Momed80
150
35,046
Changan Automotive CS75-18 Wiring Diagram 2018
Brand: Changan
Type of Machine: Automotive
Model: Changan CS75-18 Automotive
Publication Date: 2018
Number of Pages: 596 Pages
6.1 Introduction
6.2 Symbol
6.3 Circuit Fault Diagnosis
Diagnostic Procedure
Diagnostic Tools
Fault Testing
Repair Tools
Wiring Harness Terminal Repair
6.4.1 Tire Pressure Monitoring
6.4.2 Electronic Stability Control System
Power Supply/Switch
Sensor
6.4.3 Electronic Assist Steering
6.4.4 Cooling System
6.4.5 Fuel System
Fuel System
6.4.6 Ignition System
Ignition System
6.4.7 Starting System
Starting System
Starting System (for Level1 Model)
Starting System (for Level2, Level3, Level4 Models)
6.4.8 Charging System
Charging System
6.4.9 Electronic Control System
Power Supply
Power Supply/Discharge Control Valve/Oxygen Sensor/Exhaust Control Valve/Canister Control Valve
Camshaft Sensor/Electronic Accelerator Pedal/Electronic Thermostat/ Electronic Throttle
Intercooler Pressure Sensor/Coolant Temperature Sensor/Air Intake Temperature Sensor/Constant Speed Cruise
Knock Sensor/Crankshaft Sensor
6.4.10 Automatic Transmission
6.4.11 Heating, Ventilation and Air Conditioning
Heating, Ventilation and Air Conditioning - 1
Heating, Ventilation and Air Conditioning - 2
Electric A/C - Pressure Switch/Compressor
Electric A/C - Blower
Electric A/C - Power Supply/Controller
Electric A/C - Actuator
Automatic A/C - Pressure Switch/Compressor
Automatic A/C - Blower
Automatic A/C - Power Supply/Controller
Automatic A/C - Actuator
6.4.12 Airbag Restraint System
Power Supply/Actuator
Sensor and Switch
Actuator
6.4.13 Instrument Cluster
Instrument Cluster
Power Supply and Signal
Signal Lamp 1
Signal Lamp 2
6.4.14 Horn
Horn
6.4.15 Cigarette Lighter & On-board Power Supply
6.4.16 Information and Entertainment System
Power Supply
Microphone/Antenna/Multi-functional Switch
Front Speaker
Rear Speaker
Rearview Monitor (for Level2, Level3 Models)
6.4.17 Lighting System
Lighting System - 1
Lighting System - 2
Lighting System - 3
Headlamp/Light Adjusting
Position Lamp
Turn Lamp
Front Fog Lamp
Rear Fog Lamp
Brake Lamp
Backup Lamp
Daytime Running Lamp/Foot Lamp
Indoor Lamp
6.4.18 Wiper and Washer
Wiper and Washer
Front Wiper Switch
Front Wiper Motor
Rear Wiper
6.4.19 Power Rearview Mirror
Power Rearview Mirror (for Level1, Level2, Level3 Models)
Power Rearview Mirror (for Level4 Model)
Rearview Mirror Folding (for Level4 Model)
6.4.20 Central Door Lock and Body Theft Deterrent System
Power Supply and Switch Signal
Switch Signal
Actuator (for Level1 Model)
Actuator (for Level2, Level3, Level4 Models)
6.4.21 Power Window
Power Window
Power Window (for Level1, Level2, Level3 Models) - Left Front Door
Power Window (for Level1, Level2, Level3 Models) - Right Front Door
Power Window (for Level1 Model) - Left Rear Door
Power Window (for Level2, Level3 Models) - Left Rear Door
Power Window (for Level1 Model) - Right Rear Door
Power Window (for Level2, Level3 Models) - Right Rear Door
Power Window (for Level4 Model) - Left Front Door
Power Window (for Level4 Model) - Right Front Door
Power Window (for Level4 Model) - Left Rear Door
Power Window (for Level4 Model) - Right Rear Door
6.4.22 Defroster
Defroster
6.4.23 Sunroof
Sunroof
6.4.24 Parking Assist System
Power Supply and Switches
Reversing Radar Sensor (for Level1 Model)
Reversing Radar Sensor (for Level2, Level3, Level4 Models)
6.4.25 Body Control System
Body Control System
6.4.26 On-board Network System
On-board Network System - 1
On-board Network System - 2
On-board Network System - 3
On-board Network System - 4
6.4.27 Keyless Entry Control System
Power Supply
Antenna
Start Switch
6.4.28 Power Seat
Power Seat
Seat Adjustment
Seat Ventilation
6.4.29 Electronic Parking Brake System
AUTOHOLD and EPB Switch
Electronic Parking Brake Actuator Motor
6.4.30 Blind Spot Monitoring System
Controller
Indicator
6.4.31 4WD System
4WD System
6.4.32 360° Panoramic View Monitor System
6.5 Fuses and Relays
Battery Fuse Box E28
Engine Compartment Main Fuse Box C13
Engine Compartment Sub Fuse Box C03
Instrument Panel Fuse Box P04
6.6 Power Supply Distribution
6.7 Fuse Details
SB02 EF06 EF07 EF09 EF11 EF29 EF30 EF31 ER02
EF01 EF03 EF10 ER01
SB01 SB09 EF02 EF16 ER07 ER08 ER11 ER15
SB08 EF20 EF21 ER04 ER06 ER12
SB11 SB12 SB14 EF08 EF15 ER04 ER05
EF12 EF13 EF14 EF17 EF18 ER03 ER09 ER10
SB03 SB04 SB05 SB06 SB07 EF22 EF23 EF24
ER14 ER17
IF12 IF13 IF14 IF15 IF17 IF21 IF35
IF18 IF19 IF20 IF22 IF23 IR03
IF16 IF25 IF27 IR08 IR09
IF26 IF28 IF29 IF30 IF36 IR01 IR04
IF08 IF09 IR43 IR02
IF03 IF04 IF07 IF10 IF31 IF32
IF02 IF05 IF06 ER16
IF38 IF39 IF40 IF41 IF42
6.8 Grounding Distribution
GND01 G101 G102 G103
G104 G105 G106 G107
G108 G109 G110 G201 G202
G203 G204 G205 G206
G207 G208 G301 G302 G303
G304 G305 G306
G307 G308 G309 G310 G311
6.9 Wiring Harness Connector Location View
Wiring Harness to Wiring Harness (X--)
Engine Compartment Wiring Harness (C--)
Engine Wiring Harness Connector (E--)
Instrument Panel Wiring Harness Connector (P--)
Chassis Wiring Harness Connector (S--)
Door Wiring Harness Connector (D--)
Roof Wiring Harness Connector (L--)
6.10 Grounding Location View
GND01 G101 G102 G103 G104 G105 G106
G107 G108 G109 G110
G201 G202 G203 G204 G205 G206 G207 G208
G301 G302 G303 G304 G305 G306 G307 G308 G309 G310
G311
G311
6.11 Wiring Harness Connector Terminal View
Wiring Harness to Wiring Harness Connector (X--)
Engine Compartment Wiring Harness Connector (C--)
6.12 Abbreviation
Abbreviation List
