Jungheinrich (JETI) Judit-4 License JH.lfj file Maker and KG 2015v2
- Download this document, you need 3000 Gallons
Jungheinrich (JETI) Judit-4 License_JH.lfj file Maker and 2015v2 [2-5 Level]+Judit v3.2
Instruction:
1. Run "GetHWIDtool_new" to get ID
2. Run "WLGen_Judit iShell" in folder "KG Make Judit V2"
3. Click "License Manager"
4. Click "Add License"
Enter your information
Customer:
Company
HWID:
Days Expiration: 365
Click "Save"
5. Click "Create License Key" and then a license to be created
6. Copy file "regkey.Dat" in folder just to be created
6. Paste & replace near file "Judit_p"
7. Run "Judit_p"
Done and finish
( PC Unlock)
It for license file making & 2 in 1 (both response code + judit-4 license file making).
-activates JETI ProSecCo 4.4.7.0
-generate License_JH.lfj file for Judit.
-License file includes all Projects for v4.30-4.31
-License fiel activates level 9
it also works for version 4.28 - 4.29
with pc lock
Jungheinrich (JETI) KG + Judit 4 License_JH.lfj maker v2
-License file activates levels 2-5
2 - Complete level - With this level the customer is able to regulate the vehicle directly from the PC
3 - Advanced level - With this level the customer is able to regulate the vehicle directly from the PC, too. Furthermore the customer is able to execute the parameterisation of the vehicle. With this feature the change of special parts (example: a sensor) can be realized. Moreover the different error of the past will be saved in a special list
4 - Advanced plus level - This level has got the same features as the level "Advanced". Additionally, this level has got special diagnosis - tools to solve complex problems
5 - Exclusive level - With this level hardly every feature of the JUDIT-Software can be realized
6 - JH-KDT level - With this level every feature which is important for JH-KDT can be realized
7 - JH-TRB level - A change between the different levels can be realized with this level
9 - JH Software Developer level - This level is only for JH - Software Developer
Instruction:
Customer:
Company
HWID:
Click "Save"
7. Run "Judit_p"
Done and finish
( PC Unlock)
with pc lock
- JETI ForkLift (Jungheinrich Judit) v4.26 [01.2013] FULL SET
- Jungheinrich Forklift License Code Generator
- JETI ForkLift (ET) v4.33 [11.2016] Full + Instruction
- Jungheinrich Forklift Easy Error Codes
- JETI ForkLift (SH) v4.33 [11.2016] Full + Instruction
- New Jungheinrich (JETI) Judit-4 KG [2018] v3
- JUNGHEINRICH JETI V4.34 COMPLETE SET (ET, SH, JUDIT) [07.2017]
- JUNGHEINRICH JETI ForkLift (SH) v4.34 [07.2017] Full + Instruction
- JUNGHEINRICH JETI ForkLift (SH) v4.35_ES [11.2018] Full + Instruction
- Jungheinrich Errors Pdf
- Jungheinrich JETI Judit ForkLift v4.36 2021 Full Diagnostic Software
- JUNGHEINRICH JETI ForkLift (ET) v4.34 07.2017
- JETI ForkLift (ET) v4.32 Update 321 [08.2016] Full + Instruction
- JETI Forklift (Jungheinrich) ET v4.30 + Update 271/285
- JETI ForkLift (ET) v4.32 [11.2015] Full + Instruction
