Gyro
1
3,677
Press thanks on his post and also add to his reputation on that star under his nickname. Guys those discs are working ! So install 04.0.002 SA according to bullseyemods instructions, then load this disc AG_EN_201207_01, go to SAUCE folder and there on SAUpdate folder, start SA update and after that replace ServiceADVISOR.exe file with that provided in bullseyemods link. I got it working today, version 04.1.007 ! Only I dont remmember if I have done this like he said or I used those from keygen:
"DO NOT USE dl.xml.reg file or dl.xml files generated by keygen,( delete the two file made by kg) - USE the files in the lic folder."
In JDLM folder I have: jdlm.lic, PLUS1_2_1217_1_NA.lic and jd.menu files
Thanks a lot @bullseyemods and @volvosh, give them rep up that they deserve !
Hello Busha, I am still not successful to get 4.1.007 to work, Please are you able to help me?, thanks, Gyro
Gyro
1
3,677
Thank you for a quick answer.
I already have AG_EN_201207 and my update version of the program is now 4.1.007 which I cant get to work, my previous version 4.0.002 worked, but I could not load the data as I only had AG_RU_201301. I have downloaded all of this files from separate forums because I do not have 3000 credits to download this post files or someone can post the link without credits. Only thing I am missing is the Patch folder files that are mentioned here, so if there are BAT files I would kindly ask for someone to upload them as a separate download so I can follow Bullseyemods instructions and get the 4.1.007 to work and load the 2012 data.
I am afraid I only succeed until 4.0.002. Unable to succeed with 4.1.007 and unable to load data. Have you been successful? I will be so grateful if Busha or Bullseyemods or some helpful member can help, that 4.1.007 can be successful and load data. Many thanks, Gyro
krapo
584
hello for those who are interested that the test on three mobile computer
I have done like this
1-install AG_EN_201302_01 (01 A 08) installs CCE_EN_201302_01 (01 A 04) and historical AGHIST_EN_200801_01 (01 A 04) the ISO file has a total of 86 GB hard disk ------ IMPORTANT ----- - CREATING A FILE (ADVISOR) IN HARD DRIVE (C \ :) IN CASE ADVISOR CREATES A FILE NAME (ISOS) IN THE CASE FILES ISOS INSERT ISO (AG_EN_201302_01) 01A08 OR (AG_EN_201207_01) \ 01A08: CCE_EN_201302_01 AND AGHIST_EN_200801_01 (01A04)
2-install SA4.0.0002,
3-DOWNLOAD: JohnDree Service Advisor 4.0 kg With Patch! Place holder THE KEYGEN AND PATCH follow instruction
-4 - Installs DATA PATHS / VIRTUAL DRIVERS (FILE toolbar, preferences) map drive, browse, local disk, advisor, isos, enter any ISO files, close, load info
-5-go to local disk (AG_EN_201302_01) SAUCE SA_04_1_0XX,
MAKE UPDATE :::::::: ------- ----- RESTART
6-If you have any questions send me PM
krapo
584
Hi Gyro not AG_EN_201207 I have just AG_EN_201302, after instalation Service advisor you can make an update (open SA choose a model exp. Favorite place in 6420 models, go to toolbar (file) (update Data Now) follow instruction, your SA AG_EN_201207 will work
you don not have to force AGHIST_2008
