Momed80
150
35,046
Jaecoo Automotive J7 T1EJ Electrical Wiring Diagram
Brand: Jaecoo
Type of Machine: Automotive
Type of Manual: Electrical Wiring Diagram
Model: Jaecoo J7 T1EJ Automotive
Applicable Model and Configuration: 1.6T+7DCT
Publication Date: 2023
Number of Pages: 189 Pages
How to Use This Manual
Diagram Example
Description of Main Symbols in Circuit Diagram
Wire Harness Connector Definition and Location
Abbreviation
Troubleshooting
Troubleshooting Tool
Electrical Malfunction Troubleshooting
Fuse and Relay Information
Central Fuse and Relay Box
Instrument Panel Relay Box
Power Supply Distribution
Control Module Position and Terminal Definition
Module Terminal Definition
Ground Points Layout
Vehicle Ground Points Layout
Ground Point Definition
Wire Harness Location Diagram
Engine Electronic Fuel Injection Wire Harness (F4J16C) Connector Location Diagram
1.6T Injector Wire Harness Connector Location Diagram
1.6T Battery Positive Connector Location Diagram
1.6T Battery Negative Connector Location Diagram
1.6T Ground Wire Harness Connector Location Diagram
Front Radar Wire Harness Connector Location Diagram
Instrument Panel Wire Harness Connector Location Diagram
Interior Floor Wire Harness Connector Location Diagram
Front Left Door Wire Harness Connector Location Diagram
Front Right Door Wire Harness Connector Location Diagram
Rear Left Door Wire Harness Connector Location Diagram
Rear Right Door Wire Harness Connector Location Diagram
Left Back Door Wire Harness Connector Location Diagram
Right Back Door Wire Harness Connector Location Diagram
Rear Bumper Wire Harness Connector Location Diagram
Automatic A/C Wire Harness Connector Location Diagram
7DCT Transmission Wire Harness Connector Location Diagram
Vehicle Schematic Diagram
Start Charing
ECU (F4J16)
TCU (8AT)
TCU (7DCT)
BDM System
Entertainment Domain Controller
TBOX System
E Call System
GLONASS System
CVBOX System
DMS Driver Monitoring System
Automatic A/C
EPS System, Angle Sensor
ESP System
IPB System
Airbag System
Reversing Radar System (No Reversing Radar in Front, 4 Reversing Radars in Rear)
Reversing Radar System (4 Reversing Radars in Front, and 4 Reversing Radars in Rear)
Power Back Door (PLG)
Door Control Module
Blind Spot Monitor, Front Microwave Radar, Multi-function Front View Camera
Front Backup Power Supply, Luggage Compartment Backup Power Supply, 220 V Power Supply Controller, Front USB Charging Module, Rear USB Charging Module, ETC
Head Up Display Module, One-way Wireless Charging Module, Two-way Wireless Charging Module, Electronic Anti-glare Inside Rear View Mirror, Driving Recorder
Four-wheel Drive System (4WD)
Sunroof Motor, Diagnostic Interface
Driver Seat with Memory (High Configuration)
Driver Power Seat (Low Configuration), Driver Seat Heating (Low Configuration), Front Passenger Power Seat, Front Passenger Seat Heating (High Configuration)
Rear Seat Heating
Network Topological Diagram
LIN Line
