bullseyemods
15
4,676
#72
ok i will do. i will start the upload tomorrow at work because my internet at home is very slow work is much faster and as soon as i have it uploaded ill post link
Busha
Well-Known Member
635
#74
you want to update to new version then make crack after. be sure to have a internet connection when doing update
I dont want to update to 04.1.011 if I dont have to. The problem is that I dont need to change anything then, when I update SA to 04.1.011 then I cannot crack it, this keygen and patch thing does not work ! Also, those .exe files that you have sent me do not work on that version. That is the problem.
And I have 201301 on "Current version" field so I dont need to do anything that you have told me in the registry, it says what DVD version I have and I dont need to change it.
Busha
Well-Known Member
635
#75
Bottomline, SA 04.0.002 can be cracked only with keygen, SA 04.1.011 CANNOT, and as soon as I load 201301 data DVD the update for Service Advisor starts, I cannot stop it if I want to run the progrem. So it is either have 04.0.002 version with no data since 201301 does not work or update to 04.1.011 version and have it unusable since I cannot start it because no one has the crack for that version.
bullseyemods
15
4,676
#76
ok... this is easy... i guess im stumped at what is wrong with your install. i just made a install on a laptop last night with service advisor. i used my normal install disk which is version 4.0.002....i put in disk 1 of 201207 and let it run updates which then brings it to version 4.1.007 and then i run the crack and patch. i then maker sure it is running correct. witch it always does... then i insdtall disk 1 201303 run the update which it does automatically when you insert the disk. i than save it to my hdd change the dates in disk, i make my explained registry changes and it works totally fine with me.. what ever is happening with yours is a freak thing that i dont have an answer for. only thing we might be able to do is comunicate out of forum open a teamviewer session and let me see whats happening.
bullseyemods
15
4,676
#77
this is wierd because the crack works for version 4.1.007
bullseyemods
15
4,676
#79
if you dont have 2012 data you may never be able to make it work as i mentioned in a previous post. i always start with my 201207 data then move up to 201303. ive never tried from fresh install of 4.0 directly to 2013 data so i have no idea, i would recommend being patient as im going to upload 201207 _01 starting tomorrow for all to have to make 2013 easier to install
Busha
Well-Known Member
635
#80
Ok, I dont have 2012 data, only 201301. I am waiting for that data and then will try. If I dont manage to do it I will kindly ask your assistance with TeamViewer.
Tnx
