Isuzu N Series 2026 Electronic Service Information Wiring Diagram LGHTML-WEN-2661
- Download this document, you need 8625 Gallons
Type of Manual: Electronic Service Information - Mechanical Repair Procedures, Diagnostics Service Information - Troubleshooting(DTC), Wiring Diagram
Model: Isuzu N Series Truck
Date: 2026
Engine: Isuzu 4HK1 ; 4JZ1 ; RZ4E-TC Engine
EU, UK, Israel and Turkey (Date: 2026/08/21)
Parts Number: LGHTML-WEN-2661
Purchase Options: You can buy the Full Package or click on the individual links below to buy them separately.
------ List of Files ------
1. Introduction Safety Information
2. [Mechanical Repair Procedures]
3. [Diagnostics Service Information - Troubleshooting(DTC)]
4. [Wiring Diagram]
Date: 2026
4. [Wiring Diagram]
LHD 4HK1 4JZ1 ABSIESCEBS.pdf
LHD 4HK1 4JZ1 Backup Light.pdf
LHD 4HK1 4JZ1 Battery Equalizer.pdf
LHD 4HK1 4JZ1 Body Control.pdf
LHD 4HK1 4JZ1 Center DisplayMonitorAudio (Audio).pdf
LHD 4HK1 4JZ1 Center DisplayMonitorAudio (Electric Inner Mirror).pdf
LHD 4HK1 4JZ1 Central ECU.pdf
LHD 4HK1 4JZ1 Central Gateway.pdf
LHD 4HK1 4JZ1 Combination Meter.pdf
LHD 4HK1 4JZ1 Combination Switch.pdf
LHD 4HK1 4JZ1 Controller Area Network (ADAS Local CAN1).pdf
LHD 4HK1 4JZ1 Controller Area Network (ADAS Local CAN2).pdf
LHD 4HK1 4JZ1 Controller Area Network (ADAS Local CAN3).pdf
LHD 4HK1 4JZ1 Controller Area Network (Chassis CAN).pdf
LHD 4HK1 4JZ1 Controller Area Network (Data Storage CAN).pdf
LHD 4HK1 4JZ1 Controller Area Network (DIAG CAN).pdf
LHD 4HK1 4JZ1 Controller Area Network (INFO CAN).pdf
LHD 4HK1 4JZ1 Controller Area Network (ISO CAN).pdf
LHD 4HK1 4JZ1 Controller Area Network (PT CAN).pdf
LHD 4HK1 4JZ1 Controller Area Network (Vehicle CAN (J1939)).pdf
LHD 4HK1 4JZ1 Daytime Running Light.pdf
LHD 4HK1 4JZ1 DC-DC Converter.pdf
LHD 4HK1 4JZ1 DCT.pdf
LHD 4HK1 4JZ1 DLC.pdf
LHD 4HK1 4JZ1 Dome Light.pdf
LHD 4HK1 4JZ1 Driver Monitoring System.pdf
LHD 4HK1 4JZ1 Electric Parking Brake.pdf
LHD 4HK1 4JZ1 Electrical Socket.pdf
LHD 4HK1 4JZ1 Engine Control (4HK1).pdf
LHD 4HK1 4JZ1 Engine Control (4JZ1).pdf
LHD 4HK1 4JZ1 Fog Light (Front Fog Light).pdf
LHD 4HK1 4JZ1 Fog Light (Rear Fog Light).pdf
LHD 4HK1 4JZ1 Fuse Load.pdf
LHD 4HK1 4JZ1 Ground Distribution (Cab).pdf
LHD 4HK1 4JZ1 Ground Distribution (Chassis).pdf
LHD 4HK1 4JZ1 Headlight Washer.pdf
LHD 4HK1 4JZ1 Headlight.pdf
LHD 4HK1 4JZ1 Horn.pdf
LHD 4HK1 4JZ1 HVAC.pdf
LHD 4HK1 4JZ1 Illumination.pdf
LHD 4HK1 4JZ1 Information Module.pdf
LHD 4HK1 4JZ1 IO Control.pdf
LHD 4HK1 4JZ1 MAP Unit.pdf
LHD 4HK1 4JZ1 Outside Mirror.pdf
LHD 4HK1 4JZ1 Power Distribution.pdf
LHD 4HK1 4JZ1 Power Door Locks.pdf
LHD 4HK1 4JZ1 Power Windows.pdf
LHD 4HK1 4JZ1 PTO (Cable Control).pdf
LHD 4HK1 4JZ1 PTO (Electrical Control (DCT)).pdf
LHD 4HK1 4JZ1 PTO (Electrical Control (MT)).pdf
LHD 4HK1 4JZ1 Radar Sensor.pdf
LHD 4HK1 4JZ1 Seats.pdf
LHD 4HK1 4JZ1 Service Connector (CAN Converter CU (FCG)).pdf
LHD 4HK1 4JZ1 Service Connector (Service Connector).pdf
LHD 4HK1 4JZ1 Smoother.pdf
LHD 4HK1 4JZ1 SRS airbag.pdf
LHD 4HK1 4JZ1 Starter and Charging (MT).pdf
LHD 4HK1 4JZ1 Starter and Charging (Smoother DCT).pdf
LHD 4HK1 4JZ1 Stereo Camera.pdf
LHD 4HK1 4JZ1 Stoplight.pdf
LHD 4HK1 4JZ1 Tachograph.pdf
LHD 4HK1 4JZ1 Taillight.pdf
LHD 4HK1 4JZ1 Tire Pressure Monitoring System.pdf
LHD 4HK1 4JZ1 Turn Signal Light.pdf
LHD 4HK1 4JZ1 Urea SCR (4HK1).pdf
LHD 4HK1 4JZ1 Urea SCR (4JZ1).pdf
LHD 4HK1 4JZ1 Windshield Wiper and Washer.pdf
LHD 4HK1 4JZ1 Wireless Access Module.pdf
LHD RZ4E ABSIESCEBS.pdf
LHD RZ4E Automatic Transmission.pdf
LHD RZ4E Backup Light.pdf
LHD RZ4E Body Control.pdf
LHD RZ4E Center DisplayMonitorAudio (Audio).pdf
LHD RZ4E Center DisplayMonitorAudio (Monitor).pdf
LHD RZ4E Central ECU.pdf
LHD RZ4E Central Gateway.pdf
LHD RZ4E Combination Meter.pdf
LHD RZ4E Combination Switch.pdf
LHD RZ4E Controller Area Network (ADAS Local CAN1).pdf
LHD RZ4E Controller Area Network (ADAS Local CAN2).pdf
LHD RZ4E Controller Area Network (ADAS Local CAN3).pdf
LHD RZ4E Controller Area Network (Chassis CAN).pdf
LHD RZ4E Controller Area Network (Data Storage CAN).pdf
LHD RZ4E Controller Area Network (DIAG CAN).pdf
LHD RZ4E Controller Area Network (INFO CAN).pdf
LHD RZ4E Controller Area Network (ISO CAN).pdf
LHD RZ4E Controller Area Network (PT CAN).pdf
LHD RZ4E Controller Area Network (Vehicle CAN (J1939)).pdf
LHD RZ4E Daytime Running Light.pdf
LHD RZ4E DC-DC Converter (iVST).pdf
LHD RZ4E DLC.pdf
LHD RZ4E Dome Light.pdf
LHD RZ4E Driver Monitoring System.pdf
LHD RZ4E eCall.pdf
LHD RZ4E Electric Parking Brake.pdf
LHD RZ4E Electrical Socket.pdf
LHD RZ4E Engine Control.pdf
LHD RZ4E Fog Light (Front Fog Light).pdf
LHD RZ4E Fog Light (Rear Fog Light).pdf
LHD RZ4E Fuse Load.pdf
LHD RZ4E Ground Distribution (Cab).pdf
LHD RZ4E Ground Distribution (Chassis).pdf
LHD RZ4E Headlight.pdf
LHD RZ4E Horn.pdf
LHD RZ4E HVAC.pdf
LHD RZ4E Illumination.pdf
LHD RZ4E Information Module.pdf
LHD RZ4E IO Control.pdf
LHD RZ4E MAP Unit.pdf
LHD RZ4E Outside Mirror.pdf
LHD RZ4E Power Assisted System.pdf
LHD RZ4E Power Distribution.pdf
LHD RZ4E Power Door Locks.pdf
LHD RZ4E Power Windows.pdf
LHD RZ4E Radar Sensor.pdf
LHD RZ4E Service Connector (CAN Converter CU (FCG)).pdf
LHD RZ4E Service Connector (Service Connector).pdf
LHD RZ4E SRS airbag.pdf
LHD RZ4E Starter and Charging.pdf
LHD RZ4E Stereo Camera.pdf
LHD RZ4E Stoplight.pdf
LHD RZ4E Taillight.pdf
LHD RZ4E Tire Pressure Monitoring System.pdf
LHD RZ4E Turn Signal Light.pdf
LHD RZ4E Urea SCR.pdf
LHD RZ4E Windshield Wiper and Washer.pdf
LHD RZ4E Wireless Access Module.pdf
RHD 4HK1 4JZ1 ABSIESCEBS.pdf
RHD 4HK1 4JZ1 Backup Light.pdf
RHD 4HK1 4JZ1 Battery Equalizer.pdf
RHD 4HK1 4JZ1 Body Control.pdf
RHD 4HK1 4JZ1 Center DisplayMonitorAudio (Audio).pdf
RHD 4HK1 4JZ1 Center DisplayMonitorAudio (Electric Inner Mirror).pdf
RHD 4HK1 4JZ1 Central ECU.pdf
RHD 4HK1 4JZ1 Central Gateway.pdf
RHD 4HK1 4JZ1 Combination Meter.pdf
RHD 4HK1 4JZ1 Combination Switch.pdf
RHD 4HK1 4JZ1 Controller Area Network (ADAS Local CAN1).pdf
RHD 4HK1 4JZ1 Controller Area Network (ADAS Local CAN2).pdf
RHD 4HK1 4JZ1 Controller Area Network (ADAS Local CAN3).pdf
RHD 4HK1 4JZ1 Controller Area Network (Chassis CAN).pdf
RHD 4HK1 4JZ1 Controller Area Network (Data Storage CAN).pdf
RHD 4HK1 4JZ1 Controller Area Network (DIAG CAN).pdf
RHD 4HK1 4JZ1 Controller Area Network (INFO CAN).pdf
RHD 4HK1 4JZ1 Controller Area Network (ISO CAN).pdf
RHD 4HK1 4JZ1 Controller Area Network (PT CAN).pdf
RHD 4HK1 4JZ1 Controller Area Network (Vehicle CAN (J1939)).pdf
RHD 4HK1 4JZ1 Daytime Running Light.pdf
RHD 4HK1 4JZ1 DC-DC Converter.pdf
RHD 4HK1 4JZ1 DCT.pdf
RHD 4HK1 4JZ1 DLC.pdf
RHD 4HK1 4JZ1 Dome Light.pdf
RHD 4HK1 4JZ1 Driver Monitoring System.pdf
RHD 4HK1 4JZ1 Electric Parking Brake.pdf
RHD 4HK1 4JZ1 Electrical Socket.pdf
RHD 4HK1 4JZ1 Engine Control (4HK1).pdf
RHD 4HK1 4JZ1 Engine Control (4JZ1).pdf
RHD 4HK1 4JZ1 Fog Light (Front Fog Light).pdf
RHD 4HK1 4JZ1 Fog Light (Rear Fog Light).pdf
RHD 4HK1 4JZ1 Fuse Load.pdf
RHD 4HK1 4JZ1 Ground Distribution (Cab).pdf
RHD 4HK1 4JZ1 Ground Distribution (Chassis).pdf
RHD 4HK1 4JZ1 Headlight Washer.pdf
RHD 4HK1 4JZ1 Headlight.pdf
RHD 4HK1 4JZ1 Horn.pdf
RHD 4HK1 4JZ1 HVAC.pdf
RHD 4HK1 4JZ1 Illumination.pdf
RHD 4HK1 4JZ1 Information Module.pdf
RHD 4HK1 4JZ1 IO Control.pdf
RHD 4HK1 4JZ1 MAP Unit.pdf
RHD 4HK1 4JZ1 Outside Mirror.pdf
RHD 4HK1 4JZ1 Power Distribution.pdf
RHD 4HK1 4JZ1 Power Door Locks.pdf
RHD 4HK1 4JZ1 Power Windows.pdf
RHD 4HK1 4JZ1 PTO (Cable Control).pdf
RHD 4HK1 4JZ1 PTO (Electrical Control (DCT)).pdf
RHD 4HK1 4JZ1 PTO (Electrical Control (MT)).pdf
RHD 4HK1 4JZ1 Radar Sensor.pdf
RHD 4HK1 4JZ1 Seats.pdf
RHD 4HK1 4JZ1 Service Connector (CAN Converter CU (FCG)).pdf
RHD 4HK1 4JZ1 Service Connector (Service Connector).pdf
RHD 4HK1 4JZ1 Smoother.pdf
RHD 4HK1 4JZ1 SRS airbag.pdf
RHD 4HK1 4JZ1 Starter and Charging (MT).pdf
RHD 4HK1 4JZ1 Starter and Charging (Smoother DCT).pdf
RHD 4HK1 4JZ1 Stereo Camera.pdf
RHD 4HK1 4JZ1 Stoplight.pdf
RHD 4HK1 4JZ1 Tachograph.pdf
RHD 4HK1 4JZ1 Taillight.pdf
RHD 4HK1 4JZ1 Tire Pressure Monitoring System.pdf
RHD 4HK1 4JZ1 Turn Signal Light.pdf
RHD 4HK1 4JZ1 Urea SCR (4HK1).pdf
RHD 4HK1 4JZ1 Urea SCR (4JZ1).pdf
RHD 4HK1 4JZ1 Windshield Wiper and Washer.pdf
RHD 4HK1 4JZ1 Wireless Access Module.pdf
RHD RZ4E ABSIESCEBS.pdf
RHD RZ4E Automatic Transmission.pdf
RHD RZ4E Backup Light.pdf
RHD RZ4E Body Control.pdf
RHD RZ4E Center DisplayMonitorAudio (Audio).pdf
RHD RZ4E Center DisplayMonitorAudio (Monitor).pdf
RHD RZ4E Central ECU.pdf
RHD RZ4E Central Gateway.pdf
RHD RZ4E Combination Meter.pdf
RHD RZ4E Combination Switch.pdf
RHD RZ4E Controller Area Network (ADAS Local CAN1).pdf
RHD RZ4E Controller Area Network (ADAS Local CAN2).pdf
RHD RZ4E Controller Area Network (ADAS Local CAN3).pdf
RHD RZ4E Controller Area Network (Chassis CAN).pdf
RHD RZ4E Controller Area Network (Data Storage CAN).pdf
RHD RZ4E Controller Area Network (DIAG CAN).pdf
RHD RZ4E Controller Area Network (INFO CAN).pdf
RHD RZ4E Controller Area Network (ISO CAN).pdf
RHD RZ4E Controller Area Network (PT CAN).pdf
RHD RZ4E Controller Area Network (Vehicle CAN (J1939)).pdf
RHD RZ4E Daytime Running Light.pdf
RHD RZ4E DC-DC Converter (iVST).pdf
RHD RZ4E DLC.pdf
RHD RZ4E Dome Light.pdf
RHD RZ4E Driver Monitoring System.pdf
RHD RZ4E eCall.pdf
RHD RZ4E Electric Parking Brake.pdf
RHD RZ4E Electrical Socket.pdf
RHD RZ4E Engine Control.pdf
RHD RZ4E Fog Light (Front Fog Light).pdf
RHD RZ4E Fog Light (Rear Fog Light).pdf
RHD RZ4E Fuse Load.pdf
RHD RZ4E Ground Distribution (Cab).pdf
RHD RZ4E Ground Distribution (Chassis).pdf
RHD RZ4E Headlight Washer.pdf
RHD RZ4E Headlight.pdf
RHD RZ4E Horn.pdf
RHD RZ4E HVAC.pdf
RHD RZ4E Illumination.pdf
RHD RZ4E Information Module.pdf
RHD RZ4E IO Control.pdf
RHD RZ4E MAP Unit.pdf
RHD RZ4E Outside Mirror.pdf
RHD RZ4E Power Assisted System.pdf
RHD RZ4E Power Distribution.pdf
RHD RZ4E Power Door Locks.pdf
RHD RZ4E Power Windows.pdf
RHD RZ4E Radar Sensor.pdf
RHD RZ4E Service Connector (CAN Converter CU (FCG)).pdf
RHD RZ4E Service Connector (Service Connector).pdf
RHD RZ4E SRS airbag.pdf
RHD RZ4E Starter and Charging.pdf
RHD RZ4E Stereo Camera.pdf
RHD RZ4E Stoplight.pdf
RHD RZ4E Taillight.pdf
RHD RZ4E Tire Pressure Monitoring System.pdf
RHD RZ4E Turn Signal Light.pdf
RHD RZ4E Urea SCR.pdf
RHD RZ4E Windshield Wiper and Washer.pdf
RHD RZ4E Wireless Access Module.pdf
