Truck
651
1,893,713
Isuzu N Series 2026 Electronic Service Information Wiring Diagram LGHTML-WEN-2661
Download this document, you need 8625 Gallons
Type of Machine: Truck
Type of Manual: Electronic Service Information - Mechanical Repair Procedures, Diagnostics Service Information - Troubleshooting(DTC), Wiring Diagram
Model: Isuzu N Series Truck
Date: 2026
Engine: Isuzu 4HK1 ; 4JZ1 ; RZ4E-TC Engine
EU, UK, Israel and Turkey (Date: 2026/08/21)
Parts Number: LGHTML-WEN-2661
Purchase Options: You can buy the Full Package or click on the individual links below to buy them separately.
------ List of Files ------
1. Introduction Safety Information
2. [Mechanical Repair Procedures]
3. [Diagnostics Service Information - Troubleshooting(DTC)]
4. [Wiring Diagram]
LHD 4HK1 4JZ1 ABSIESCEBS.pdf​
LHD 4HK1 4JZ1 Backup Light.pdf​
LHD 4HK1 4JZ1 Battery Equalizer.pdf​
LHD 4HK1 4JZ1 Body Control.pdf​
LHD 4HK1 4JZ1 Center DisplayMonitorAudio (Audio).pdf​
LHD 4HK1 4JZ1 Center DisplayMonitorAudio (Electric Inner Mirror).pdf​
LHD 4HK1 4JZ1 Central ECU.pdf​
LHD 4HK1 4JZ1 Central Gateway.pdf​
LHD 4HK1 4JZ1 Combination Meter.pdf​
LHD 4HK1 4JZ1 Combination Switch.pdf​
LHD 4HK1 4JZ1 Controller Area Network (ADAS Local CAN1).pdf​
LHD 4HK1 4JZ1 Controller Area Network (ADAS Local CAN2).pdf​
LHD 4HK1 4JZ1 Controller Area Network (ADAS Local CAN3).pdf​
LHD 4HK1 4JZ1 Controller Area Network (Chassis CAN).pdf​
LHD 4HK1 4JZ1 Controller Area Network (Data Storage CAN).pdf​
LHD 4HK1 4JZ1 Controller Area Network (DIAG CAN).pdf​
LHD 4HK1 4JZ1 Controller Area Network (INFO CAN).pdf​
LHD 4HK1 4JZ1 Controller Area Network (ISO CAN).pdf​
LHD 4HK1 4JZ1 Controller Area Network (PT CAN).pdf​
LHD 4HK1 4JZ1 Controller Area Network (Vehicle CAN (J1939)).pdf​
LHD 4HK1 4JZ1 Daytime Running Light.pdf​
LHD 4HK1 4JZ1 DC-DC Converter.pdf​
LHD 4HK1 4JZ1 DCT.pdf​
LHD 4HK1 4JZ1 DLC.pdf​
LHD 4HK1 4JZ1 Dome Light.pdf​
LHD 4HK1 4JZ1 Driver Monitoring System.pdf​
LHD 4HK1 4JZ1 Electric Parking Brake.pdf​
LHD 4HK1 4JZ1 Electrical Socket.pdf​
LHD 4HK1 4JZ1 Engine Control (4HK1).pdf​
LHD 4HK1 4JZ1 Engine Control (4JZ1).pdf​
LHD 4HK1 4JZ1 Fog Light (Front Fog Light).pdf​
LHD 4HK1 4JZ1 Fog Light (Rear Fog Light).pdf​
LHD 4HK1 4JZ1 Fuse Load.pdf​
LHD 4HK1 4JZ1 Ground Distribution (Cab).pdf​
LHD 4HK1 4JZ1 Ground Distribution (Chassis).pdf​
LHD 4HK1 4JZ1 Headlight Washer.pdf​
LHD 4HK1 4JZ1 Headlight.pdf​
LHD 4HK1 4JZ1 Horn.pdf​
LHD 4HK1 4JZ1 HVAC.pdf​
LHD 4HK1 4JZ1 Illumination.pdf​
LHD 4HK1 4JZ1 Information Module.pdf​
LHD 4HK1 4JZ1 IO Control.pdf​
LHD 4HK1 4JZ1 MAP Unit.pdf​
LHD 4HK1 4JZ1 Outside Mirror.pdf​
LHD 4HK1 4JZ1 Power Distribution.pdf​
LHD 4HK1 4JZ1 Power Door Locks.pdf​
LHD 4HK1 4JZ1 Power Windows.pdf​
LHD 4HK1 4JZ1 PTO (Cable Control).pdf​
LHD 4HK1 4JZ1 PTO (Electrical Control (DCT)).pdf​
LHD 4HK1 4JZ1 PTO (Electrical Control (MT)).pdf​
LHD 4HK1 4JZ1 Radar Sensor.pdf​
LHD 4HK1 4JZ1 Seats.pdf​
LHD 4HK1 4JZ1 Service Connector (CAN Converter CU (FCG)).pdf​
LHD 4HK1 4JZ1 Service Connector (Service Connector).pdf​
LHD 4HK1 4JZ1 Smoother.pdf​
LHD 4HK1 4JZ1 SRS airbag.pdf​
LHD 4HK1 4JZ1 Starter and Charging (MT).pdf​
LHD 4HK1 4JZ1 Starter and Charging (Smoother DCT).pdf​
LHD 4HK1 4JZ1 Stereo Camera.pdf​
LHD 4HK1 4JZ1 Stoplight.pdf​
LHD 4HK1 4JZ1 Tachograph.pdf​
LHD 4HK1 4JZ1 Taillight.pdf​
LHD 4HK1 4JZ1 Tire Pressure Monitoring System.pdf​
LHD 4HK1 4JZ1 Turn Signal Light.pdf​
LHD 4HK1 4JZ1 Urea SCR (4HK1).pdf​
LHD 4HK1 4JZ1 Urea SCR (4JZ1).pdf​
LHD 4HK1 4JZ1 Windshield Wiper and Washer.pdf​
LHD 4HK1 4JZ1 Wireless Access Module.pdf​
LHD RZ4E ABSIESCEBS.pdf​
LHD RZ4E Automatic Transmission.pdf​
LHD RZ4E Backup Light.pdf​
LHD RZ4E Body Control.pdf​
LHD RZ4E Center DisplayMonitorAudio (Audio).pdf​
LHD RZ4E Center DisplayMonitorAudio (Monitor).pdf​
LHD RZ4E Central ECU.pdf​
LHD RZ4E Central Gateway.pdf​
LHD RZ4E Combination Meter.pdf​
LHD RZ4E Combination Switch.pdf​
LHD RZ4E Controller Area Network (ADAS Local CAN1).pdf​
LHD RZ4E Controller Area Network (ADAS Local CAN2).pdf​
LHD RZ4E Controller Area Network (ADAS Local CAN3).pdf​
LHD RZ4E Controller Area Network (Chassis CAN).pdf​
LHD RZ4E Controller Area Network (Data Storage CAN).pdf​
LHD RZ4E Controller Area Network (DIAG CAN).pdf​
LHD RZ4E Controller Area Network (INFO CAN).pdf​
LHD RZ4E Controller Area Network (ISO CAN).pdf​
LHD RZ4E Controller Area Network (PT CAN).pdf​
LHD RZ4E Controller Area Network (Vehicle CAN (J1939)).pdf​
LHD RZ4E Daytime Running Light.pdf​
LHD RZ4E DC-DC Converter (iVST).pdf​
LHD RZ4E DLC.pdf​
LHD RZ4E Dome Light.pdf​
LHD RZ4E Driver Monitoring System.pdf​
LHD RZ4E eCall.pdf​
LHD RZ4E Electric Parking Brake.pdf​
LHD RZ4E Electrical Socket.pdf​
LHD RZ4E Engine Control.pdf​
LHD RZ4E Fog Light (Front Fog Light).pdf​
LHD RZ4E Fog Light (Rear Fog Light).pdf​
LHD RZ4E Fuse Load.pdf​
LHD RZ4E Ground Distribution (Cab).pdf​
LHD RZ4E Ground Distribution (Chassis).pdf​
LHD RZ4E Headlight.pdf​
LHD RZ4E Horn.pdf​
LHD RZ4E HVAC.pdf​
LHD RZ4E Illumination.pdf​
LHD RZ4E Information Module.pdf​
LHD RZ4E IO Control.pdf​
LHD RZ4E MAP Unit.pdf​
LHD RZ4E Outside Mirror.pdf​
LHD RZ4E Power Assisted System.pdf​
LHD RZ4E Power Distribution.pdf​
LHD RZ4E Power Door Locks.pdf​
LHD RZ4E Power Windows.pdf​
LHD RZ4E Radar Sensor.pdf​
LHD RZ4E Service Connector (CAN Converter CU (FCG)).pdf​
LHD RZ4E Service Connector (Service Connector).pdf​
LHD RZ4E SRS airbag.pdf​
LHD RZ4E Starter and Charging.pdf​
LHD RZ4E Stereo Camera.pdf​
LHD RZ4E Stoplight.pdf​
LHD RZ4E Taillight.pdf​
LHD RZ4E Tire Pressure Monitoring System.pdf​
LHD RZ4E Turn Signal Light.pdf​
LHD RZ4E Urea SCR.pdf​
LHD RZ4E Windshield Wiper and Washer.pdf​
LHD RZ4E Wireless Access Module.pdf​
RHD 4HK1 4JZ1 ABSIESCEBS.pdf​
RHD 4HK1 4JZ1 Backup Light.pdf​
RHD 4HK1 4JZ1 Battery Equalizer.pdf​
RHD 4HK1 4JZ1 Body Control.pdf​
RHD 4HK1 4JZ1 Center DisplayMonitorAudio (Audio).pdf​
RHD 4HK1 4JZ1 Center DisplayMonitorAudio (Electric Inner Mirror).pdf​
RHD 4HK1 4JZ1 Central ECU.pdf​
RHD 4HK1 4JZ1 Central Gateway.pdf​
RHD 4HK1 4JZ1 Combination Meter.pdf​
RHD 4HK1 4JZ1 Combination Switch.pdf​
RHD 4HK1 4JZ1 Controller Area Network (ADAS Local CAN1).pdf​
RHD 4HK1 4JZ1 Controller Area Network (ADAS Local CAN2).pdf​
RHD 4HK1 4JZ1 Controller Area Network (ADAS Local CAN3).pdf​
RHD 4HK1 4JZ1 Controller Area Network (Chassis CAN).pdf​
RHD 4HK1 4JZ1 Controller Area Network (Data Storage CAN).pdf​
RHD 4HK1 4JZ1 Controller Area Network (DIAG CAN).pdf​
RHD 4HK1 4JZ1 Controller Area Network (INFO CAN).pdf​
RHD 4HK1 4JZ1 Controller Area Network (ISO CAN).pdf​
RHD 4HK1 4JZ1 Controller Area Network (PT CAN).pdf​
RHD 4HK1 4JZ1 Controller Area Network (Vehicle CAN (J1939)).pdf​
RHD 4HK1 4JZ1 Daytime Running Light.pdf​
RHD 4HK1 4JZ1 DC-DC Converter.pdf​
RHD 4HK1 4JZ1 DCT.pdf​
RHD 4HK1 4JZ1 DLC.pdf​
RHD 4HK1 4JZ1 Dome Light.pdf​
RHD 4HK1 4JZ1 Driver Monitoring System.pdf​
RHD 4HK1 4JZ1 Electric Parking Brake.pdf​
RHD 4HK1 4JZ1 Electrical Socket.pdf​
RHD 4HK1 4JZ1 Engine Control (4HK1).pdf​
RHD 4HK1 4JZ1 Engine Control (4JZ1).pdf​
RHD 4HK1 4JZ1 Fog Light (Front Fog Light).pdf​
RHD 4HK1 4JZ1 Fog Light (Rear Fog Light).pdf​
RHD 4HK1 4JZ1 Fuse Load.pdf​
RHD 4HK1 4JZ1 Ground Distribution (Cab).pdf​
RHD 4HK1 4JZ1 Ground Distribution (Chassis).pdf​
RHD 4HK1 4JZ1 Headlight Washer.pdf​
RHD 4HK1 4JZ1 Headlight.pdf​
RHD 4HK1 4JZ1 Horn.pdf​
RHD 4HK1 4JZ1 HVAC.pdf​
RHD 4HK1 4JZ1 Illumination.pdf​
RHD 4HK1 4JZ1 Information Module.pdf​
RHD 4HK1 4JZ1 IO Control.pdf​
RHD 4HK1 4JZ1 MAP Unit.pdf​
RHD 4HK1 4JZ1 Outside Mirror.pdf​
RHD 4HK1 4JZ1 Power Distribution.pdf​
RHD 4HK1 4JZ1 Power Door Locks.pdf​
RHD 4HK1 4JZ1 Power Windows.pdf​
RHD 4HK1 4JZ1 PTO (Cable Control).pdf​
RHD 4HK1 4JZ1 PTO (Electrical Control (DCT)).pdf​
RHD 4HK1 4JZ1 PTO (Electrical Control (MT)).pdf​
RHD 4HK1 4JZ1 Radar Sensor.pdf​
RHD 4HK1 4JZ1 Seats.pdf​
RHD 4HK1 4JZ1 Service Connector (CAN Converter CU (FCG)).pdf​
RHD 4HK1 4JZ1 Service Connector (Service Connector).pdf​
RHD 4HK1 4JZ1 Smoother.pdf​
RHD 4HK1 4JZ1 SRS airbag.pdf​
RHD 4HK1 4JZ1 Starter and Charging (MT).pdf​
RHD 4HK1 4JZ1 Starter and Charging (Smoother DCT).pdf​
RHD 4HK1 4JZ1 Stereo Camera.pdf​
RHD 4HK1 4JZ1 Stoplight.pdf​
RHD 4HK1 4JZ1 Tachograph.pdf​
RHD 4HK1 4JZ1 Taillight.pdf​
RHD 4HK1 4JZ1 Tire Pressure Monitoring System.pdf​
RHD 4HK1 4JZ1 Turn Signal Light.pdf​
RHD 4HK1 4JZ1 Urea SCR (4HK1).pdf​
RHD 4HK1 4JZ1 Urea SCR (4JZ1).pdf​
RHD 4HK1 4JZ1 Windshield Wiper and Washer.pdf​
RHD 4HK1 4JZ1 Wireless Access Module.pdf​
RHD RZ4E ABSIESCEBS.pdf​
RHD RZ4E Automatic Transmission.pdf​
RHD RZ4E Backup Light.pdf​
RHD RZ4E Body Control.pdf​
RHD RZ4E Center DisplayMonitorAudio (Audio).pdf​
RHD RZ4E Center DisplayMonitorAudio (Monitor).pdf​
RHD RZ4E Central ECU.pdf​
RHD RZ4E Central Gateway.pdf​
RHD RZ4E Combination Meter.pdf​
RHD RZ4E Combination Switch.pdf​
RHD RZ4E Controller Area Network (ADAS Local CAN1).pdf​
RHD RZ4E Controller Area Network (ADAS Local CAN2).pdf​
RHD RZ4E Controller Area Network (ADAS Local CAN3).pdf​
RHD RZ4E Controller Area Network (Chassis CAN).pdf​
RHD RZ4E Controller Area Network (Data Storage CAN).pdf​
RHD RZ4E Controller Area Network (DIAG CAN).pdf​
RHD RZ4E Controller Area Network (INFO CAN).pdf​
RHD RZ4E Controller Area Network (ISO CAN).pdf​
RHD RZ4E Controller Area Network (PT CAN).pdf​
RHD RZ4E Controller Area Network (Vehicle CAN (J1939)).pdf​
RHD RZ4E Daytime Running Light.pdf​
RHD RZ4E DC-DC Converter (iVST).pdf​
RHD RZ4E DLC.pdf​
RHD RZ4E Dome Light.pdf​
RHD RZ4E Driver Monitoring System.pdf​
RHD RZ4E eCall.pdf​
RHD RZ4E Electric Parking Brake.pdf​
RHD RZ4E Electrical Socket.pdf​
RHD RZ4E Engine Control.pdf​
RHD RZ4E Fog Light (Front Fog Light).pdf​
RHD RZ4E Fog Light (Rear Fog Light).pdf​
RHD RZ4E Fuse Load.pdf​
RHD RZ4E Ground Distribution (Cab).pdf​
RHD RZ4E Ground Distribution (Chassis).pdf​
RHD RZ4E Headlight Washer.pdf​
RHD RZ4E Headlight.pdf​
RHD RZ4E Horn.pdf​
RHD RZ4E HVAC.pdf​
RHD RZ4E Illumination.pdf​
RHD RZ4E Information Module.pdf​
RHD RZ4E IO Control.pdf​
RHD RZ4E MAP Unit.pdf​
RHD RZ4E Outside Mirror.pdf​
RHD RZ4E Power Assisted System.pdf​
RHD RZ4E Power Distribution.pdf​
RHD RZ4E Power Door Locks.pdf​
RHD RZ4E Power Windows.pdf​
RHD RZ4E Radar Sensor.pdf​
RHD RZ4E Service Connector (CAN Converter CU (FCG)).pdf​
RHD RZ4E Service Connector (Service Connector).pdf​
RHD RZ4E SRS airbag.pdf​
RHD RZ4E Starter and Charging.pdf​
RHD RZ4E Stereo Camera.pdf​
RHD RZ4E Stoplight.pdf​
RHD RZ4E Taillight.pdf​
RHD RZ4E Tire Pressure Monitoring System.pdf​
RHD RZ4E Turn Signal Light.pdf​
RHD RZ4E Urea SCR.pdf​
RHD RZ4E Windshield Wiper and Washer.pdf​
RHD RZ4E Wireless Access Module.pdf​
