Hyundai
86
178,785
Exeed E03 REEV 2025 Service Manual
Brand: Exeed
Type of Machine: Automotive
Model: Exeed E03 REEV 2025
Number of Pages: 5258 Pages
1 OVERVIEW
1.1 INTRODUCTION​
1 Foreword​
2 Information Description​
3 Maintenance Instruction​
4 Circuit Inspection​
5 ECU Troubleshooting​
6 Plastic Repair​
7 High Voltage Test and Repair​
8 High Voltage Maintenance Information​
1.2 MAINTENANCE AND REPAIR​
1 Maintenance​
2 Repair​
2 SQRH4J15 ENGINE
2.1 SQRH4J15 ENGINE ELECTRONIC CONTROL SYSTEM​
1 Warnings and Precautions​
2 System Overview​
3 Diagnostic Information​
4 Intake pressure/temperature sensor​
5 Electronic throttle​
6 Knock sensor​
7 Coolant Temperature Sensor​
8 Speed Sensor​
9 Phase Sensor​
10 Boost Pressure Sensor​
11 VVT Control Valve​
12 Fuel Rail Injector​
13 High Pressure Fuel Rail Pressure Sensor​
14 Canister Control Valve​
15 Engine Control Unit (ECU)​
2.2 SQRH4J15 ENGINE MECHANICAL SYSTEM​
2 System Overview​
3 Diagnosis & Testing​
4 Cylinder Head Cover​
5 Crankshaft Front Oil Seal​
6 Crankshaft Rear Oil Seal​
7 Flywheel​
8 Engine Timing Chain​
9 Camshaft and Rocker Arm​
10 Cylinder head​
11 Engine Assembly​
12 Cylinder Block Unit Repair​
2.3 SQRH4J15 ENGINE FUEL SUPPLY SYSTEM​
2 System Overview​
4 High Pressure Fuel Pipe​
5 High Pressure Fuel Pump, Roller Tappet​
6 Inlet pipe​
7 Fuel Filler Pipe​
8 Fuel Filler Cap Assembly​
9 Electric Fuel Pump Assembly​
10 Fuel Tank Assembly​
11 Fuel Rail Injector Assembly​
2.4 SQRH4J15 ENGINE EMISSION SYSTEM​
2 System Overview​
4 Canister Solenoid Valve​
5 Charcoal Canister Solenoid Valve Air Outlet Pipe​
6 Fuel Vapor Pipe Assembly​
7 Activated Charcoal Canister Assembly​
8 Upstream Oxygen Sensor​
9 Downstream Oxygen Sensor​
10 GPF Temperature Sensor​
11 Differential pressure sensor​
12 EGR System​
2.5 SQRH4J15 ENGINE INTAKE SYSTEM​
2 System Overview​
4 Air Filter Element (4WD Model)​
5 Air Filter Element (RWD Model)​
6 Air Direct Pipe Assembly​
7 Air Filter Assembly (4WD Model)​
8 Air Filter Assembly (RWD Model)​
9 Intake Hose Assembly​
10 Electronic Throttle Assembly​
11 Intercooler Assembly​
12 Intake Manifold Assembly​
13 Oil-gas Separator Assembly​
2.6 SQRH4J15 ENGINE EXHAUST SYSTEM​
2 System Overview​
4 Turbocharger Heat Insulator​
5 Intercooler Pipe​
6 Turbocharger Assembly​
7 Precatalytic Converter Assembly​
8 Front Muffler Assembly​
9 Rear Muffler Assembly​
10 Battery Quarter Heat Insulator​
2.7 SQRH4J15 ENGINE COOLING SYSTEM​
2 System Overview​
4 Coolant Replacement​
5 Water Side Thermal Management Module​
6 Cooling Fan Assembly​
7 Radiator Assembly​
8 Electric Water Pump Assembly​
9 Electronic Thermostat Assembly​
10 Engine Outlet Port Cover​
11 Water pipe​
2.8 SQRH4J15 ENGINE LUBRICATION SYSTEM​
2 System Overview​
4 Engine Oil Replacement​
5 Oil Filter​
6 Oil Pressure Sensor​
7 Oil Cooler Assembly​
8 Oil Pan​
9 Oil Pump Assembly​
2.9 SQRH4J15 ENGINE IGNITION SYSTEM​
2 System Overview​
4 Ignition Coil Assembly​
5 Spark Plug​
3 POWER SYSTEM
3.1 FRONT MOTOR CONTROL UNIT​
2 System Overview​
4 Motor control unit assembly​
5 Front MCU Power Cable​
3.2 Transmission Assembly​
2 System Overview​
4 Transmission oil​
5 Transmission Assembly​
6 Pressure Filter (Filter)​
7 Differential Oil Seal​
8 Input Flange Oil Seal​
9 Oil cooler​
3.3 Alternator Assembly​
2 System Overview​
4 Generator Oil​
5 Alternator Assembly​
6 Oil cooler​
7 Power battery two-phase cable wire harness​
3.4 power battery pack assembly​
2 System Overview​
3.5 Rear Electrical Drive Three-In-One Assembly​
2 System Overview​
4 Gearbox Oil​
5 Differential Oil Seal​
6 Rear MCU Power Cable​
7 Rear Electrical Drive Three-In-One Assembly​
8 Electric Oil Pump​
9 Oil cooler​
10 Electrical Drive Three-In-One Assembly Air Tightness Test​
3.6 CHARGING/DISCHARGING SYSTEM​
2 System Overview​
4 Diagnostic Information (EVCC)​
5 On-board Charger CDU Assembly​
6 DC Charging Wire Harness Assembly​
7 EVCC Assembly​
4 HEAT MANAGEMENT SYSTEM
4.1 COOLING/HEATING SYSTEM​
2 System Overview​
3 Draining and Adding Coolant​
4 Water Side Thermal Management Module​
5 Active Intake Grille Assembly​
6 Electric Water Pump Assembly​
7 Three-way water valve​
8 High Voltage Heater​
9 Coolant Temperature Sensor (Low Temperature Radiator Outlet Pipe)​
10 High Temperatures Radiator Assembly​
11 Low Temperature Radiator Assembly​
12 Cooling Fan Assembly​
4.2 Air conditioning system​
2 System Overview​
3 Refrigerant​
4 Refrigerant oil​
5 A/C Element​
6 Outside Temperature Sensor​
7 Electric compressor​
8 Electric A/C Wire Harness​
9 Fragrance Generator​
10 Rear A/C Control Panel Assembly​
11 Anion generator​
12 Condenser Assembly​
13 Automatic HVAC Assembly​
5 DRIVE TRAIN
5.1 DRIVE SHAFT​
2 System Overview​
3 Front Drive Shaft Assembly​
4 Rear Drive Shaft Assembly​
5 Rear Output Shaft Assembly​
6 BRAKE SYSTEM
6.1 BRAKE CONTROL SYSTEM​
2 System components diagram​
4 Front Wheel Speed Sensor​
5 Rear Wheel Speed Sensor with Caliper Wire Harness Assembly​
6 Brake switch​
7 Integrated Brake Controller Assembly​
8 Automatic Brake Pedal Assembly​
6.2 BRAKE​
2 System Overview​
3 FRONT BRAKE ASSEMBLY​
4 Front Brake Disc Assembly​
5 Front Brake Plate​
6 REAR BRAKE ASSEMBLY​
7 Rear Brake Disc Assembly​
8 Rear Brake Plate​
6.3 Parking Brake System​
2 System Overview​
4 Electronic Parking Controller Assembly​
7 SUSPENSION SYSTEM
7.1 SUSPENSION CONTROL SYSTEM​
2 System Overview​
4 Front Height Sensor Assembly​
5 Rear Height Sensor Assembly​
6 Front Body Acceleration Sensor Assembly​
7 Rear Body Acceleration Sensor Assembly​
8 Air suspension controller​
7.2 Front suspension (air suspension)​
2 System Overview​
3 On-vehicle inspection​
4 Front Upper Control Arm Assembly​
5 Lower Control Arm Assembly​
6 Front Lateral Stabilizer Bar Assembly​
7 Front Lateral Stabilizer Bar Connecting Rod​
8 Front shock absorber assembly​
9 Front Height Sensor Assembly​
10 CDC Wire Harness Bracket​
11 Body acceleration sensor assembly​
12 Front Air Hose I Assembly​
13 Front Air Hose II Assembly​
14 Front Hub Bearing​
15 Suspension​
16 Front Sub Frame Assembly​
7.3 AIR SUSPENSION (AIR SUSPENSION)​
2 System Overview​
4 Rear Upper Control Arm Assembly​
5 Rear Lower Control Arm Assembly​
6 Rear Trailing Arm Assembly​
7 Rear Pull Rod Assembly​
8 Rear control arm assembly​
9 Rear Lateral Stabilizer Bar Connecting Rod​
10 Rear Lateral Stabilizer Bar Assembly​
11 Rear Shock Absorber Assembly​
12 Rear Air Spring Assembly​
13 Air suspension controller​
14 Air Supply Unit Assembly​
15 Air Reservoir​
16 Rear Height Sensor Assembly​
17 Rear Left Air Hose Assembly​
18 Rear Right Air Hose Assembly​
19 Rear Hub Bearing​
20 Suspension​
21 Rear Sub Frame Assembly​
7.4 FRONT SUSPENSION​
2 System Overview​
5 Front Lower Control Arm Assembly​
6 Front Shock Absorber Assembly​
7 Front Lateral Stabilizer Bar Assembly​
8 Front Lateral Stabilizer Bar Connecting Rod​
9 Front Hub Bearing​
10 Front Sub Frame Assembly​
7.5 REAR SUSPENSION​
2 System Overview​
4 Rear Suspension Upper Control Arm​
5 Rear Suspension Lower Control Arm​
10 Rear Lateral Stabilizer Bar​
12 Rear Coil Spring​
13 Rear Hub Bearing​
14 Rear Sub Frame Assembly​
7.6 Four-wheel alignment​
1 System Overview​
2 Front Wheel Alignment​
3 Rear Wheel Alignment​
7.7 Tires/Wheels​
2 System Overview​
3 Wheel​
4 Wheel Bolt​
7.8 Tire Pressure Monitoring System (TPMS)​
2 System Overview​
3 Tire Pressure Sensor​
8 STEERING SYSTEM
8.1 POWER STEERING SYSTEM​
2 System Overview​
4 Steering Wheel Body​
5 STEERING COLUMN​
6 Steering Intermediate Shaft​
7 Electronic Power Steering Gear with Tie Rod Assembly​
8 Front Steering Knuckle Assembly​
9 Rear Steering Knuckle Assembly​
9 ELECTRICAL EQUIPMENT
9.1 BODY DOMAIN CONTROL MODULE​
2 System Overview​
3 Diagnostic Information (FLZCU)​
4 Diagnostic information (FRZCU)​
5 Left Zone Control Unit​
6 Electronic Accelerator Pedal Assembly​
7 Right Zone Control Unit​
9.2 ON-BOARD NETWORK SYSTEM​
1 On-board Network Overview​
2 LIN network​
3 CAN network diagnosis​
4 Ethernet (EHT) network diagnosis​
9.3 Power supply​
2 System Overview​
3 Battery Sensor​
4 Battery​
5 Battery positive fuse box​
6 Front compartment fuse and relay box assembly​
7 Instrument electrical box assembly​
8 Luggage Compartment Fuse and Relay Box​
9.4 VEHICLE DRIVING WARNING SYSTEM​
1 Description​
2 Exterior Speaker​
9.5 ANTI-THEFT/VEHICLE ENTRY/START SYSTEM​
2 System Overview​
3 Front Low Frequency Antenna​
4 High performance low frequency antenna​
5 Interior Low Frequency Antenna​
6 Rear Low Frequency Antenna​
9.6 INFORMATION AND ENTERTAINMENT SYSTEM​
2 System Overview​
4 Diagnostic Information​
5 Audio Head Unit Display​
6 Domain Controller Module​
7 Mid-range Speaker​
8 USB Charging Module​
9 USB charging module (SD card)​
10 USB Charging Module​
11 Tweeter​
12 Center speaker assembly​
13 Woofer​
14 Tweeter​
15 Center Speaker​
16 Roof Tweeter​
17 Surround Speaker​
18 Speaker Power Amplifier​
19 Subwoofer​
9.7 INFORMATION COMMUNICATION SYSTEM​
2 System Overview​
4 Information Communication Module​
5 Ecall Backup Power Supply​
6 GPS Antenna​
7 Plate Antenna​
8 Microphone​
9.8 Mobile phone wireless charging module​
1 System Overview​
2 Diagnostic Information​
3 Mobile phone wireless charging module​
9.9 HUD Head Up Display​
2 System Overview​
4 HUD Head Up Display​
9.10 Instrument Cluster​
2 System Overview​
4 Instrument Cluster​
9.11 Combination switch​
1 System Overview​
9.12 Airbag​
2 System Overview​
4 Frontal Collision Sensor Assembly​
5 Side Collision Sensor Assembly​
6 Side Pressure Collision Sensor Assembly​
7 Driver Airbag Assembly​
8 Front Passenger Airbag Assembly​
9 Left Curtain Shield Airbag Assembly​
10 Front Seat Side Airbag Assembly​
11 Airbag Controller Assembly​
10 ASSIST DRIVING SYSTEM
10.1 AUTOMATIC DRIVING COMPUTING CENTER​
2 System Overview​
3 Diagnostic Information (Bosch)​
4 Diagnostic information (HOLO)​
5 Automatic Driving Controller (BOSCH)​
6 Automatic Driving Controller (HOLO)​
10.2 Millimeter Wave Corner Radar Module​
2 System Overview​
4 Microwave wave corner radar​
10.3 Long Distance Ultrasonic Radar Module​
2 System Overview​
4 Long Distance Ultrasonic Sensor​
5 Ultrasonic Controller​
10.4 Camera Module​
2 System Overview​
4 front panoramic camera​
5 Side Camera​
6 Rear panoramic camera​
7 Multi-function Front Camera​
8 Front driving camera​
9 Side front view camera​
10 Side rear view camera​
11 Rear surrounding view camera​
12 Driver Monitoring Camera​
13 Passenger Monitoring Camera​
10.5 High Precision Positioning Module​
3 High Precision Positioning Module​
11 INTERIOR
11.1 INTERIOR LIGHTING​
1 System Overview​
2 Front Interior Dome Light Assembly​
3 Rear Interior Dome Light Assembly​
4 Glove box light​
5 Luggage Compartment Light Assembly​
6 Vanity mirror light​
11.2 Inside Rear View Mirror​
1 System Overview​
2 Inside Rear View Mirror Assembly​
11.3 BACKUP POWER SUPPLY SOCKET​
1 BACKUP POWER SUPPLY SOCKET​
11.4 SEAT​
1 System Overview​
2 Driver Seat​
3 Rear Seat Cushion Assembly​
4 Rear Seatback Assembly​
11.5 Seat belt​
2 System Overview​
4 Front seat belt assembly​
5 Rear Seat Belt Assembly​
6 Front seat belt buckle assembly​
7 Double buckle/small buckle assembly​
11.6 Instrument panel/auxiliary fascia console​
1 System Overview​
2 Auxiliary Fascia Console Assembly​
3 Instrument Panel Body Assembly​
4 Auxiliary Fascia Console Assembly​
5 Glove box​
6 Instrument Panel Crossmember Assembly​
11.7 A/B/C-pillar Trim Panel​
1 System Overview​
2 A-pillar trim panel assembly​
3 B-pillar trim panel assembly​
4 C-pillar Trim Panel Assembly​
11.8 Roof​
1 System Overview​
2 Sun visor​
3 Passenger grip (if equipped)​
4 Roof Assembly​
11.9 Carpet​
1 System Overview​
2 Front carpet​
3 Rear carpet​
11.10 Tonneau Cover Assembly​
1 System Overview​
2 Tonneau Cover Assembly​
12 EXTERIOR
12.1 LIGHTING SYSTEM​
2 System Overview​
5 Diagnostic Information​
6 Front Position Light​
7 Front left interactive signal indicator​
8 Left headlight assembly​
9 Rear Combination Light (Fixed) Assembly​
10 Back Door Combination Light Assembly​
11 Third Stop Light Assembly (With Spoiler)​
12 Third Stop Light Assembly (Without Spoiler)​
13 License Plate Light Assembly​
14 Rear Left Retro-reflector​
12.2 Outside Rear View Mirror​
1 System Overview​
2 Left Outside Rear View Mirror​
12.3 Wiper/Washer​
1 System Overview​
2 Front Wiper Drive System Assembly​
3 Front Main Wiper Arm​
4 Front Sub Wiper Arm​
5 Front Main Wiper Blade​
6 Front Sub Wiper Blade​
7 Washer Fluid Reservoir​
8 Washer Pipeline​
9 Front Washer Nozzle​
10 Combination Switch Assembly​
12.4 Horn​
1 System Overview​
2 High Pitched Horn Assembly​
3 Low Pitched Horn Assembly​
12.5 DOOR​
2 System Overview​
4 Front door assembly​
5 Front Left Door Protector Body​
6 Front Left Door Electric Switch​
7 Front Left Power Door Actuator Assembly​
8 Front Door Stopper Assembly​
9 Front Door Seal​
10 Rear door assembly​
11 Rear Left Door Protector Body​
12 Rear Left Door Power Switch​
13 Rear Left Power Door Actuator Assembly​
14 Rear Door Check Assembly​
15 Rear Door Weatherstrip​
12.6 Door lock​
1 System Overview​
2 Front Left Door Lock Assembly​
3 Front Left Outside Handle Assembly​
4 Front Left Door Lock Cylinder​
5 Side Door Lock Striker​
6 Rear Left Door Lock Assembly​
7 Rear Left Outside Handle Assembly​
12.7 Window, glass regulator​
1 System Overview​
2 Front Left Side Door Glass Assembly​
3 Front Left Rope-wheeled Glass Regulator Assembly​
4 Front Left Door Weather Bar​
5 Driver Glass Regulator Switch​
6 Rear Left Side Door Glass Assembly​
7 Rear Left Rope-wheeled Glass Regulator Assembly​
8 Rear Left Door Weather Bar​
9 Rear Left Door Glass Regulator Switch Assembly​
10 Front Windshield Assembly​
11 Panoramic Sunroof Glass Assembly​
12 Rear Windshield Assembly​
13 Rear Left Quarter Window Assembly​
12.8 Luggage Compartment Door​
1 System Overview​
2 Luggage Compartment Door Assembly​
3 Luggage Compartment Door Trim Board Assembly​
4 Luggage Compartment Emergency Opening Method​
5 Self-engage Luggage Compartment Lock Assembly​
6 Back Door Switch Assembly​
7 Back Door Closed Switch​
8 Back Door Upper Trim Panel Assembly (Without Spoiler)​
9 Back Door Upper Trim Panel Assembly (With Spoiler)​
10 Spoiler Assembly​
11 Electric Spoiler Mechanism Assembly​
12 Luggage Compartment Door Left Hinge Seat Assembly​
13 Luggage Compartment Door Weatherstrip​
14 Luggage Compartment Baffler Plate​
15 Back Doorsill Pressure Plate Assembly​
16 Rear Floor Cushion​
17 left luggage compartment wheel house assembly​
18 Left Electric Support Assembly​
19 Tension Spring Assembly​
12.9 Engine Hood​
1 System Overview​
2 Front Compartment Cover Assembly​
3 Front Compartment Cover Left Gas Spring Assembly​
4 Front Compartment Cover Hinge Assembly​
5 Front Windshield Lower Trim Panel​
6 Engine Hood Sound Insulator​
7 Adjustable Buffer Block​
8 Front Compartment Cover Weatherstrip​
9 Engine Hood Lock Assembly​
10 Front Compartment Cover Lock Cable Assembly​
11 front compartment trim cover assembly​
12.10 Front Bumper​
1 System Overview​
2 Front Bumper Upper Trim Panel​
3 Front Bumper Upper Mounting Panel​
4 Front Bumper Assembly​
5 Front Bumper Bracket​
6 Front Impact Beam Assembly​
7 Lower Impact Beam Assembly​
12.11 Rear Bumper​
1 System Overview​
2 Rear Bumper Body Assembly​
3 Rear Bumper Left Mounting Bracket​
4 Rear Impact Beam Assembly​
12.12 Exterior​
1 System Overview​
2 Front Left Wheel House Protector Assembly​
3 Front Left Quarter Trim Strip Assembly​
4 Lidar guard​
5 Roof guard​
6 Front Left Door Trim Strip Assembly​
7 Left Skirt Protector​
8 Left Quarter B Pillar Trim Panel​
9 Rear Left Wheel House Protector Assembly​
10 charging port cover assembly​
11 front chassis protector​
12 Left Chassis Protector​
13 rear chassis protector​
14 Rear Left Suspension Bottom Protector​
12.13 Vehicle Signs​
1 System Overview​
2 Left Wing Trim Name Plate​
3 ES signage​
13 Sheet Metal/Paint
13.1 Information and Repair of Plastic Panel​
2 System Overview​
3 Inspection and Adjustment​
13.2 Paint​
1 Surface Treatment​
2 Paint Coating Description​
3 Corrosion​
4 Cavity Sealant​
5 Sealant​
6 Painting Galvanized Sheets​
13.3 Body Dimensions​
1 Body Dimensions​
2 Lifting and Fixing Points​
3 Body Gap Dimensions​
13.4 Sheet Metal​
1 Safety Reminder Description​
2 Standard Description for Maintenance​
3 Instructions for Body Repair Tools​
4 Body Structure​
5 Primer​
6 Cutting​
7 Allowable Joint Positions​
8 Description of Welding​
9 Front Impact Beam Body​
10 Front Bumper Crossmember Left Mounting Panel Assembly​
11 Rear Impact Beam Body​
12 Left Wing Body​
13 Front Left Wing Front Mounting Bracket, Left Wing Middle Bracket​
14 Left Wing Upper Bracket, Left Wing Middle Bracket​
15 Left Wing Lower Bracket​
16 Front Roof Beam Inner Panel​
17 Front Roof Beam Reinforcing Panel​
18 Middle Roof Beam Inner Panel​
19 Middle Roof Beam Reinforcing Panel​
20 Left Quarter Outer Skin Assembly​
21 Center Part of Front Left Wheel House Upper Reinforcement Beam Outer Panel Assembly​
22 Left Door Ring Reinforcing Panel Assembly​
23 Rear Left Side Beam Reinforcing Panel​
24 Left Doorsill Rear Connecting Panel Assembly​
25 Parcel Rack Beam Assembly​
26 Parcel Rack Assembly​
27 Rear Left Combination Light Upper Mounting Panel​
28 Rear Left Gutter Channel Body​
29 Rear Left Combination Light Mounting Panel Assembly​
30 Charging Port Box Assembly​
31 Rear End Outer Panel Assembly​
32 Rear End Inner Panel Assembly​
33 Front Part of Left Quarter Inner Panel Assembly​
34 Rear Part Of Left Quarter Inner Panel Assembly​
35 Left Doorsill Inner Panel Assembly​
36 Rear Part of Left Doorsill Inner Panel Assembly​
37 Front Left Riser Assembly​
38 Front Windshield Lower Crossmember Assembly​
39 Front Left Side Rail Wheel House Assembly​
40 Front Baffle Crossmember Assembly​
41 Front Cowl Assembly​
42 Front Floor Assembly​
43 Rear Floor Crossmember Assembly​
44 Rear Left Rail Assembly​
