Momed80
150
35,046
Hongqi Automotive H5 NEW Repair Manual 20230819
Brand: Hongqi
Type of Machine: Automotive
Type of Manual: Repair Manual
Model: Hongqi H5 NEW Automotive
Applicable Model: CA7151HA6T, CA7150HA6HEVT, CA7201HA6T, CA7181HA6T
Part Number: 20230819
Publication Date: 2022
Number of Pages: 4514 Pages
Foreword
Repair Manual Quality Report
Note
How to troubleshoot
Introduction
How to use this manual
VIN and serial number
Maintenance Operation Instructions and Precautions
Terminology in this manual
EMS (2.0 T and 1.8 T)
ECM
ECM assembly
Camshaft position sensor
Upstream oxygen sensor assembly
Downstream oxygen sensor
Electric accelerator pedal
Electronic throttle body assembly
Solenoid valve assembly
MAP/IAT sensor assembly
Knock sensor
Crankshaft position sensor
Engine mechanical system 2.0T and 1.8T
On-board inspection
V-ribbed belt
Engine assembly
ECM
EMS (1.5T)
ECM
ECM assembly
Knock sensor
Engine mechanical system 1.5 T
On-board inspection
V-ribbed belt
Engine assembly
ECM
EMS (HEV)
ECM
Lubrication system 1.5 T
On-board inspection
Oil and oil filter assembly
Variable displacement oil pump solenoid valve
Oil pressure sensor
Oil sump assembly
Piston cooling nozzle control valve
Lubrication system 2.0T and 1.8T
On-board inspection
Oil pressure sensor
Oil sump lower body assembly
Intake system 1.5 T and HEV
On-board inspection
Intake manifold assembly
Air cleaner assembly
Turbocharger pipeline
Turbocharger assembly
Intake system 2.0 T and 1.8 T
On-board inspection
Intercooler
Exhaust system 1.5T and HEV
On-board inspection
Catalytic converter weldment (exhaust manifold hot end assembly)
Muffler weldment (exhaust manifold cold end assembly)
Exhaust system 2.0T and 1.8T
On-board inspection
Starting system 1.5T
Starter assembly
Starting system 2.0T and 1.8T
Starter assembly
Ignition system 1.5T
Ignition coil assembly
Spark plug assembly
Ignition system 2.0T and 1.8T
Spark plug assembly
Cooling system 1.5T and HEV
Coolant
Coolant temperature sensor assembly
Metal coolant pipe
Oil cooler assembly
Coolant pump assembly
Thermal management module assembly
Electric coolant pump assembly
Thermostat assembly
Cooling system 2.0 T and 1.8 T
Coolant
Metal coolant pipe
Radiator assembly
Oil cooler assembly
Expansion tank
Additional coolant pump assembly
Low-temperature cooling system
Coolant
Low-temperature coolant temperature sensor assembly
Low-temperature radiator
Low-temperature radiator water inlet pipe assembly
Coolant pipe under floor
Motor rear metal pipe assembly
Expansion tank
Metal water pipe I assembly
Emission control system
On-board inspection
Activated carbon canister assembly
Crankcase ventilation pipe
EVAP fuel leakage diagnosis module assembly
Desorption pipe and venturi valve & pressure sensor assembly
Fuel system
High-pressure fuel pump
Fuel rail
Fuel pump with fuel level sensor assembly
Fuel tank
Fuel filler pipe assembly
Charging system
Service switch
Dual USB charging port assembly
Cigarette lighter
DCDC assembly
On-board wireless charger assembly
Battery assembly
8G45B transmission control system
TCU
ATF
AT
AT assembly unit
CA7CM270D1 dual clutch transmission
TCU
TCU assembly
ATF
AT
AT assembly unit
ACM system
ACM
ACM
EGSM control system
EGSM
EGSM assembly
Supplemental restraint system
ACU assembly
Side curtain airbag assembly
Front seat airbag
Front passenger airbag assembly
Acceleration impact sensor assembly
Driver knee airbag
Driver airbag assembly
Rear seat airbag
Pressure side impact sensor assembly
Seat belt
Front seat belts
Rear seat belt
ATC system
ATC
Refrigerant
Front A/C control unit assembly
A/C filter element
Plasma generator assembly
Sunlight sensor assembly
Rain sensor assembly
Fragrance generator assembly
AQS assembly
PM2.5 sensor assembly
Inside temperature sensor assembly
Outside temperature sensor assembly
Compressor assembly
A/C pipeline
A/C condenser assembly
A/C air outlet assembly
Front HVAC Assembly
Front A/C air duct
ADV
ADV
Advanced ADV assembly
IFC
IFC
IFC
DCDC control system
DCDC control unit
DCDC assembly
High-voltage harness
DC bus high-voltage harness assembly
DMS
DMS
DMS
HCU
VCU
VCU
Motor control system
MCU
Electric drive system transmission fluid
BMS
BMU
Traction battery
Maintenance requirements
Scrapping
Traction battery assembly
Traction battery
Power steering system
Power steering
Double gear type electric power steering gear & tie rod assembly
Outer tie rod ball joint of electric power steering gear
Steering column system
Steering wheel
Steering column shroud
Steering column assembly
T-BOX
T-BOX
T-Box assembly
T-Box - Overseas
T-Box - Overseas
ETC system
ETC
ETC
Mobile phone wireless charging control system
WCM
BCM
BCM
BCM assembly
Door control system
Front left door control system
Front right door control system
Rear left door control system
Rear right door control system
Door control system (one-drive-two)
Brake control
ESC
ESC unit assembly
Front wheel speed sensor
Rear wheel speed sensor
Brake control (HEV)
IBC (HEV)
IBC assembly
Brake system
Brake fluid
Brake switch assembly
Brake pedal
Front brake disc
Front brake caliper assembly
Rear brake disc
Rear brake caliper assembly
Electric vacuum pump
Vacuum booster & master cylinder and reservoir assembly
Brake pipe assembly
Seat system
Driver seat control system
SCCU system
Front seat assembly
Rear seat
Lighting system
Light domain control unit
AFS
Lighting control unit assembly
AFS assembly
Front interior lamp assembly
Front combination lamp I assembly
Front combination lamp II assembly
Front combination lamp Ⅲ assembly
Vanity mirror lamp assembly
Rear interior lamp assembly
Rear combination lamp I assembly
Rear combination lamp II assembly
Trunk lamp assembly
Ride height sensor
Door lamp assembly
High-mounted stop lamp
Forward MMW radar system
Forward MMW radar
Forward MMW radar assembly
LCDA
Rear corner MMW radar
IVI
Front EnHost
Squawker and tweeter assembly
Front door speaker assembly
Main display assembly
IVI assembly
Power amplifier
Woofer assembly
HUD system
HUD
HUD
IPC
Instrument cluster
Instrument cluster
PDC
PDC
PDC assembly
Ultrasonic sensor assembly
PA
PA ECU
PA ECU assembly
Rear camera and bracket assembly
AVM
AVM ECU
AVM ECU assembly
IFC & bracket assembly
CAN communication system
GW
Central GW assembly
Suspension
Front wheel alignment
Hub bearing unit check
Front suspension
Rear wheel alignment
Rear suspension
Driving shaft
Front driving axle
Removal
Check
Installation
Instrument panel
Instrument panel assembly
Console assembly
Interiors
A, B, C, D pillar guard plates
Front door guard plate
Parcel shelf guard plate assembly
Rear door guard plate
Carpet and heat insulation pad
Trunk side covering
Sun visor assembly
Sill trim panel
Roof
Roof grab handle
Exterior
A pillar trim strip
Front bumper cover assembly
Fuel filler cap assembly
Engine hood heat insulation pad
Engine hood latch upper guard plate
Rear bumper cover assembly
Driver door trim cover assembly
Radiator grille assembly
Body bottom guard plate
Wheel guard
Door B pillar trim panel assembly
Sill trim panel
Door lock
Engine hood latch assembly
Trunk lid latch body assembly
Door handle assembly
Door lock assembly
Closure system
Front fender
Front door assembly
Front power window regulator assembly
Engine hood assembly
Rear door assembly
Rear power window regulator assembly
Trunk switch assembly
Trunk lid unlocking switch
Trunk lid
Door control system
Horn
Horn
Rearview mirror
Interior rearview mirror
Exterior rearview mirror
Sunroof
Sunroof
Anti-theft system
Interior antenna assembly
Exterior low frequency antenna
RF transmitter
PEPS low frequency antenna
ENGINE START/STOP button assembly
Smart key
Windshield and window
Front windshield assembly
Rear windshield assembly
Quarter window assembly
Wiper and washer
Front wiper blade
Front wiper arm
Front wiper motor linkage assembly
Washer fluid reservoir assembly
Washer fluid level sensor
Washer pump
Wheel
Wheel and tire
Tire pressure monitoring sensor
Glonass system
GLonass system switch assembly
Glonass system speaker assembly
Glonass system controller assembly
Appendix
Revision record table
