Land Pride No Till Seeder NTS2607 NTS2609 NTS2611 Operation Manual 329-141M
- Download this document, you need 300 Gallons
Brand: Land Pride
Type of Machine: No Till Seeder
Model: Land Pride NTS2607 NTS2609 NTS2611 No Till Seeder
Part Number: 329-141M
Publication Date: 2023
Number of Pages: 78 Pages
Introduction
Application
Patented Lockout Clutch
Using This Manual
Owner Assistance
Section 1: Assembly & Set-up
Tractor Requirements
Quick Hitch Compatibility
Torque Requirements
Dealer Preparations
Sling Bracket
Flex Guard Hose
Small Seeds Zero Adjustment Set-up
Tow Hitch Option
Acremeter Option
Hydraulic Plumbing For Tow Option
Purge Hydraulic System
Section 2: Operating Instructions
Operating Checklist
General Safety
Tractor Shutdown Procedure
Hook-up 3-Point Seeder
Check LED Lights
Check Tractor Clearance
Unhook 3-Point Seeder
Hook-up Pull-Type Seeder
Store Park Jack
Unhook Pull-Type Seeder
Install Transport Locks and Spacers
Transporting
Level Seeder With 3-Point Mount
Level Seeder With Pull Hitch
Fill Small Seeds Seedbox
Filling Grass Seedbox
Filling Native Seedbox
How the Seeder Works
Grass Seeds Transmission
All-Seeds Drive Lock In/Out Clutch
Native Seeds Lock In/out Sprocket
Small Seeds Lock In/out Sprocket
Lock In/Out Pin Operation
Operating the Seeder
Section 3: Roller Adjustments
Front Spike Roller Angle
Mud Scrapers
Section 4: Grass Seed Rate Adjustment
Grass Seedbox Drive Speed Ranges
Grass Seedbox Cup Gate Setting
Grass Seed Rate Adjustments
Calibrate Grass Seed Dispersal
Seed Rate Crank Instructions
Pull-Type Seeder
Three Point Mount Seeder
Install Seed Rate Crank
Store Seed Rate Crank
Grass Seed Rate Chart (English)
Grass Seed Rate Chart (Metric)
Section 5: Small Seed Rate Adjustment
Small Seeds Seed Rate Adjustments
Calibrate Small Seeds Dispersal
Small Seed Rate Chart (English)
Small Seed Rate Chart (Metric)
Section 6: Native Seed Rate Adjustment
Native Seed Rate Adjustments
Calibrate Native Seed Dispersal
Native Seed Rate Chart
Section 7: Options & Accessories
Agitation Extension Kit (Accessory)
Electronic Acremeter (Option)
Slow Moving Vehicle Sign (Accessory)
Section 8: Maintenance & Lubrication
Maintenance
Roller Chains and Sprockets
General Maintenance
All Seeds Drive Chains #3, #6, & #9
Grass Seeds Drive Chain #12
Transmission Drive Chain #15
Small Seeds Drive Chain #18
Native Seedbox
Native Grass Seed Main Drive Chain #1
Native Grass Seed Gearbox Drive Chain #5
Native Grass Seed Cup Drive Chain #10
Native Grass Seed Agitator Drive Chain #14
Roller Chain Part Numbers
All, Grass, and Small Seeds Drive Chains
Native Seeds Drive Chains
Front Spike Rollers
Rear Packer Roller
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Front Roller Bearings
Rear Roller Left End Bearing
Rear Roller Right End Bearing
Rear Roller Center Bearings
Small Seed Drive Sprocket Bearing
Native Seed Drive Sprocket Bearings
Seed Cup Drive Shafts
All Seeds Drive Sprocket
Roller Chains
Seed Cup Sprockets and Nylon Washers
Gearbox for the Native Seedbox
Axle Hub Bearing
Section 9: Specifications & Capacities
Section 10: Features & Benefits
Section 11: Troubleshooting
Section 12: Torque Values & Tire Inflation
Section 13: Warranty
Brand: Land Pride
Introduction
Application
Using This Manual
Owner Assistance
Torque Requirements
Dealer Preparations
Sling Bracket
Flex Guard Hose
Tow Hitch Option
Acremeter Option
Operating Checklist
General Safety
Check LED Lights
Store Park Jack
Transporting
Mud Scrapers
Pull-Type Seeder
Maintenance
General Maintenance
Native Seedbox
Front Spike Rollers
Rear Packer Roller
Long-Term Storage
Lubrication Points
Roller Chains
Axle Hub Bearing
- Land Pride Grapple Buckets GB25 GBE25 GBE30 Series Operation Manual 380-192M
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operation Manual 329-301M
- Land Pride Rotary Cutters RCF3696 RCFM3696 RCF3610 RCFM3610 Operator Manual 326-600M-FRC FR
- Land Pride Grapple Buckets GB25 GBE25 GBE30 Series Parts Manual 380-192P
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operator Manual 329-301M-FRC FR
- Land Pride Rotary Cutters RCFM3696 RCF3696 Parts Manual 326-600P
- Land Pride Grapple Buckets SRB1566 to SSB1578 Operation Manual 380-101M
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Parts Manual 329-301P
- Land Pride Rotary Cutters RCFM4014 Operator Manual 326-730M
- Land Pride Grapples SGC1060 SGC1072 Operation Manual 380-092M
- Land Pride Multi-Purpose Seeder NTS2607 NTS2609 NTS2611 Operator Manual 329-141M-FRC FR
- Land Pride Rotary Cutters RCFM4014 Operator Manual 326-730M-FRC FR
- Land Pride Grapples SGC1060 SGC1072 Operator Manual 380-092M-FRC FR
- Land Pride No Till Seeder NTS2507 NTS2509 NTS2511 Operation Manual 313-629M 2018
- Land Pride Rotary Cutters RCFM4014 Parts Manual 326-730P
