HINO Diagnostic eXplorer DX2 [01.2016] Unlocked Full + Instruction
- Download this document, you need 3000 Gallons
Region: All regions
Languages: English
Win: Win7 x32, Win7 x64, Windows 8 x32
Year: 01.2016
Version: 1.1.16.1
Type: HINO Diagnostic eXplorer
Diagnosis, Customization, Reprogramming, Simulation
Pass: Thanks + PM Email "autorepairmanuals.ws@gmail.com"
Instruction:
1. Run "1.Hino_DX2_setup_v1.1.16.1" and waiting untill finish
2. In folder "For Users" Run "HINO_DX2_USER_CODE_p" and copy Code ID
3. Run "Lic Maker\HinoDX2_KG_p.exe", input ID and press "GO"
Send "regkey.dat" file to user
4. User must put "regkey.dat" file near "HINO_DX2_USER_ACT_p.exe"
5. User must run HinoDX on Desktop one time and close it.
6. User must run "HINO_DX2_USER_ACT_p.exe" and press "Activate"
7. Then HinoDX can be run
user: HINO
pass: HINO
Before Run HinoDX you must switch-off internet connection or add to Host file follow strings:
127.0.0.1 hinogsps.com
127.0.0.1 http://hinogsps.com
127.0.0.1 https://hinogsps.com
Hino Explorer Diagnostic diagnostic software for Hino Trucks
The HINO Diagnostic eXplorer (hereafter referred to as HINO DX) is a tool equipped with all the functions needed to diagnose trouble, check functions, and configure the settings of the electronic systems built into HINO engines.
Main Functions
Acquires and deletes trouble data.
Links diagnostic trouble codes read from the ECU to corresponding diagnostic work flow sequences and directly displays the required data.
Obtains sensor conditions from the vehicle when trouble occurs (Freeze Frame function).
Monitors the sensors and actuators equipped on the engine (Data Monitor function) and tests the operation of solenoid valves by forcefully operating them (Active Test function).
Simulates diagnostic work with only a PC(Simulation function).
Automatically saves fetched ECU data and analyzes trouble based on the saved data even when the cause of trouble cannot be grasped.
Full Customization Capability
* Turn on Engine Protection Shutdown System
* Set Maximum Vehicle Speed
* Set Maximum Cruise Control Speed
* Set PTO idle speeds fixed and variable
* Change Injector Calibration QR Code when replacing injectors
* Supply Pump relearning when replacing SCV or supply pump
* Complete DPF testing and regeneration capabillity
* Built in Help Menus for troubleshooting specific diagnostics
Region: All regions
Languages: English
Year: 01.2016
Version: 1.1.16.1
Instruction:
user: HINO
pass: HINO
Main Functions
- Hino Diagnostic Explorer 3.0 full
- HINO Diagnostic eXplorer DX2 [10.2015] Unlocked Full + Instruction
- HINO Diagnostic eXplorer DX2 [2017] Unlocked Full + Instruction
- Hino HIECHO-II EPC [09.2015] English + Instruction Manual
- Hino Diagnostic Explorer_3.0 full + How to install
- Hino Trucks / Buses HIECHO II Electronic Spare Parts Caralogue 2015
- Hino Truck Full Set Manual DVD
- HINO Trucks (LHD & RHD) Light Medium Heavy [01.2016]
- HINO Diagnostic eXplorer DX2 v1.1.18.6 [2018] Unlocked Full + Instruction
- Hino EPC Japan Trucks [02.2013] English/Japanese + Instruction
- Hino HIECHO-II EPC [08.2014] English + Installation
- HINO Trucks (LHD & RHD) Light Medium Heavy [05.2017]
- HINO Truck Workshop Manuals [2001-2019] DVD
- HINO Trucks (LHD & RHD) Light Medium Heavy [03.2016] Full Instruction
- HINO Diagnostic eXplorer DX2 [2019] Unlocked Full + Instruction
