Isuzu N Series 2026 Mechanical Repair Procedures LGHTML-WEN-2661
Type of Manual: Workshop Manual - Mechanical Repair Procedures
Model: Isuzu N Series Truck
Date: 2026
Engine: Isuzu 4HK1 ; 4JZ1 ; RZ4E-TC Engine
EU, UK, Israel and Turkey (Date: 2026/08/21)
Parts Number: LGHTML-WEN-2661
Number of Pages: 10509 Pages
1.1. Engine (4HK1)
1B. Mechanical​
Camshaft - disassembly​
Camshaft - inspection​
Camshaft - installation​
Camshaft - reassembly​
Camshaft - removal​
Crankshaft - disassembly​
Crankshaft - inspection​
Crankshaft - installation​
Crankshaft - reassembly​
Crankshaft - removal​
Crankshaft front oil seal - installation​
Crankshaft front oil seal - removal​
Crankshaft pulley - installation​
Crankshaft pulley - removal​
Crankshaft rear oil seal - installation​
Crankshaft rear oil seal - removal​
Cylinder block - disassembly​
Cylinder block - inspection​
Cylinder block - installation​
Cylinder block - reassembly​
Cylinder block - removal​
Cylinder head - disassembly​
Cylinder head - inspection​
Cylinder head - installation​
Cylinder head - reassembly​
Cylinder head - removal​
Cylinder head cover - installation​
Cylinder head cover - removal​
Engine - installation​
Engine - removal​
Engine mounting - installation​
Engine mounting - removal​
Exhaust manifold - inspection​
Exhaust manifold - installation​
Exhaust manifold - removal​
Flywheel - disassembly​
Flywheel - inspection​
Flywheel - installation​
Flywheel - reassembly​
Flywheel - removal​
Flywheel housing - installation​
Flywheel housing - removal​
Front cover - installation​
Front cover - removal​
Idle gear - inspection​
Idle gear - installation​
Idle gear - removal​
Inlet cover - installation​
Inlet cover - removal​
Intake throttle valve - installation​
Intake throttle valve - removal​
Piston - disassembly​
Piston - inspection​
Piston - installation​
Piston - reassembly​
Piston - removal​
Rocker arm shaft - disassembly​
Rocker arm shaft - inspection​
Rocker arm shaft - installation​
Rocker arm shaft - reassembly​
Rocker arm shaft - removal​
Supplementary Information​
1C. Fuel System​
Common rail (fuel rail) - installation​
Common rail (fuel rail) - removal​
FRP regulator - installation​
FRP regulator - removal​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Fuel cooler - installation​
Fuel cooler - removal​
Fuel filter - installation​
Fuel filter - removal​
Fuel filter element - installation​
Fuel filter element - removal​
Fuel supply pump - installation​
Fuel supply pump - removal​
Fuel tank - installation​
Fuel tank - removal​
Fuel tank unit - inspection​
Fuel tank unit - installation​
Fuel tank unit - removal​
Injector - installation​
Injector - removal​
Pre-fuel filter - installation​
Pre-fuel filter - removal​
Pre-fuel filter element - inspection​
Pre-fuel filter element - installation​
Pre-fuel filter element - removal​
Pressure limiter - installation​
Pressure limiter - removal​
Water sedimenter switch - inspection​
Water sedimenter switch - installation​
Water sedimenter switch - removal​
1D. Cooling​
Coolant - inspection​
Coolant - replacement​
Cooling fan belt - inspection​
Cooling fan belt - installation​
Cooling fan belt - removal​
Cooling fan clutch - inspection​
Cooling fan clutch - installation​
Cooling fan clutch - removal​
Radiator - inspection​
Radiator - installation​
Radiator - removal​
Radiator reserve tank - installation​
Radiator reserve tank - removal​
Thermostat - inspection​
Thermostat - installation​
Thermostat - removal​
Water pump - inspection​
Water pump - installation​
Water pump - removal​
1E. Lubrication​
Engine oil - inspection​
Engine oil - replacement​
Oil cooler - disassembly​
Oil cooler - installation​
Oil cooler - reassembly​
Oil cooler - removal​
Oil filter - installation​
Oil filter - removal​
Oil filter element - installation​
Oil filter element - removal​
Oil level switch - installation​
Oil level switch - removal​
Oil pan - installation​
Oil pan - removal​
Oil pressure switch - installation​
Oil pressure switch - removal​
Oil pump - disassembly​
Oil pump - inspection​
Oil pump - installation​
Oil pump - reassembly​
Oil pump - removal​
1F. Induction​
Air cleaner element - inspection​
Air cleaner element - installation​
Air cleaner element - removal​
Air cleaner indicator switch - inspection​
Air cleaner indicator switch - installation​
Air cleaner indicator switch - removal​
Intercooler - inspection​
Intercooler - installation​
Intercooler - removal​
Turbocharger - inspection​
Turbocharger - installation​
Turbocharger - removal​
Ventilator - installation​
Ventilator - removal​
Vertical air intake duct - installation​
Vertical air intake duct - removal​
1G. Exhaust​
DPD - disassembly​
DPD - inspection​
DPD - installation​
DPD - reassembly​
DPD - removal​
Exhaust pipe - inspection​
Exhaust pipe - installation​
Exhaust pipe - removal​
1H. Aux. Emission Control Devices​
Dosing module - disassembly​
Dosing module - installation​
Dosing module - reassembly​
Dosing module - removal​
EGR - inspection​
EGR - installation​
EGR - removal​
Urea fluid - inspection​
Urea fluid supply module - disassembly​
Urea fluid supply module - inspection​
Urea fluid supply module - installation​
Urea fluid supply module - reassembly​
Urea fluid supply module - removal​
Urea fluid supply module filter - installation​
Urea fluid supply module filter - removal​
Urea fluid tank - installation​
Urea fluid tank - removal​
Urea fluid tank heater coolant control valve - installation​
Urea fluid tank heater coolant control valve - removal​
Urea fluid tank level gauge - installation​
Urea fluid tank level gauge - removal​
Urea SCR - disassembly​
Urea SCR - inspection​
Urea SCR - installation​
Urea SCR - reassembly​
Urea SCR - removal​
1I. Speed Control Systems​
Accelerator pedal - installation​
Accelerator pedal - removal​
Idle up sensor - inspection​
Idle up sensor - installation​
Idle up sensor - removal​
1J. Electrical​
Generator (Bosch) - disassembly​
Generator (Bosch) - inspection​
Generator (Bosch) - installation​
Generator (Bosch) - reassembly​
Generator (Bosch) - removal​
Generator(Mitsubishi) - disassembly​
Generator(Mitsubishi) - inspection​
Generator(Mitsubishi) - installation​
Generator(Mitsubishi) - reassembly​
Generator(Mitsubishi) - removal​
Glow plug - inspection​
Glow plug - installation​
Glow plug - removal​
Starter motor - disassembly​
Starter motor - inspection​
Starter motor - installation​
Starter motor - reassembly​
Starter motor - removal​
1Z. Engine Electrical Control​
Boost pressure sensor - inspection​
Boost pressure sensor - installation​
Boost pressure sensor - removal​
Charge air cooler temperature sensor 1 - inspection​
Charge air cooler temperature sensor 1 - installation​
Charge air cooler temperature sensor 1 - removal​
Charge air cooler temperature sensor - inspection​
Charge air cooler temperature sensor - installation​
Charge air cooler temperature sensor - removal​
CKP sensor - inspection​
CKP sensor - installation​
CKP sensor - removal​
CMP sensor - inspection​
CMP sensor - installation​
CMP sensor - removal​
DCU - installation​
DCU - removal​
DCU - setting​
ECM - inspection​
ECM - installation​
ECM - removal​
ECM - setting​
EGR gas temperature sensor 1 - inspection​
EGR gas temperature sensor 1 - installation​
EGR gas temperature sensor 1 - removal​
EGR gas temperature sensor 2 - inspection​
EGR gas temperature sensor 2 - installation​
EGR gas temperature sensor 2 - removal​
Engine coolant temperature sensor - inspection​
Engine coolant temperature sensor - installation​
Engine coolant temperature sensor - removal​
Exhaust differential pressure sensor - inspection​
Exhaust differential pressure sensor - installation​
Exhaust differential pressure sensor - removal​
Exhaust gas temperature sensor 3 - installation​
Exhaust gas temperature sensor 3 - removal​
Exhaust gas temperature sensor - inspection​
Exhaust gas temperature sensor - installation​
Exhaust gas temperature sensor - removal​
FRP sensor - inspection​
FRP sensor - installation​
FRP sensor - removal​
Fuel temperature sensor - inspection​
Fuel temperature sensor - installation​
Fuel temperature sensor - removal​
IMT sensor - inspection​
IMT sensor - installation​
IMT sensor - removal​
MAF and IAT sensor - inspection​
MAF and IAT sensor - installation​
MAF and IAT sensor - removal​
NOx sensor 1 - inspection​
NOx sensor 1 - installation​
NOx sensor 1 - removal​
NOx sensor 2 - inspection​
NOx sensor 2 - installation​
NOx sensor 2 - removal​
PM sensor - installation​
PM sensor - removal​
Turbocharger outlet temperature sensor - inspection​
Turbocharger outlet temperature sensor - installation​
Turbocharger outlet temperature sensor - removal​
Urea fluid sensor - inspection​
Urea fluid sensor - installation​
Urea fluid sensor - removal​
VNT control module - installation​
VNT control module - removal​
1.2. Engine (4JZ1)
1B. Mechanical​
Camshaft - removal​
Engine - removal​
Flywheel - removal​
Inlet manifold - installation​
Inlet manifold - removal​
PCV valve - installation​
PCV valve - removal​
Piston - removal​
VVT control valve - inspection​
VVT control valve - installation​
VVT control valve - removal​
1C. Fuel System​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Fuel supply pump - setting​
Injector - removal​
1D. Cooling​
Auto tensioner - installation​
Auto tensioner - removal​
Radiator - removal​
1E. Lubrication​
Oil check valve - installation​
Oil check valve - removal​
Oil cooler - inspection​
Oil pan - removal​
Oil pump - removal​
1F. Induction​
1G. Exhaust​
DPD - disassembly​
DPD - inspection​
DPD - installation​
DPD - reassembly​
DPD - removal​
EGR cooler - inspection​
EGR cooler - installation​
EGR cooler - removal​
EGR valve - inspection​
EGR valve - installation​
EGR valve - removal​
Urea fluid electro-thermal heater - installation​
Urea fluid electro-thermal heater - removal​
Urea SCR - removal​
1J. Electrical​
Generator - disassembly​
Generator - inspection​
Generator - installation​
Generator - reassembly​
Generator - removal​
DCU - installation​
DCU - removal​
DCU - setting​
ECM - inspection​
ECM - installation​
ECM - removal​
ECM - setting​
EGR gas temperature sensor - inspection​
EGR gas temperature sensor - installation​
EGR gas temperature sensor - removal​
Engine oil temperature sensor - inspection​
Engine oil temperature sensor - installation​
Engine oil temperature sensor - removal​
Exhaust gas temperature sensor (DPD) - inspection​
Exhaust gas temperature sensor (DPD) - installation​
Exhaust gas temperature sensor (DPD) - removal​
Exhaust gas temperature sensor (oxidation catalyst) - inspection​
Exhaust gas temperature sensor (oxidation catalyst) - installation​
Exhaust gas temperature sensor (oxidation catalyst) - removal​
Exhaust gas temperature sensor (urea SCR) - inspection​
Exhaust gas temperature sensor (urea SCR) - installation​
Exhaust gas temperature sensor (urea SCR) - removal​
Oil level sensor - inspection​
Oil level sensor - installation​
Oil level sensor - removal​
Oil level sensor control unit - installation​
Oil level sensor control unit - removal​
Oil pressure sensor - inspection​
Oil pressure sensor - installation​
Oil pressure sensor - removal​
Urea fluid quality sensor - inspection​
Urea fluid quality sensor - installation​
Urea fluid quality sensor - removal​
1.3. Engine (RZ4E-TC)
1B. Mechanical​
Camshaft - removal​
Crankcase - inspection​
Crankcase - installation​
Crankcase - removal​
Engine - removal​
Flywheel - removal​
Piston - removal​
Swirl control solenoid valve - installation​
Swirl control solenoid valve - removal​
Timing chain - installation​
Timing chain - removal​
1C. Fuel System​
Fuel - air bleed​
Fuel - drain water​
Fuel - inspection​
Injector - removal​
1D. Cooling​
Radiator - removal​
1E. Lubrication​
Oil pan - removal​
Oil pressure switch - inspection​
Oil pump - removal​
1F. Induction​
1G. Exhaust​
DPD - inspection​
DPD - installation​
DPD - removal​
Exhaust throttle solenoid valve - inspection​
Exhaust throttle solenoid valve - installation​
Exhaust throttle solenoid valve - removal​
Exhaust throttle valve - disassembly​
Exhaust throttle valve - inspection​
Exhaust throttle valve - installation​
Exhaust throttle valve - reassembly​
Exhaust throttle valve - removal​
EGR - inspection​
EGR - installation​
EGR - removal​
EGR cooler bypass control solenoid valve - installation​
EGR cooler bypass control solenoid valve - removal​
Urea SCR - removal​
1J. Electrical​
Glow control unit - installation​
Glow control unit - removal​
ICR relay - inspection​
ICR relay - installation​
ICR relay - removal​
DCU - installation​
DCU - removal​
DCU - setting​
ECM - inspection​
ECM - installation​
ECM - removal​
ECM - setting​
EGR gas pressure sensor - inspection​
EGR gas pressure sensor - installation​
EGR gas pressure sensor - removal​
Exhaust gas temperature sensor 1 - inspection​
Exhaust gas temperature sensor 1 - installation​
Exhaust gas temperature sensor 1 - removal​
Exhaust gas temperature sensor 2 - inspection​
Exhaust gas temperature sensor 2 - installation​
Exhaust gas temperature sensor 2 - removal​
Exhaust gas temperature sensor 3 - inspection​
Heated oxygen sensor 1 - installation​
Heated oxygen sensor 1 - removal​
Heated oxygen sensor 2 - installation​
Heated oxygen sensor 2 - removal​
2. Suspension
2B. Front Suspension​
Independent suspension (transverse leaf spring type) - disassembly​
Independent suspension (transverse leaf spring type) - inspection​
Independent suspension (transverse leaf spring type) - installation​
Independent suspension (transverse leaf spring type) - reassembly​
Independent suspension (transverse leaf spring type) - removal​
Leaf rigid suspension - disassembly​
Leaf rigid suspension - inspection​
Leaf rigid suspension - installation​
Leaf rigid suspension - reassembly​
Leaf rigid suspension - removal​
2C. Rear Suspension​
2D. Wheel, Tire System​
Disc wheel and tire - inspection​
Disc wheel and tire - installation​
Disc wheel and tire - removal​
Tire pressure monitoring receiver - installation​
Tire pressure monitoring receiver - removal​
Tire pressure monitoring receiver - setting​
Tire pressure sensor - installation​
Tire pressure sensor - removal​
Tire pressure sensor - setting​
Wheel nut cover - installation​
Wheel nut cover - removal​
3. Driveline, Axle
3B. Differentials​
Differential oil - replacement​
Rear final drive (φ220 mm { 8.66 in }) - disassembly​
Rear final drive (φ220 mm { 8.66 in }) - inspection​
Rear final drive (φ220 mm { 8.66 in }) - installation​
Rear final drive (φ220 mm { 8.66 in }) - reassembly​
Rear final drive (φ220 mm { 8.66 in }) - removal​
Rear final drive (φ292 mm { 11.50 in }) - disassembly​
Rear final drive (φ292 mm { 11.50 in }) - inspection​
Rear final drive (φ292 mm { 11.50 in }) - installation​
Rear final drive (φ292 mm { 11.50 in }) - reassembly​
Rear final drive (φ292 mm { 11.50 in }) - removal​
Rear final drive (φ320 mm { 12.6 in }) - disassembly​
Rear final drive (φ320 mm { 12.6 in }) - inspection​
Rear final drive (φ320 mm { 12.6 in }) - installation​
Rear final drive (φ320 mm { 12.6 in }) - reassembly​
Rear final drive (φ320 mm { 12.6 in }) - removal​
3C. Drive Shaft System​
Front axle (disc brake) - inspection​
Front axle (disc brake) - installation​
Front axle (disc brake) - removal​
Front hub (disc brake) - disassembly​
Front hub (disc brake) - inspection​
Front hub (disc brake) - installation​
Front hub (disc brake) - reassembly​
Front hub (disc brake) - removal​
Knuckle (disc brake) (leaf rigid suspension) - disassembly​
Knuckle (disc brake) (leaf rigid suspension) - inspection​
Knuckle (disc brake) (leaf rigid suspension) - installation​
Knuckle (disc brake) (leaf rigid suspension) - reassembly​
Knuckle (disc brake) (leaf rigid suspension) - removal​
Knuckle (independent suspension) - inspection​
Knuckle (independent suspension) - installation​
Knuckle (independent suspension) - removal​
Knuckle arm (leaf rigid suspension) - inspection​
Knuckle arm (leaf rigid suspension) - installation​
Knuckle arm (leaf rigid suspension) - removal​
Propeller shaft - disassembly​
Propeller shaft - inspection​
Propeller shaft - installation​
Propeller shaft - reassembly​
Propeller shaft - removal​
Rear axle (disc brake) - disassembly​
Rear axle (disc brake) - inspection​
Rear axle (disc brake) - installation​
Rear axle (disc brake) - reassembly​
Rear axle (disc brake) - removal​
Rear axle (drum brake) - disassembly​
Rear axle (drum brake) - inspection​
Rear axle (drum brake) - installation​
Rear axle (drum brake) - reassembly​
Rear axle (drum brake) - removal​
Rear axle shaft - inspection​
Rear axle shaft - installation​
Rear axle shaft - removal​
Rear hub (disc brake) - disassembly​
Rear hub (disc brake) - inspection​
Rear hub (disc brake) - installation​
Rear hub (disc brake) - reassembly​
Rear hub (disc brake) - removal​
Rear hub (drum brake) - disassembly​
Rear hub (drum brake) - inspection​
Rear hub (drum brake) - installation​
Rear hub (drum brake) - reassembly​
Rear hub (drum brake) - removal​
Tie rod (leaf rigid suspension) - disassembly​
Tie rod (leaf rigid suspension) - inspection​
Tie rod (leaf rigid suspension) - installation​
Tie rod (leaf rigid suspension) - reassembly​
Tie rod (leaf rigid suspension) - removal​
Tie rod arm (leaf rigid suspension) - inspection​
Tie rod arm (leaf rigid suspension) - installation​
Tie rod arm (leaf rigid suspension) - removal​
Wheel alignment check​
4. Brakes
4B. Brake System​
Brake fluid - inspection​
Brake fluid - replacement​
Brake fluid tank (standard cab) - inspection​
Brake fluid tank (standard cab) - installation​
Brake fluid tank (standard cab) - removal​
Brake fluid tank (wide cab) - inspection​
Brake fluid tank (wide cab) - installation​
Brake fluid tank (wide cab) - removal​
Brake master cylinder - installation​
Brake master cylinder - removal​
Front disc brake - disassembly​
Front disc brake - inspection​
Front disc brake - installation​
Front disc brake - reassembly​
Front disc brake - removal​
Rear disc brake - disassembly​
Rear disc brake - inspection​
Rear disc brake - installation​
Rear disc brake - reassembly​
Rear disc brake - removal​
Rear drum brake - disassembly​
Rear drum brake - inspection​
Rear drum brake - installation​
Rear drum brake - reassembly​
Rear drum brake - removal​
Rear wheel cylinder - disassembly​
Rear wheel cylinder - inspection​
Rear wheel cylinder - installation​
Rear wheel cylinder - reassembly​
Rear wheel cylinder - removal​
Stoplight switch - inspection​
Stoplight switch - installation​
Stoplight switch - removal​
Vacuum brake booster (standard cab) - inspection​
Vacuum brake booster (standard cab) - installation​
Vacuum brake booster (standard cab) - removal​
Vacuum brake booster (wide cab) - inspection​
Vacuum brake booster (wide cab) - installation​
Vacuum brake booster (wide cab) - removal​
Vacuum pump(4HK1) - installation​
Vacuum pump(4HK1) - removal​
Vacuum pump(4JZ1) - disassembly​
Vacuum pump(4JZ1) - inspection​
Vacuum pump(4JZ1) - installation​
Vacuum pump(4JZ1) - reassembly​
Vacuum pump(4JZ1) - removal​
Vacuum pump(RZ4E) - disassembly​
Vacuum pump(RZ4E) - inspection​
Vacuum pump(RZ4E) - installation​
Vacuum pump(RZ4E) - reassembly​
Vacuum pump(RZ4E) - removal​
Vacuum switch (vacuum tank side) - inspection​
Vacuum switch (vacuum tank side) - installation​
Vacuum switch (vacuum tank side) - removal​
4C. Parking Brake System​
Electric parking brake actuator - installation​
Electric parking brake actuator - removal​
Electric parking brake switch - inspection​
Electric parking brake switch - installation​
Electric parking brake switch - removal​
Parking brake - inspection​
Parking brake - installation​
Parking brake - removal​
Parking brake lever - installation​
Parking brake lever - removal​
Parking brake switch - inspection​
Parking brake switch - installation​
Parking brake switch - removal​
4D. ABS​
Front exciter ring (disc brake) - inspection​
Front exciter ring (disc brake) - installation​
Front exciter ring (disc brake) - removal​
Rear exciter ring (disc brake) - inspection​
Rear exciter ring (disc brake) - installation​
Rear exciter ring (disc brake) - removal​
Rear exciter ring (drum brake) - inspection​
Rear exciter ring (drum brake) - installation​
Rear exciter ring (drum brake) - removal​
4E. Speed Retarder System​
Exhaust brake solenoid valve - inspection​
Exhaust brake solenoid valve - installation​
Exhaust brake solenoid valve - removal​
Exhaust brake valve (4HK1) - disassembly​
Exhaust brake valve (4HK1) - inspection​
Exhaust brake valve (4HK1) - installation​
Exhaust brake valve (4HK1) - reassembly​
Exhaust brake valve (4HK1) - removal​
Exhaust brake valve(4JZ1) - inspection​
Exhaust brake valve(4JZ1) - installation​
Exhaust brake valve(4JZ1) - removal​
4Z. Brake Electrical Control​
Brake pressure sensor - inspection​
Brake pressure sensor - installation​
Brake pressure sensor - removal​
EHCU - installation​
EHCU - removal​
EHCU - setting​
Electric parking brake control unit (standard cab) - installation​
Electric parking brake control unit (standard cab) - removal​
Electric parking brake control unit (standard cab) - setting​
Electric parking brake control unit (wide cab) - installation​
Electric parking brake control unit (wide cab) - removal​
Electric parking brake control unit (wide cab) - setting​
Front wheel speed sensor (disc brake) - inspection​
Front wheel speed sensor (disc brake) - installation​
Front wheel speed sensor (disc brake) - removal​
Rear wheel speed sensor (disc brake) - inspection​
Rear wheel speed sensor (disc brake) - installation​
Rear wheel speed sensor (disc brake) - removal​
Rear wheel speed sensor (drum brake) - inspection​
Rear wheel speed sensor (drum brake) - installation​
Rear wheel speed sensor (drum brake) - removal​
Vacuum sensor - installation​
Vacuum sensor - removal​
5.1. Transmission, Transaxle (MVC)
5C. Manual​
Gear control cable - inspection​
Gear control cable - installation​
Gear control cable - removal​
Input shaft - disassembly​
Input shaft - inspection​
Input shaft - reassembly​
Main shaft - disassembly​
Main shaft - inspection​
Main shaft - reassembly​
Neutral switch - inspection​
Neutral switch - installation​
Neutral switch - removal​
Rear case - disassembly​
Rear case - inspection​
Rear case - reassembly​
Rear oil seal - installation​
Rear oil seal - removal​
Shift lever - installation​
Shift lever - removal​
Transmission - disassembly​
Transmission - inspection​
Transmission - installation​
Transmission - reassembly​
Transmission - removal​
Transmission oil - inspection​
Transmission oil - replacement​
5E. Clutch System​
Clutch - inspection​
Clutch - installation​
Clutch - removal​
Clutch control - inspection​
Clutch control - installation​
Clutch control - removal​
Clutch master cylinder - disassembly​
Clutch master cylinder - inspection​
Clutch master cylinder - reassembly​
Clutch oil pressure switch - inspection​
Clutch oil pressure switch - installation​
Clutch oil pressure switch - removal​
Clutch switch - installation​
Clutch switch - removal​
Shift fork - inspection​
Shift fork - installation​
Shift fork - removal​
Slave cylinder (automatic adjustment) - disassembly​
Slave cylinder (automatic adjustment) - inspection​
Slave cylinder (automatic adjustment) - reassembly​
5Z. Transmission Electrical Control​
Clutch stroke sensor - inspection​
Clutch stroke sensor - installation​
Clutch stroke sensor - removal​
5.2. Transmission, Transaxle (MYR (DCT))
5C. Manual​
ATF - inspection​
ATF - replacement​
ATF cooler pipe - inspection​
ATF cooler pipe - installation​
ATF cooler pipe - removal​
Backup light switch - inspection​
Backup light switch - installation​
Backup light switch - removal​
Counter shaft - disassembly​
Counter shaft - inspection​
Counter shaft - reassembly​
DCT parts - inspection​
DCT parts - installation​
DCT parts - removal​
Inhibitor switch - inspection​
Inhibitor switch - installation​
Inhibitor switch - removal​
Inner input shaft - disassembly​
Inner input shaft - inspection​
Inner input shaft - reassembly​
Outer input shaft - disassembly​
Outer input shaft - inspection​
Outer input shaft - reassembly​
Output shaft - disassembly​
Output shaft - inspection​
Output shaft - reassembly​
Parking lock cable - installation​
Parking lock cable - removal​
5F. PTO​
PTO control lever - disassembly​
PTO control lever - installation​
PTO control lever - reassembly​
PTO control lever - removal​
Side PTO (cable control) - disassembly​
Side PTO (cable control) - inspection​
Side PTO (cable control) - installation​
Side PTO (cable control) - reassembly​
Side PTO (cable control) - removal​
Side PTO (electronic control) - disassembly​
Side PTO (electronic control) - inspection​
Side PTO (electronic control) - installation​
Side PTO (electronic control) - reassembly​
Side PTO (electronic control) - removal​
Floating gear speed sensor - inspection​
Floating gear speed sensor - installation​
Floating gear speed sensor - removal​
Inner input shaft speed sensor - inspection​
Inner input shaft speed sensor - installation​
Inner input shaft speed sensor - removal​
Outer input shaft speed sensor - inspection​
Outer input shaft speed sensor - installation​
Outer input shaft speed sensor - removal​
Output shaft speed sensor - inspection​
Output shaft speed sensor - installation​
Output shaft speed sensor - removal​
PTO control unit - installation​
PTO control unit - removal​
Shift stroke sensor 1 - inspection​
Shift stroke sensor 1 - installation​
Shift stroke sensor 1 - removal​
Shift stroke sensor 2 - inspection​
Shift stroke sensor 2 - installation​
Shift stroke sensor 2 - removal​
Shift stroke sensor 3 - inspection​
Shift stroke sensor 3 - installation​
Shift stroke sensor 3 - removal​
Shift stroke sensor 4 - inspection​
Shift stroke sensor 4 - installation​
Shift stroke sensor 4 - removal​
TCM - installation​
TCM - removal​
TCM - setting​
Turbine speed sensor - inspection​
Turbine speed sensor - installation​
Turbine speed sensor - removal​
5.3. Transmission, Transaxle (MYY)
5C. Manual​
Control box - disassembly​
Control box - inspection​
Control box - reassembly​
Counter shaft (5-speed) - disassembly​
Counter shaft (5-speed) - inspection​
Counter shaft (5-speed) - reassembly​
Counter shaft (6-speed) - disassembly​
Counter shaft (6-speed) - inspection​
Counter shaft (6-speed) - reassembly​
Main shaft (5-speed) - disassembly​
Main shaft (5-speed) - inspection​
Main shaft (5-speed) - reassembly​
Main shaft (6-speed) - disassembly​
Main shaft (6-speed) - inspection​
Main shaft (6-speed) - reassembly​
Rear oil seal (5-speed) - installation​
Rear oil seal (5-speed) - removal​
Rear oil seal (6-speed) - installation​
Rear oil seal (6-speed) - removal​
Transmission (5-speed) - disassembly​
Transmission (5-speed) - inspection​
Transmission (5-speed) - installation​
Transmission (5-speed) - reassembly​
Transmission (5-speed) - removal​
Transmission (6-speed) - disassembly​
Transmission (6-speed) - inspection​
Transmission (6-speed) - installation​
Transmission (6-speed) - reassembly​
Transmission (6-speed) - removal​
5E. Clutch System​
Clutch - removal​
Clutch booster - disassembly​
Clutch booster - inspection​
Clutch booster - reassembly​
Slave cylinder (manual adjustment) - disassembly​
Slave cylinder (manual adjustment) - inspection​
Slave cylinder (manual adjustment) - reassembly​
5F. PTO​
Input speed sensor - inspection​
Input speed sensor - installation​
Input speed sensor - removal​
5.4. Transmission, Transaxle (MZZ)
5C. Manual​
5E. Clutch System​
Clutch - removal​
5F. PTO​
5.5. Transmission, Transaxle (R6B45)
5B. Automatic​
ATF - inspection​
ATF - replacement​
ATF cooler_warmer - installation​
ATF cooler_warmer - removal​
Automatic transmission control cable - inspection​
Automatic transmission control cable - installation​
Automatic transmission control cable - removal​
Brake piston No.1 - disassembly​
Brake piston No.1 - reassembly​
Brake piston No.2 - disassembly​
Brake piston No.2 - reassembly​
Forward clutch assembly - disassembly​
Forward clutch assembly - inspection​
Forward clutch assembly - reassembly​
Front planetary ring gear - disassembly​
Front planetary ring gear - inspection​
Front planetary ring gear - reassembly​
Middle planetary ring gear - disassembly​
Middle planetary ring gear - reassembly​
Rear planetary ring gear - disassembly​
Rear planetary ring gear - inspection​
Rear planetary ring gear - reassembly​
Selector lever - installation​
Selector lever - removal​
Output speed sensor - inspection​
Output speed sensor - installation​
Output speed sensor - removal​
TCM - installation​
TCM - removal​
TCM - setting​
5.6. Transmission, Transaxle (Smoother (MZZ))
5C. Manual​
ATF - inspection​
ATF - replacement​
Gear shift unit - disassembly​
Gear shift unit - inspection​
Gear shift unit - reassembly​
Smoother parts - inspection​
Smoother parts - installation​
Smoother parts - removal​
5F. PTO​
Select stroke sensor - inspection​
Select stroke sensor - installation​
Select stroke sensor - removal​
Shift stroke sensor - inspection​
Shift stroke sensor - installation​
Shift stroke sensor - removal​
TCM - installation​
TCM - removal​
TCM - setting​
6. Steering
6B. Power Assisted System​
Drag link - inspection​
Drag link - installation​
Drag link - removal​
Power steering fluid - replacement​
Power steering oil pump (4H series engine) - disassembly​
Power steering oil pump (4H series engine) - inspection​
Power steering oil pump (4H series engine) - installation​
Power steering oil pump (4H series engine) - reassembly​
Power steering oil pump (4H series engine) - removal​
Power steering oil pump (4JZ1) - disassembly​
Power steering oil pump (4JZ1) - inspection​
Power steering oil pump (4JZ1) - installation​
Power steering oil pump (4JZ1) - reassembly​
Power steering oil pump (4JZ1) - removal​
Power steering oil pump (RZ4E) - disassembly​
Power steering oil pump (RZ4E) - inspection​
Power steering oil pump (RZ4E) - installation​
Power steering oil pump (RZ4E) - reassembly​
Power steering oil pump (RZ4E) - removal​
Power steering unit (independent suspension) - disassembly​
Power steering unit (independent suspension) - installation​
Power steering unit (independent suspension) - reassembly​
Power steering unit (independent suspension) - removal​
Power steering unit (leaf rigid suspension) - disassembly​
Power steering unit (leaf rigid suspension) - inspection​
Power steering unit (leaf rigid suspension) - installation​
Power steering unit (leaf rigid suspension) - reassembly​
Power steering unit (leaf rigid suspension) - removal​
Steering shaft (with steering motor control unit) - inspection​
Steering shaft (with steering motor control unit) - installation​
Steering shaft (with steering motor control unit) - removal​
Steering shaft (with steering motor control unit) - setting​
Steering shaft - inspection​
Steering shaft - installation​
Steering shaft - removal​
Transfer gear - inspection​
Transfer gear - installation​
Transfer gear - removal​
6Z. Steering Electrical Control​
Steering angle sensor - installation​
Steering angle sensor - removal​
Steering angle sensor - setting​
Steering angle sensor - writing​
7. HVAC
7B. Heater Ventilator Airconditioner​
A_C compressor (4HK1) - installation​
A_C compressor (4HK1) - removal​
A_C compressor (4JZ1) - installation​
A_C compressor (4JZ1) - removal​
A_C compressor (RZ4E) - installation​
A_C compressor (RZ4E) - removal​
A_C compressor drive belt(4HK1) - inspection​
A_C compressor drive belt(4HK1) - installation​
A_C compressor drive belt(4HK1) - removal​
Air mix door - installation​
Air mix door - removal​
Blower - installation​
Blower - removal​
Blower module - inspection​
Blower module - installation​
Blower module - removal​
Blower motor - inspection​
Blower motor - installation​
Blower motor - removal​
Condenser - installation​
Condenser - removal​
Condenser fan - inspection​
Condenser fan - installation​
Condenser fan - removal​
Control panel - inspection​
Control panel - installation​
Control panel - removal​
Control panel - setting​
Evaporator core - installation​
Evaporator core - removal​
Expansion valve - installation​
Expansion valve - removal​
Heater core - installation​
Heater core - removal​
Heater evaporator unit - installation​
Heater evaporator unit - removal​
Inside and outside air filter - installation​
Inside and outside air filter - removal​
Intake actuator - installation​
Intake actuator - removal​
Intake door - installation​
Intake door - removal​
Mix actuator - installation​
Mix actuator - removal​
Mode actuator - installation​
Mode actuator - removal​
Mode door - installation​
Mode door - removal​
Pressure switch - inspection​
Pressure switch - installation​
Pressure switch - removal​
Receiver dryer - installation​
Receiver dryer - removal​
Vent grille (center and driver side) - installation​
Vent grille (center and driver side) - removal​
Vent grille (passenger side) - installation​
Vent grille (passenger side) - removal​
Ventilation duct - installation​
Ventilation duct - removal​
7Z. HVAC Control​
A_C control unit - installation​
A_C control unit - removal​
A_C control unit - setting​
Inside air temperature sensor - inspection​
Inside air temperature sensor - installation​
Inside air temperature sensor - removal​
Outside air temperature sensor - inspection​
Outside air temperature sensor - installation​
Outside air temperature sensor - removal​
Sun sensor - inspection​
Sun sensor - installation​
Sun sensor - removal​
8. Restraints
8B. Airbag Systems​
Driver airbag - installation​
Driver airbag - removal​
Driver airbag - scrapping​
Passenger airbag - installation​
Passenger airbag - removal​
Passenger airbag - scrapping​
SRS coil - installation​
SRS coil - removal​
8C. Seat Belt Systems​
Buckle side driver seat belt - installation​
Buckle side driver seat belt - removal​
Buckle side passenger seat belt - installation​
Buckle side passenger seat belt - removal​
Front buckle side center seat belt - installation​
Front buckle side center seat belt - removal​
Front tongue side center seat belt - installation​
Front tongue side center seat belt - removal​
Rear buckle side center seat belt - installation​
Rear buckle side center seat belt - removal​
Rear buckle side seat belt - installation​
Rear buckle side seat belt - removal​
Rear tongue side center seat belt - installation​
Rear tongue side center seat belt - removal​
Seat belt with pretensioner - installation​
Seat belt with pretensioner - removal​
Seat belt with pretensioner - scrapping​
Seat belt without pretensioner - installation​
Seat belt without pretensioner - removal​
8Z. Seat Belt and SRS Airbag Electrical Control​
Satellite sensor - installation​
Satellite sensor - removal​
SRS control unit - installation​
SRS control unit - removal​
SRS control unit - setting​
9. Body, Cab, Accessories
9A. Lighting Systems​
Backup light bulb - installation​
Backup light bulb - removal​
Clearance light - installation​
Clearance light - removal​
Combination switch - inspection​
Combination switch - installation​
Combination switch - removal​
Daytime running light - installation​
Daytime running light - removal​
Dome light bulb - installation​
Dome light bulb - removal​
Door switch - inspection​
Door switch - installation​
Door switch - removal​
Fog light - installation​
Fog light - removal​
Front turn signal light - installation​
Front turn signal light - removal​
Hazard warning flasher switch - inspection​
Hazard warning flasher switch - installation​
Hazard warning flasher switch - removal​
Headlight - inspection​
Headlight - installation​
Headlight - removal​
Headlight leveling switch - inspection​
Headlight leveling switch - installation​
Headlight leveling switch - removal​
License plate light bulb - installation​
License plate light bulb - removal​
Rear combination light - inspection​
Rear combination light - installation​
Rear combination light - removal​
Rear fog light bulb - installation​
Rear fog light bulb - removal​
Rear turn signal light bulb - installation​
Rear turn signal light bulb - removal​
Roof-mounted clearance light bulb - installation​
Roof-mounted clearance light bulb - removal​
Side turn signal light - installation​
Side turn signal light - removal​
Tail stoplight bulb - installation​
Tail stoplight bulb - removal​
9B. Wiper, Washer Systems​
Headlight washer nozzle - installation​
Headlight washer nozzle - removal​
Washer motor - inspection​
Washer motor - installation​
Washer motor - removal​
Wiper arm - installation​
Wiper arm - removal​
Wiper blade rubber - installation​
Wiper blade rubber - removal​
Wiper linkage - installation​
Wiper linkage - removal​
Wiper motor - installation​
Wiper motor - removal​
9C. Electrical Control, Entertainment​
Accessory socket - installation​
Accessory socket - removal​
Antenna (GNSS antenna) - installation​
Antenna (GNSS antenna) - removal​
Antenna - inspection​
Antenna - installation​
Antenna - removal​
Battery equalizer - installation​
Battery equalizer - removal​
Battery equalizer - setting​
Battery sensor - installation​
Battery sensor - removal​
DCT emergency switch - inspection​
DCT emergency switch - installation​
DCT emergency switch - removal​
Door speaker - inspection​
Door speaker - installation​
Door speaker - removal​
DPD switch - inspection​
DPD switch - installation​
DPD switch - removal​
ecostop off switch and warm-up switch - inspection​
ecostop off switch and warm-up switch - installation​
ecostop off switch and warm-up switch - removal​
ESC OFF switch - inspection​
ESC OFF switch - installation​
ESC OFF switch - removal​
Front blind spot monitor OFF switch - inspection​
Front blind spot monitor OFF switch - installation​
Front blind spot monitor OFF switch - removal​
Heated seat switch - inspection​
Heated seat switch - installation​
Heated seat switch - removal​
Horn - inspection​
Horn - installation​
Horn - removal​
Horn switch - installation​
Horn switch - removal​
HSA OFF switch and LDWS switch - inspection​
HSA OFF switch and LDWS switch - installation​
HSA OFF switch and LDWS switch - removal​
Ignition switch - inspection​
Ignition switch - installation​
Ignition switch - removal​
iVST - installation​
iVST - removal​
iVST - setting​
Radio - installation​
Radio - removal​
Smoother emergency switch - inspection​
Smoother emergency switch - installation​
Smoother emergency switch - removal​
START ASSIST switch - inspection​
START ASSIST switch - installation​
START ASSIST switch - removal​
Steering wheel switch - inspection​
Steering wheel switch - installation​
Steering wheel switch - removal​
USB charger - installation​
USB charger - removal​
Variable PTO switch - inspection​
Variable PTO switch - installation​
Variable PTO switch - removal​
Warm up switch - inspection​
Warm up switch - installation​
Warm up switch - removal​
9E. Instrumentation, Driver Info​
Analog tachograph (wide cab) - installation​
Analog tachograph (wide cab) - removal​
Back buzzer - inspection​
Back buzzer - installation​
Back buzzer - removal​
Blind spot monitor indicator light - installation​
Blind spot monitor indicator light - removal​
DC-DC converter (ISS) (standard cab) - installation​
DC-DC converter (ISS) (standard cab) - removal​
DC-DC converter (ISS) (wide cab) - installation​
DC-DC converter (ISS) (wide cab) - removal​
Electronic inner mirror - inspection​
Electronic inner mirror - installation​
Electronic inner mirror - removal​
Instrument panel cluster - diagnostics​
Instrument panel cluster - installation​
Instrument panel cluster - removal​
Instrument panel cluster - setting​
Rearview camera - installation​
Rearview camera - removal​
Speakerphone - installation​
Speakerphone - removal​
Stereo camera - installation​
Stereo camera - removal​
Stereo camera - setting​
Stereo camera - writing​
9G. Hood, Fenders, Doors​
Cab back cover - installation​
Cab back cover - removal​
Engine under cover - installation​
Engine under cover - removal​
Front door (standard cab, wide cab) - disassembly​
Front door (standard cab, wide cab) - installation​
Front door (standard cab, wide cab) - reassembly​
Front door (standard cab, wide cab) - removal​
Front step - installation​
Front step - removal​
Mud valance cover - installation​
Mud valance cover - removal​
Rear door (standard cab, wide cab) - disassembly​
Rear door (standard cab, wide cab) - installation​
Rear door (standard cab, wide cab) - reassembly​
Rear door (standard cab, wide cab) - removal​
Rear mudguard - installation​
Rear mudguard - removal​
Rear step - installation​
Rear step - removal​
9H. Cab Structure​
Air outlet valve - installation​
Air outlet valve - removal​
Crush box(frame side) - installation​
Crush box(frame side) - removal​
Crush box(front cab mounting side) - installation​
Crush box(front cab mounting side) - removal​
Engine cover - installation​
Engine cover - removal​
Engine cover lock - installation​
Engine cover lock - removal​
Front bumper - disassembly​
Front bumper - installation​
Front bumper - reassembly​
Front bumper - removal​
Front panel - installation​
Front panel - removal​
Front side panel - installation​
Front side panel - removal​
Radiator grille - disassembly​
Radiator grille - installation​
Radiator grille - reassembly​
Radiator grille - removal​
9I. Seats​
Driver seat - disassembly​
Driver seat - installation​
Driver seat - reassembly​
Driver seat - removal​
Driver suspension seat - installation​
Driver suspension seat - removal​
Passenger seat (integrated type) - disassembly​
Passenger seat (integrated type) - installation​
Passenger seat (integrated type) - reassembly​
Passenger seat (integrated type) - removal​
Passenger seat (separate type) - disassembly​
Passenger seat (separate type) - installation​
Passenger seat (separate type) - reassembly​
Passenger seat (separate type) - removal​
Rear seat (stationary type) - installation​
Rear seat (stationary type) - removal​
9J. Security and Locks​
Cab external antenna - installation​
Cab external antenna - removal​
Cab internal antenna - installation​
Cab internal antenna - removal​
Electronic key - disassembly​
Electronic key - reassembly​
Electronic key - setting​
External buzzer - installation​
External buzzer - removal​
Front door lock (standard cab, wide cab) - installation​
Front door lock (standard cab, wide cab) - removal​
Key cylinder (standard cab, wide cab) - installation​
Key cylinder (standard cab, wide cab) - removal​
Rear door lock (standard cab, wide cab) - installation​
Rear door lock (standard cab, wide cab) - removal​
Receiver - installation​
Receiver - removal​
Steering lock - installation​
Steering lock - removal​
Steering lock - setting​
Transponder key - setting​
9L. Exterior, Interior Trim​
Back lower trim (standard cab) - installation​
Back lower trim (standard cab) - removal​
Back lower trim (wide cab) - installation​
Back lower trim (wide cab) - removal​
Front pillar trim cover - installation​
Front pillar trim cover - removal​
Head lining (crew cab) - installation​
Head lining (crew cab) - removal​
Head lining (single cab) - installation​
Head lining (single cab) - removal​
Header tray - installation​
Header tray - removal​
Instrument panel (standard cab) - disassembly​
Instrument panel (standard cab) - installation​
Instrument panel (standard cab) - reassembly​
Instrument panel (standard cab) - removal​
Instrument panel (wide cab) - disassembly​
Instrument panel (wide cab) - installation​
Instrument panel (wide cab) - reassembly​
Instrument panel (wide cab) - removal​
Rear pillar trim - installation​
Rear pillar trim - removal​
Reinforcement - installation​
Reinforcement - removal​
9M. Cab Mounting​
Cab - installation​
Cab - removal​
Cab lock - installation​
Cab lock - removal​
Cab lock switch - inspection​
Cab lock switch - installation​
Cab lock switch - removal​
Cab tilt stay - installation​
Cab tilt stay - removal​
Front cab mounting - installation​
Front cab mounting - removal​
Rear cab mounting (crew cab) - installation​
Rear cab mounting (crew cab) - removal​
Rear cab mounting (single cab) - installation​
Rear cab mounting (single cab) - removal​
9T. Glass, Windows, Mirrors​
Backlight glass - installation​
Backlight glass - removal​
Door mounted outside rearview mirror - disassembly​
Door mounted outside rearview mirror - installation​
Door mounted outside rearview mirror - reassembly​
Door mounted outside rearview mirror - removal​
Front door power window switch - inspection​
Front door power window switch - installation​
Front door power window switch - removal​
Front windshield glass - installation​
Front windshield glass - removal​
Mirror heater switch - inspection​
Mirror heater switch - installation​
Mirror heater switch - removal​
Rear door power window switch - inspection​
Rear door power window switch - installation​
Rear door power window switch - removal​
Remote control mirror switch - inspection​
Remote control mirror switch - installation​
Remote control mirror switch - removal​
9Z. Body, Cab, Accessories Electrical Control​
BCM - installation​
BCM - removal​
BCM - setting​
CAN converter control unit (FCG) (crew cab) - installation​
CAN converter control unit (FCG) (crew cab) - removal​
CAN converter control unit (FCG) (crew cab) - setting​
CAN converter control unit (FCG) (standard cab) - installation​
CAN converter control unit (FCG) (standard cab) - removal​
CAN converter control unit (FCG) (standard cab) - setting​
CAN converter control unit (FCG) (wide cab) - installation​
CAN converter control unit (FCG) (wide cab) - removal​
CAN converter control unit (FCG) (wide cab) - setting​
Central ECU - installation​
Central ECU - removal​
Central ECU - setting​
Central gateway control unit - installation​
Central gateway control unit - removal​
Central gateway control unit - setting​
ECall unit - installation​
ECall unit - removal​
ECall unit - setting​
I_O control unit - installation​
I_O control unit - removal​
I_O control unit - setting​
Illuminance sensor - inspection​
Illuminance sensor - installation​
Illuminance sensor - removal​
Image processing unit (driver monitor camera) - installation​
Image processing unit (driver monitor camera) - removal​
Image processing unit (driver monitor camera) - setting​
Information module - installation​
Information module - removal​
Information module - setting​
MAP unit - installation​
MAP unit - removal​
MAP unit - setting​
Radar sensor (cab back side) - installation​
Radar sensor (cab back side) - removal​
Radar sensor (cab back side) - setting​
Radar sensor (front) - installation​
Radar sensor (front) - removal​
Radar sensor (front) - setting​
Radar sensor (side) (turn signal light mounting) - installation​
Radar sensor (side) (turn signal light mounting) - removal​
Radar sensor (side) (turn signal light mounting) - setting​
Rear height sensor - inspection​
Rear height sensor - installation​
Rear height sensor - removal​
Wireless access module - installation​
Wireless access module - removal​
Wireless access module - setting​
