702,019
Land Pride Compact Drills 3P806NT Operator Manual 313-520M-FRC FR
Language: French
Brand: Land Pride
Type of Machine: Compact Drills
Model: Land Pride 3P806NT Compact Drills
Part Number: 313-520M-FRC
Publication Date: 2018
Number of Pages: 88 Pages
Section 1: Important Safety Information
Safety Labels
Section 2: Introduction
Device Description
Intended Use
Models Covered
Using This Manual
Owner Assistance
Section 3: Preparation And Setup
Pre-Delivery Setup
Pre-Planting Setup
Pre-Assembly Checklist
Hitching Tractor To Planter
Hydraulic Hose Hitch
Electrical Connections
Leveling The Planter
Stroke Control Spacers
Check Level
Section 4: Operating Instructions
Operational Checklist
Raising/Lowering The Planter
Lowering
Locks Caster Swivel
Movement
Semi-Mounted Three-Point Hitch Movement
Movement With Trailer
Loading Materials
Filling The Main Seed Hopper
Filling The Native Grass Box
Filling The Small Seed Box
Filling The Dual Seed Box
Loading Fertilizer
Material Rates Overview
Planting Depth Overview
Area Meter Operation
Normal Operation Sequence
Screen Saver
Field Operation
Parking
Storage
Section 5: Settings
Seed And Fertilizer Rates
Planting Depth
Coulter Settings
Table Of Contents
Coulter Depth (All Rows)
Coulter Down Pressure
Coulter Spring Length
Coulter Depth (Individual Rows)
Setting The Seeder Weight
Row Unit Settings
Cutter Disc Settings
Shaker Settings
Shaker Down Pressure
Disc Scrapers Adjustment
Small Seed Tube Adjustment (Optional)
Shaker Depth (Press Wheel Height)
Section 6: Troubleshooting
Section 7: Maintenance And Lubrication
Castor Brake Adjustment
Pressure Plate Adjustment
Material Cleaning
Main And Dual Hopper Cleaning
Native Grass Hopper Cleaning
Fertilizer Hopper Cleaning
Small Seed Hopper Cleaning
Disc Maintenance
Shaft Disc Replacement
Coulter Disc Replacement
Chain Maintenance
Seed Flap Replacement
Eyebolt Adjustment
Hydraulic System Bleeding
Lubrication And Periodic Maintenance
Section 8: Options
Section 9: Appendix A – Reference Information
Specifications And Capacities
Tire Pressure Chart
Torque Chart
Hydraulic System Diagram
Chain Routing
Section 10: Appendix B – Before Delivery
Connecting The Meter Hoses
At The Rows
Section 11: Appendix C – Accessory Installation
Carbide Disc Scrapers Installation
Hitch Extension Installation
Weight Support Installation
Section 12: Warranty
