Momed80
150
35,046
Changan Automotive CS35PLUS Wiring Diagram 2019
Brand: Changan
Type of Machine: Automotive
Model: Changan CS35PLUS Automotive
Publication Date: 2019
Number of Pages: 538 Pages
6.1 Introduction
6.2 Symbol
6.3 Circuit Fault Diagnosis
Diagnostic Procedure
Diagnostic Tools
Fault Testing
Repair Tools
Wiring Harness Terminal Repair
6.4.1 Electronic Stability Control System
Electronic Stability Control System (for MT LEV1, MT LEV2 Models)
Electronic Stability Control System (for MT LEV3 Model)
Electronic Stability Control System (for AT LEV2, AT LEV3 Models)
6.4.2 Electronic Assist Steering
6.4.3 Cooling System
6.4.4 Fuel System
Fuel System
6.4.5 Ignition System
Ignition System
6.4.6 Starting System
Starting System - AT
Starting System - MT
6.4.7 Charging System
Charging System
6.4.8 Electronic Control System
Electronic Control System - 1
Electronic Control System - 2
Power Supply
Oxygen Sensor
Control Valve/Accelerator Pedal/Constant Speed Cruise
Neutral Sensor/Clutch Top Switch/Knock Sensor/Fuel Pressure Sensor/High Pressure Oil Pump/Camshaft Phase Sensor
Electronic Throttle Valve/Crankshaft Position Sensor/Brake Vacuum Sensor/ Coolant Temperature Sensor/Air Intake Temperature/Pressure Sensor
6.4.9 Automatic Transmission
6.4.10 Heating, Ventilation and Air Conditioning
Power Supply/Blower/Pressure Switch/Speed Regulation Module
Compressor
Actuator/Temperature Sensor/Sunlight Sensor
6.4.11 Airbag Restraint System
Power Supply/Actuator
Sensor/Switch
6.4.12 Instrument Cluster
Instrument Cluster
6.4.13 Horn
Horn
6.4.14 Cigarette Lighter & On-board Power Supply
6.4.15 Information and Entertainment System
Power Supply/Multi-functional Switch/Microphone/Antenna
Drive Recorder
Speaker
Rearview Monitor
6.4.16 Lighting System
Lighting System (for LEV2, LEV3 Models)
Lighting System (for MT LEV1 Model)
Headlamp (for LEV2, LEV3 Models)
Headlamp (for MT LEV1 Model)
Position Lamp (for LEV2, LEV3 Models)
Position Lamp (for MT LEV1 Model)
Turn Lamp (for LEV2, LEV3 Models)
Turn Lamp (for MT LEV1 Model)
Fog Lamp (for LEV2, LEV3 Models)
Fog Lamp (for MT LEV1 Model)
Brake Lamp (for LEV2, LEV3 Models)
Brake Lamp (for MT LEV1 Model)
Backup Lamp (for LEV2, LEV3 Models)
Backup Lamp (for MT LEV1 Model)
Daytime Running Lamp
Indoor Lamp (for LEV2, LEV3 Models)
Indoor Lamp (for MT LEV1 Model)
6.4.17 Wiper and Washer
Wiper (for LEV2, LEV3 Models)
Wiper (for MT LEV1 Model)
Front Wiper (for LEV2, LEV3 Models)
Rear Wiper (for LEV2, LEV3 Models)
Front Wiper (for MT LEV1 Model)
Rear Wiper (for MT LEV1 Model)
6.4.18 Power Rearview Mirror
6.4.19 Central Door Lock and Body Theft Deterrent System
Central Door Lock and Body Theft Deterrent System (for LEV2, LEV3 Models)
Central Door Lock and Body Theft Deterrent System (for MT LEV1 Model)
Switch Signal (for LEV2, LEV3 Models)
Actuator (for LEV2, LEV3 Models)
Switch Signal (for MT LEV1 Model)
Actuator (for MT LEV1 Model)
Key Reminder Switch (for MT LEV1 Model)
6.4.20 Power Window
Power Window (for MT LEV3, AT LEV3 Models)
Power Window (for MT LEV2, AT LEV2 Models)
Power Window (for MT LEV1 Model)
Left Front Door Window (Anti-Pinch) (for MT LEV3, AT LEV3 Models)
Left Rear Door Window (for MT LEV3, AT LEV3 Models)
Right Front/Right Rear Door Window (for MT LEV3, AT LEV3 Models)
Left Front Door Window (Non Anti-Pinch) (for MT LEV2, AT LEV2 Models)
Left Rear Door Window (for MT LEV2, AT LEV2 Models)
Right Front/Right Rear Door Window (for MT LEV2, AT LEV2 Models)
Left Front Door Window (Non Anti-Pinch) (for MT LEV1 Model)
Left Rear Door Window (for MT LEV1 Model)
Right Front/Right Rear Door Window (for MT LEV1 Model)
6.4.21 Defroster
Defroster
6.4.22 Sunroof
Sunroof
6.4.23 Parking Assist System
Parking Assist System (for LEV2, LEV3 Models)
Parking Assist System (for MT LEV1 Model)
6.4.24 Body Control System
Body Control System (for LEV2, LEV3 Models)
Body Control System (for MT LEV1 Model)
6.4.25 On-board Network System
On-board Network System - 1
On-board Network System - 2
6.4.26 Keyless Entry Control System
Power Supply
Start Switch
Antenna
6.4.27 Electronic Steering Lock System
6.4.28 Electronic Parking Brake System
Electronic Parking Brake System (for AT LEV2, AT LEV3 Models)
Electronic Parking Brake System (for MT LEV3 Model)
AUTOHOLD and EPB Switch (for AT LEV2, AT LEV3 Models)
Electronic Parking Brake Actuator Motor (for AT LEV2, AT LEV3 Models)
AUTOHOLD and EPB Switch (for MT LEV3 Model)
Electronic Parking Brake Actuator Motor/Clutch Stroke Sensor (for MT LEV3 Model)
6.4.29 Tire Pressure Monitoring
6.4.30 Self-adaptive Cruise
Self-adaptive Cruise (for AT LEV3 Model)
6.5 Fuses and Relays
Battery Positive
Engine Compartment Fuse Box
Engine Compartment Sub Fuse Box
Instrument Panel Fuse Box
6.6 Power Supply Distribution
Power Supply Distribution - 1
Power Supply Distribution - 2
Power Supply Distribution - 3
Power Supply Distribution - 4
Power Supply Distribution - 5
Power Supply Distribution - 6
Power Supply Distribution - 7
Power Supply Distribution - 8
6.7 Fuse Details
EF01 EF08 EF37 EF38 EF39 ER20 ER21
EF03 EF21 EF22 ER22
EF18 ER25 ER26
EF06 EF28 EF29 EF31 ER11
EF09 EF26 EF30 SB03 SB05 SB10 ER01 ER04 ER07 ER09 ER10 ER14
SB06 SB07 SB08 EF27 ER06 ER08 ER12
EF23 EF24 EF25 ER13 ER16 ER17
EF24 EF25 EF33 EF34 ER13 ER16
SB13 SB14 EF35 EF36
EF07 EF10 EF11 EF12 ER18 ER19
SB01 SB04 EF14 EF15 ER03 ER15
SB02 SB09 DF01 DF16 DF17 DF18 DF20 DF21 DF45 DF46
DF02 DF03 DF04 DF06 DF07 DF08 DF09 DF44 DF47
DF22 DF23 DF24 DF25 DF26
DF26 DF37 DF38 DF41 DF42 DF43 DF51 DF52
6.8 Grounding Distribution
G301G303 G304 G305 G306 G1401
G302 G307 G308
G101 G102 G103 GD106 G1902
G104 G105 G106
G201 G401
G202 G203 G204 G205 G207
G206 G208 G210
6.9 Wiring Harness Connector Location View
Wiring Harness to Wiring Harness (X--)
Engine Compartment Wiring Harness Connector (C--)
Engine Wiring Harness Connector (E--)
Instrument Panel Wiring Harness Connector (P--)
Chassis Wiring Harness Connector (S--)
Door Wiring Harness Connector (D--)
Roof Wiring Harness Connector (L--)
6.10 Grounding Location View
G301a G301b G302 G303 G304 G305 G306 G307 G308 G1401
GD01 GD02 GD106 G1902
G101 G102 G103 G104 G105 G106
G201 G202 G203 G204 G205 G206 G207 G208 G210
G401
6.11 Wiring Harness Connector Terminal View
Wiring Harness to Wiring Harness Connector (X--)
6.12 Abbreviation
Abbreviation List
