Hyundai Step 1 ( 2007) : Engine service
- Download this document, you need 400 Gallons
HYUNDAI MOTORS
Chonan Technical Service Training Center
407-7, Yongdu-Ri, Byungchon-Myun, Chonan-City,
Chungnam,330-863, Korea
TEL : 82-41-559-2960 FAX : 82-41-561-0584
Chapter 1. Inspection on the Vehicle
1. Vehicle identification number
2. Engine identification number
3. Engine oil inspection
4. Spark test
5. Injector operation test
6. Idle rpm inspection
7. Ignition timing inspection
8. Power balance test
9. Fuel pump operation test
10. Fuel pressure test
11. Cylinder compression test
Chapter 2. Cylinder Head
1. Valve clearance
2. MLA shim adjustment
3. Removing and tightening Cylinder head bolts
4. Tightening method
5. Measuring deformation of cylinder head
6. Checking the bending of the camshaft
7. Measuring the cam lift
Chapter 3. Timing System
1. Timing belt inspection
2. Cautions for Timing belt installation
Chapter 4. Crankshaft
1. Cautions for removing and tightening main bearing caps
2. Measuring crankshaft oil clearance
3. Measuring thrust bearing clearance (end play)
4. Checking the bending of the crankshaft
Chapter 5. Piston, Piston Ring and Cylinder
1. Measuring piston ring end gap
2. Measuring piston ring side clearance
3. Cautions for installation of piston ring
4. Measuring cylinder worn-out
Appendix 1
1. Vernier caliper usage
2. Micrometer usage
3. Dial gauge usage
4. Unit Symbol
5. Unit Conversion
Appendix 2
Practice sheets
4. Spark test
1. Valve clearance
Appendix 1
2. Micrometer usage
3. Dial gauge usage
4. Unit Symbol
5. Unit Conversion
Appendix 2
Practice sheets
T55D
- Huyndai I20 Workshop Manual
- [Hyundai Service Training] Engine D6CA
- Hyundai i10 Workshop Manual
- [MF] Hyundai Shop Manual - Global Service Way
- Hyundai Santafe 2006 Engine D4EB
- Hyundai CRDI Engine D4FA Technical Training
- Hyundai H100 Poter Grace Service Rus
- Hyundai Diesel Engine D4EA Shop Manual
- Hyundai I30-2007 Service Manual
- Hyundai Galloper Service Manual
- Hyundai CRDI D4FA Engine
- Hyundai Santa Fe DM 2013-2014 Service Manual ONLINE
- Hyundai Technical Service Training
- [Hyundai Training] Hyundai I30 Workshop Manual
- Hyundai CVVT Engine - Training Programe
