Land Pride No Till Seeder NTS2507 NTS2509 NTS2511 Operation Manual 313-629M 2020
- Download this document, you need 300 Gallons
Brand: Land Pride
Type of Machine: No Till Seeder
Model: Land Pride NTS2507, NTS2509, NTS2511 No Till Seeder
Serial Number: 1304387+
Part Number: 313-629M
Publication Date: 2020
Number of Pages: 76 Pages
Section 1: Assembly & Set-up
Tractor Requirements
Quick Hitch Compatibility
Torque Requirements
Dealer Preparations
Sling Bracket
Flex Guard Hose
Small Seeds Zero Adjustment Set-up
Tow Hitch Option
Acremeter Option
Hydraulic Plumbing For Tow Option
Purge Hydraulic System
Section 2: Operating Instructions
Operating Checklist
Tractor Shutdown Procedure
Hook-up 3-Point Seeder
Check LED Lights
Check Tractor Clearance
Unhook 3-Point Seeder
Hook-up Pull-Type Seeder
Store Park Jack on Seeder Frame
Unhook Pull-Type Seeder
Install Transport Locks & Spacers
Transporting with Seeder Attached
Level Seeder With 3-Point Mount
Level Seeder With Pull Hitch
Filling Small Seeds Seedbox
Filling Grass Seedbox
Filling Native Seedbox
How the Seeder Works
Lockout Clutch
Drive Sprocket Engagement
Operating the Seeder
Section 3: Roller Adjustments
Front Spike Roller Angle
Mud Scrapers
Section 4: Grass Seed Rate Adjustment
Grass Seed High/Low Range Set-up
Low Range Reduction Set-up
Return to Standard High/Low Range
Grass Seed Cup Gate Setting
Grass Seed Rate Chart (English)
Grass Seed Rate Chart (Metric)
Section 5: Small Seed Rate Adjustment
Small Seed High/Low Range Set-up
Small Seeds Seed Rate Adjustment
Small Seed Rate Chart (English)
Small Seed Rate Chart (Metric)
Section 6: Native Seed Rate Adjustment
Native Seed High/Low Range Set-up
Native Seed Rate Chart
Section 7: Options & Accessories
Agitation Extension Kit (Accessory)
Electronic Acremeter (Option)
Slow Moving Vehicle Sign (Accessory)
Section 8: Maintenance & Lubrication
Maintenance
Roller Chains & Sprockets
Roller Chain Part Numbers
Small Seed Roller Chains & Grass Seed Standard Roller Chains
Front Spike Rollers
Rear Packer Roller
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 9: Specifications & Capacities
Section 10: Features & Benefits
Section 11: Troubleshooting
Section 12: Torque Values & Tire Inflation
Section 13: Warranty
Brand: Land Pride
Torque Requirements
Dealer Preparations
Sling Bracket
Flex Guard Hose
Tow Hitch Option
Acremeter Option
Operating Checklist
Check LED Lights
Lockout Clutch
Mud Scrapers
Maintenance
Front Spike Rollers
Rear Packer Roller
Long-Term Storage
Lubrication Points
- Land Pride Grapple Buckets GB25 GBE25 GBE30 Series Operation Manual 380-192M
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operation Manual 329-301M
- Land Pride Rotary Cutters RCF3696 RCFM3696 RCF3610 RCFM3610 Operator Manual 326-600M-FRC FR
- Land Pride Grapple Buckets GB25 GBE25 GBE30 Series Parts Manual 380-192P
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operator Manual 329-301M-FRC FR
- Land Pride Rotary Cutters RCFM3696 RCF3696 Parts Manual 326-600P
- Land Pride Grapple Buckets SRB1566 to SSB1578 Operation Manual 380-101M
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Parts Manual 329-301P
- Land Pride Rotary Cutters RCFM4014 Operator Manual 326-730M
- Land Pride Grapples SGC1060 SGC1072 Operation Manual 380-092M
- Land Pride Multi-Purpose Seeder NTS2607 NTS2609 NTS2611 Operator Manual 329-141M-FRC FR
- Land Pride Rotary Cutters RCFM4014 Operator Manual 326-730M-FRC FR
- Land Pride Grapples SGC1060 SGC1072 Operator Manual 380-092M-FRC FR
- Land Pride No Till Seeder NTS2507 NTS2509 NTS2511 Operation Manual 313-629M 2018
- Land Pride Rotary Cutters RCFM4014 Parts Manual 326-730P
