Jungheinrich JETI Judit v4.36.004 11.2021 DVD
Jungheinrich JETI Judit v4.36_004 11.2021 DVD
1. It is only DVD ISO new update
2. Can see more here if you need:
Judit 4.36 2021 KG Jungheinrich Judit 4.36 KG
If need install full program: Contact us
Admin@autorepairmanuals.ws
Gallons@autorepairmanuals.ws
Autorepairmanuals.ws@gmail.com
004.036.00004
16.11.2021
Changes
Judit-4.36.00.87_EasyAccess_2015_4560.exe
Updated translation to other languages.
Judit-4.36.00.90_EasyPilot_2016_4430.exe
- Parameter 0x2A08 "Cross aisle detection" now has another setting value: "2" = Cross aisle detection active, platform switch monitoring
- Parameter 0x2A1E "Reduction of shelf depth" added.
- Parameter 0x2A1F "Scan angle correction of the navigation scanner.
- Software update component K1 to V1.08.00
Judit-4.36.00.91_EJE_2xx_2018_4050.exe
Parameter P2466 "Temperature sensor drive motor" wrongly had the tooltip of the display. This has now been corrected.
Judit-4.36.00.86_EFG_2xx_3xx_2015_FG.exe
The parameter "Speed after the service interval has expired" was not displayed on some computers.
Judit-4.36.00.94_EZS_130_350_C40_2011_4220.exe
New vehicle type and new parameter "CurveControl speed"
Judit-4.36.00.95_EZS_130_2019_4050.exe
New vehicle type and new parameters for assistance systems
Judit-4.36.00.96_SfFMS_2018_4020.exe
Limitation of bus communication for all vehicles so that system devices can communicate better
Judit-4.36.00.97_EJE_112i_2014_4500.exe
"Temperature sensor" parameter corrected, battery lock color changed
Judit-4.36.00.98_ECE_2xx_2015_4560.exe
Judit-4.36.00.99_ECE_3xx_2015_4500.exe
JetPilot baud rate is no longer saved or loaded in the backup
Judit-SDT_4.325_EJE_2xx_2018.exe
Div. Change points:
SWSBLA-21: Intercepting timer overflow in SF-H1
SWSBLA-22: Shorten the response time of the overvoltage interrupt
SWSBLA-25: Correction of the ramp lift function
SWSBLA-26: Increase the threshold for monitoring the pump to 30 A.
SWSBLA-27: Modify control of the pump output stage
Bugfix for 8-bit signed values in the CANopen stack
"Use fast sort algorithm" flag removed from CANopen stack
Ignore Emergency 805.1 from the group display
Corrected the heartbeat times in the first environment variable for event 805.
Judit-4.36.00.100_EJC_2xx_Bxx_2011_4260.exe
Fixed problems with steering controls
Judit-4.36.00.101_EKM_2018_4050.exe
Button added at the top left of the main page to prepare the two Curtis control units for flashing
Judit-4.36.00.102_EFG_FL_4060.exe
Update of the texts in other languages
Judit-4.36.00.103_ERxi_2019_4090.exe
Judit-4.36.00.105_Telematicbox_2018_4250.exe
Transponder reader Plus is supported, time zones can be set, UART log can be used for error localization, parameter "Setting recovery mode for VDI-4458 on CAN1" added
Judit-4.36.00.106_EKS_110_2015_4540.exe
Fixed bug with display and jet pilot parameters
Judit-4.36.00.108_ERDi_2021_4000.exe
First release based on the ERxi_2019 project for the ERD 220i
Judit-4.36.00.109_EKS_2019_4220.exe
Added the "External shutdown option" parameter and calculates the steering ratio
Judit-4.36.00.110_ERC_2xx_2019_4120.exe
New parameters "Minimum CurveControl speed" and "Pulse duration prop valve",
Documentation updated for P449, P461 and P1377, P2338 Selection of the values was restricted according to EN1175, P393 now has the value 5
Judit-4.36.00.111_ETVQ_2017_4060.exe
Storage path for the parameters changed
Judit-4.36.00.112_ EJC_2xx_2xxz_Bxx_2013_4180.exe
Reading out the error memory was accelerated by an internal modification of the pollen
Judit-4.36.00.113_EFG_2xx_3xx_2015_FG_4250.exe
TecUpgrade support and 3 new parameters (assistance systems)
Judit-4.36.00.114_ESE_4xx_2009_4180.exe
New parameter steering mode 180 ° / 360 °
Judit-4.36.00.115_ESE_533_2010_4220.exe
New parameter "Driving while standing"
Judit-4.36.00.116_LiIonen24V_2015_4240.exe
Translations added
Judit-4.36.00.118_ESE_533_2010_4230.exe
Fixed communication problem
Judit-4.36.00.119_LiIonen24V_2015_4250.exe
Node assignment function added
Judit-4.36.00.120_EJD_220_2019_4440.exe
Mast type is now a safety parameter, vehicle types expanded
Judit-4.36.00.121_EFG_2xx_3xx_2015_FG_4260.exe
Prop valve parameters changeable from level 6 and graphic representation of the values in case of exchange
Judit-4.36.00.122_EJD_220_2019_4450.exe
Parameter "Option stroke end switch initial stroke" added
Judit-4.36.00.123_SLH_300_2017_4070.exe
- Fix for shifts, deletions and "0" settings when saving / loading parameters
- "Characteristic curve 0x2590" parameter corrected. At the request of the line, parameter values "12" and "13" are combined in "11". 12 and 13 are now omitted.
- Texts for the selection of the parameter "Characteristic curve 0x2590" for the values "9" to "11" revised (incl. Translations).
Judit-4.36.00.124_EJC_2xx_2019_4130.exe
"Standard drive program" parameter expanded and new parameter "Pulse duration prop valve" added
Judit-4.36.00.125_ET_1_2_3_C_2019_4030.exe
Judit-4.36.00.126_ET2i_2019_4030.exe
Judit-4.36.00.127_ETVQ_2019_4040.exe
Judit-4.36.00.128_ET_1_2_3_C_2018_4090.exe
Judit-4.36.00.129_ET2i_2018_4070.exe
Judit-4.36.00.130_ETVQ_2018_4100.exe
MP enabling button can be taught
Judit-4.36.00.131_Platform_FG_2018_4080.exe
Major changes and extensions in the area of BUD management.
Judit-4.36.00.132_EMC_110_B10_2014_4500.exe
New parameter 0x256C charger characteristic, travel motor temperature sensor.
Judit-4.36.00.133_ECE_2xx_2015_4570.exe
Judit-4.36.00.134_ECE_3xx_2015_4510.exe
Parameter description for parameter P2339 adapted.
Judit-4.36.00.135_Platform_FG_2018_4090.exe
The handling of safety parameters (hydraulics, system, options) was incorrect. Parameter changes were not possible
Judit-4.36.00.137_EFG_FL_4070.exe
Judit-4.36.00.138_EFG_FL_H_4060.exe
Two new parameters: Option Controller Fan and Option Motor Fan
004.036.00004
16.11.2021
Changes
Div. Change points:
Translations added
- JETI ForkLift (Jungheinrich Judit) v4.26 [01.2013] FULL SET
- Jungheinrich Forklift License Code Generator
- JETI ForkLift (Jungheinrich Judit) v4.31 [03.2015] Full
- JETI ForkLift (ET) v4.33 [11.2016] Full + Instruction
- Jungheinrich Forklift Easy Error Codes
- JETI ForkLift (SH) v4.33 [11.2016] Full + Instruction
- New Jungheinrich (JETI) Judit-4 KG [2018] v3
- JUNGHEINRICH JETI V4.34 COMPLETE SET (ET, SH, JUDIT) [07.2017]
- JUNGHEINRICH JETI ForkLift (SH) v4.34 [07.2017] Full + Instruction
- Jungheinrich (JETI) Judit-4 License JH.lfj file Maker and KG 2015v2
- JUNGHEINRICH JETI ForkLift (SH) v4.35_ES [11.2018] Full + Instruction
- Jungheinrich Errors Pdf
- Jungheinrich JETI Judit ForkLift v4.36 2021 Full Diagnostic Software
- JUNGHEINRICH JETI ForkLift (ET) v4.34 07.2017 Full + Instruction
- JETI ForkLift (ET) v4.32 Update 321 [08.2016] Full + Instruction
