How to Use Bendix Acom Pro Virtual Truck Connection Function
The virtual truck feature is designed to show the vehicle diagnostic and repair capabilities of ACom PRO without having to be physically connected to a vehicle. Any calibrations,
configurations, testing, faults and functionality of ACom PRO in virtual truck are simulations. So here car-auto-repair.com show you guide on how to use Bendix Acom Pro virtual truck connection functions.
Procedures:
1.Select the F8 key or the Connect button on the main toolbar.
2.You will be prompted for the connection type. Select the Truck Simulators button.
3.Choose Virtual Truck from the Select Virtual or Demo Truck screen.
4.The application will enter a truck simulation mode allowing you to exercise application features for training and educational purposes.
5.The simulation will behave like a Heavy-Duty vehicle connection. The Vehicle Readiness, Fault Code Information and Key Data Points windows are displayed.
Initially, the top portion of the Vehicle Readiness window will indicate the gathering the vehicle’s information. Once all vehicle information has been retrieved, the health of the vehicle is displayed.
6.Explore Bendix® ACom® PRO™ Diagnostics features such as NextStep™ Bendix, Data
Monitor, Connector Info, Bus Statistics, Clearing Faults, as well as exercising bidirectional tests. These features will behave exactly as if you were connected to a normal Heavy-Duty vehicle connection.
7.Use the Simulator Controls to adjust wheel speeds, cycle ignition power, or perform other functions as instructed during some bi-directional tests. Click on the key to toggle the ignition state. Press and hold the Crank button to simulate engine cranking.
NOTE: The ability to initiate a Recording or Submit Warranty are not available when connected to a Virtual Truck.
8.Select the F8 key or the Disconnect button on the main toolbar to close the virtual truck simulation session.
Newest 2023 V1.2 JPRO Professional Heavy Truck Diagnostic Scanner Tool Noregon JPro DLA+ 2.0 Adapter Kit more informatiom please visit
Procedures:
- Full Software Volvo IMPACT 2011
- Volvo VCADS Pro V2 Full
- VCDS Lite 1.0 full
- VOLVO IMPACT 2015
- Download Cummins INCAL 04/ 2013 the newest
- Volvo VCADS Pro 2.3.500
- Tech Tool V2.01 FULL Installation
- Perkins SPI 2012A KG
- Volvo prosis 2013 full active
- Metafile for CUMMINS CALTERM
- Allison Doc 8 KG
- WABCO TEBS-E v2.0 Activation + PIN
- How to your ECM with Calterm III
- CAT SIS ET CBT 2012 Master Install
- DVD Software MAN MANTIS EPC Update 477 (02.2012)
