Rocketman
Well-Known Member
11
2,337
[Hyundai Service Training] Engine D6CA
Download this document, you need 1100 Gallons
File Type: Flash
Powertec engine mechanical system
EMS engine Managemewnt system
Troubleshooting
General
Outside feature
Engine line-up
Specification
Bolt tighenting torque
Structure
Valves and rocker arm
Camshatf sensor plate
Cylinder liner and piston
Flywheel and crankshaft positionm sensor
Electronic unit injector EUI
Oil filter and cooler
Turbo-Charger
Fuel pump and Filter
Installation
Timing gear assembly
Electronic Unit Injector E.U.I 2
Replaceing the nozzle tube
Air breating from fule line
Jake brake
Adjustment
Valve clearnce adjustment
Pre-strok of Electronic Unit Injector
Jake brake
