Master
Cleaner
720
4,280,278
DVD Software MAN MANTIS EPC Update 477 (02.2012)
Year / Date : 02.2012 Version : 477 Developer : Lexcom Language : Multilingual Medicine : Present OS : OS: XP, Vista, 7 (32-bit) Extras. Information : In order to remove the program must know the password "MADONNA". Description : Man Mantis electronic spare parts catalog presented spare parts for trucks, tractors, buses Man, engines MAN. The new version allows you to enter a full VIN cars on identification, but defines by VIN only model and date of issue. There is a search of figure by original number of a detail and list of automobiles, where the detail was applied, also replaced numbers of details both new and old. To search for a specific machine parts need to know VIN or precisely to know model, wheel formula, interaxial distance, suspension and cab, and the type and modification of the engine installed on the machine. Search by VIN in the program is implemented as follows. You may enter full VIN or to use with 4 till 6 symbols VIN to determine the type (up to five characters to enter the zero) and from 7 to 10 characters to define the chassis number, and you can choose the type and chassis number from the list of possible options. All other data to specify require search directly on the machine. Abbreviation MAN - means Machine Companies Augsburg and Nuremberg. The firm "MAN" is based in 1915 and is one of the largest manufacturers of vehicles, including buses and also components for their assembly (axles, transmissions, engines, cabins).
FIX Update expired
Solving the problem with the message "Update expired" and departure MANTIS.
You need to create simple. bat file
Open Notepad, copy the code:
Code:
@ ECHO OFF
set string =% Date%
Date 12/12/2006 @
C: \ MANTIS \ PROG \ MANStart.EXE "C: \ WINDOWS \ mantis.ini"
PING 1.1.1.1-n 1-w 6000> NUL
@ Date % string%
"File-> Save As ..."
File Type -> select all files
Filename, such as pointing Mantis.bat
MANTIS now run through the script Mantis.bat.
