284C) S/N 584481+
Float Conversion Kit (316-366A) Independent Hydraulic
Gauge Wheel Option
Hydraulic Solenoid Valve W/O Gauge Wheel
Hydraulic Solenoid Valve Float Deck W/
Gauge Wheels
Hydraulic Solenoid Valve Seal Kits For
Cartridges
Operator Protective Shield
SMV Sign
Stabilizer Kit
Tire 13X5 Semi-Solid (814-272C)
Weight Hangers
Section 8: Independent to Tractor Hyd
Control Option S/N 635576+
Deck Motor Plumbing (Independent System)
Deck Motor Plumbing (Tractor/Solenoid Control)
Hydraulic Cylinder Plumbing (Independent Control)
Hydraulic Cylinder Plumbing (Solenoid Control 15 GPM & Under)
Hydraulic Cylinder Plumbing (Solenoid Control 16 GPM & Above)
Hydraulic Cylinder Plumbing (Tractor Control)
Brand: Land Pride
Using This Manual
Manual Revisions
Touch-up Paint
Hardware Legend
Serial Numbers
Section 2: Frame
RCP Lights
SMV Sign
Section 3: Deck
Blade Drive
Chain Guard Front
Chain Guard Rea
Deck Link
15 GPM & Less
16 GPM & Greater
Spline Eurocardan
Spline Eurocardan
Section 6: Decals
Decal Placement
Gauge Wheel Option
Gauge Wheels
Cartridges
SMV Sign
Stabilizer Kit
Weight Hangers
- Land Pride Grapple Buckets GB25 GBE25 GBE30 Series Operation Manual 380-192M
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operation Manual 329-301M
- Land Pride Rotary Cutters RCF3696 RCFM3696 RCF3610 RCFM3610 Operator Manual 326-600M-FRC FR
- Land Pride Grapple Buckets GB25 GBE25 GBE30 Series Parts Manual 380-192P
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operator Manual 329-301M-FRC FR
- Land Pride Rotary Cutters RCFM3696 RCF3696 Parts Manual 326-600P
- Land Pride Grapple Buckets SRB1566 to SSB1578 Operation Manual 380-101M
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Parts Manual 329-301P
- Land Pride Rotary Cutters RCFM4014 Operator Manual 326-730M
- Land Pride Grapples SGC1060 SGC1072 Operation Manual 380-092M
- Land Pride Multi-Purpose Seeder NTS2607 NTS2609 NTS2611 Operator Manual 329-141M-FRC FR
- Land Pride Rotary Cutters RCFM4014 Operator Manual 326-730M-FRC FR
- Land Pride Grapples SGC1060 SGC1072 Operator Manual 380-092M-FRC FR
- Land Pride No Till Seeder NTS2507 NTS2509 NTS2511 Operation Manual 313-629M 2018
- Land Pride Rotary Cutters RCFM4014 Parts Manual 326-730P
