HINO Diagnostic eXplorer DX2 1.1.19.9 [2019] Unlocked Full + Instruction
- Download this document, you need 1500 Gallons
Size: 1.76gb (After install)
Region: All regions
Languages: English, Russian, Janpanese, Chinese, Spanish, Thai, French, Indonesian, Vietnamese
Win: Windows 7,Window 8, Window 10 (Test on window 7 untimate 64 bit)
Year: 2019
Version: 1.1.19.9
Type: Hino DX2 diagnostic program for trucks Hino
Diagnosis, Customization, Reprogramming, Simulation
Pass: After download send to email to get pass autorepairmanuals.ws@gmail.com
Before Run HinoDX you must switch-off internet connection or add to Host file follow strings:
127.0.0.1 hinogsps.com
127.0.0.1 http://hinogsps.com
127.0.0.1 https://hinogsps.com
Description : Hino DX2 diagnostic program for trucks Hino
- US markets, Japan, Russia and others
- RUS, DEF, JPN, USA , CAN, AUS, CHN, ESP, NZL, COL, CHL, HKG, TN, GBR, IRL, SGP, THA.
The program runs on any Windows.
BENEFITS TO HINO DX I Low speed HINO DX I in contact with large amounts of data, failure to extend the functionality of the software led to the need to develop a new diagnostic system.
From 2015 to diagnose HINO vehicles introduced to the work of the next generation system
- HINO Diagnostic eXplorer II (HINO DX II) ON THE ACTIVATION and updates to the PM !!!
Hino Explorer Diagnostic diagnostic software for Hino Trucks
The HINO Diagnostic eXplorer (hereafter referred to as HINO DX) is a tool equipped with all the functions needed to diagnose trouble, check functions, and configure the settings of the electronic systems built into HINO engines.
Main Functions
Acquires and deletes trouble data.
Links diagnostic trouble codes read from the ECU to corresponding diagnostic work flow sequences and directly displays the required data.
Obtains sensor conditions from the vehicle when trouble occurs (Freeze Frame function).
Monitors the sensors and actuators equipped on the engine (Data Monitor function) and tests the operation of solenoid valves by forcefully operating them (Active Test function).
Simulates diagnostic work with only a PC(Simulation function).
Automatically saves fetched ECU data and analyzes trouble based on the saved data even when the cause of trouble cannot be grasped.
Full Customization Capability
* Turn on Engine Protection Shutdown System
* Set Maximum Vehicle Speed
* Set Maximum Cruise Control Speed
* Set PTO idle speeds fixed and variable
* Change Injector Calibration QR Code when replacing injectors
* Supply Pump relearning when replacing SCV or supply pump
* Complete DPF testing and regeneration capabillity
* Built in Help Menus for troubleshooting specific diagnostics
Region: All regions
Year: 2019
Version: 1.1.19.9
Main Functions
- HINO Diagnostic eXplorer DX2 [10.2015] Unlocked Full + Instruction
- HINO Diagnostic eXplorer DX2 [2017] Unlocked Full + Instruction
- Hino Diagnostic Explorer 3.0 full
- Hino HIECHO-II EPC [09.2015] English + Instruction Manual
- Hino Diagnostic Explorer_3.0 full + How to install
- Hino Truck Full Set Manual DVD
- Hino Trucks / Buses HIECHO II Electronic Spare Parts Caralogue 2015
- HINO Diagnostic eXplorer DX2 [01.2016] Unlocked Full + Instruction
- HINO Trucks (LHD & RHD) Light Medium Heavy [01.2016]
- HINO Diagnostic eXplorer DX2 v1.1.18.6 [2018] Unlocked Full + Instruction
- HINO Truck 300 500 700 ML M XL Series Workshop Manual DVD New Update 2020
- HINO Truck Workshop Manuals [2001-2019] DVD
- Hino Truck Full Models 2000 - 2018 Wiring Diagrams DVD PDF
- Hino EPC Japan Trucks [02.2013] English/Japanese + Instruction
- HINO Diagnostic eXplorer DX2 [2019] Unlocked Full + Instruction
