705,578
Land Pride Offset Flail Mower OFM2660 OFM2672 OFM2678 Operation Manual 333-142M
Brand: Land Pride
Type of Machine: Offset Flail Mower
Model: Land Pride OFM2660 OFM2672 OFM2678 Offset Flail Mower
Part Number: 333-142M
Publication Date: 2021
Number of Pages: 68 Pages
Important Safety Information
Safety at All Times
Look for the Safety Alert Symbol
Safety Labels
Introduction
Application
Using This Manual
Owner Assistance
Section 1: Assembly & Set-up
Tractor Requirements
Weight Requirements
Torque Requirements
Before You Start
Tractor Shutdown Procedure
Offset Flail Mower Features
Flail Mower Accessories
Counter-blade (Accessory)
Blade Type & Usage (Standard)
Handling & Unloading Instructions
Packing & Unpacking
Attach Flail head to the Hitch
Hose Assembly
Preliminary Checks & Inspections
Lifting & Transporting the Mower
Handling & Storage
Permitted Hoist Lifting Points
Driveline Installation
3-Point Hook-up
Driveline Hook-up
Hydraulic Hook-up
Check Driveline Interference
Check Driveline Collapsible Length
Measure Driveline Maximum Length
Tractor & Tire Load Capacities
Tractor Data
Tire Data
Assessment of Load Capacities
Effective Gross Weight
Front Axle Load
Rear Axle Load
Section 2: Adjustments
Settings
Set Working Height
Adjust Roller Height
Adjust Park Stands
Adjust Lateral Position
Accumulator Safety Function
Adjust Flail Head Incline Angle
Section 3: General Operating Instructions
Operator’s Responsibilities
Safety Information
Transporting
Maximum Driveline Operating Angle
Slow Moving Vehicle Sign
Danger Zones
Offset Flail Mower Safety Devices
Working at Night
Improper Use of the Flail Mower
Pulley Configuration
Lateral Adjustment
Avoid Driveline Contact With Mower
Correct Operating Procedure
Mowing Positions
Overturning Hazard
Working on Incline Surfaces
Entering a Decline Surface
Exiting a Decline Surface
Starting Work
Ground Speed
Vibration and Noise
Clogging
Ending Work
Unhook Offset Flail Mower
Section 4: Maintenance & Lubrication
General Maintenance Information
Special Maintenance Safety
General Maintenance Safety
Adjustment Safety
Hydraulic Systems Care
Check Belt Tension
Belt Manufacture Instrument
Belt Frequency Meter
Set Belt Tension
Replace Belts
Check & Replace Blades
Check Blades
Replace Blades
Skid Shoe Replacement
Remove Accumulated Trash
Cleaning the Flail Mower
Safe Handling of Oils & Lubricants
Lubrication Schedule and Points
Front, Lateral Pivot Pins
Back, Lateral Pivot Pins
Incline Cylinder Clevis Pin
Lateral Cylinder Clevis Pins
Flail Head Incline Pivot Pin
Rotor Right Side Bearing
Rotor Left Side Bearing
Roller Right Side Bearing
Roller Left Side Bearing
Driveline Universal Joints
Driveline Profiles
Gearbox Lubrication
Access Oil Level Plug
Check Oil Level
Add Oil
Replace Gearbox Oil
Storing the Mower
Bringing the Machine Out of Storage
Section 5: Specifications & Capacities
Section 6: Features & Benefits
Section 6: Troubleshooting
Section 7: Torque Values Chart
Section 8: Warranty
