Yanmar Engine TNE Series 2TNE68 to 4TNE94 Application Manual HINSHI-H9003 1997
Brand: Yanmar
Type of Manual:
Model: Yanmar TNE Series 2TNE68 to 4TNE94 Application Manual HINSHI-H9003 1997.pdf Engine
Part Number: Yanmar Engine TNE Series 2TNE68 to 4TNE94 Application Manual HINSHI-H9003 1997
Publication Date:
Number of Pages: 342 Pages
Cover
Foreword
Contents
1. Tne Engine Application Standard
1-1 Application Standard
1-2 Special Operating Environment
1-3 Startability
1-4 Allowable Depression At Engine Manifold And Exhaust Back Pressures
2. Engine Model Selection
2-1 Model Designation
2-2 Applicable Driven Machine By Engine Classification
2-3 Rated Output Table
3. Specifications
3-1 Atmospheric Conditions Of Engine Output
3-2 Specifications, Performance And Dimensions
4. Output Corrections
4-1 Output Corrections
4-2 Atmospheric Pressure Calculation For Change In Altitude
4-3 Atmospheric Temperature Calculation For Change In Altitude
4-4 Relationships Among Altitude, Atmospheric Pressure And Atmospheric Temperature
4-5 How To Obtain Relative Humidity By Dry And Wet Bulb Thermometer
4-6 Relationships Between Atmospheric Temperature And Saturation Vapor Pressure
4-7 Characteristics At High Altitude
5. Performance
5-1 Performance Curves
5-2 Partial Recovery Ratio
5-3 Governor Performance
6. Cold Starting Aids
6-1 Glow Plug
6-2 Air Heater
6-3 Block Heater
7. Air Intake System
7-1 Air Capacity Required For Combustion
7-2 Air Cleaner
7-3 Piping Of The Air Intake System
7-4 Depression At Engine Manifold
7-5 Ventilation Capacity Of Generator Room
8. Exhaust System
8-1 Exhaust Back Pressure
8-2 Exhaust Silencer
8-3 Precautions For Exhaust System Fitting
8-4 Exhaust Gas Volume And Exhaust Back Pressure
9. Cooling System
9-1 Cooling System Diagram
9-2 Engine Cooling Water
9-3 Antifreeze, Rust Preventive And Descaling Agents
9-4 Radiator
9-5 Cooling Water Piping
9-6 Thermostat
9-7 Cooling Water Temperature Switch
9-8 Subtank
9-9 Heat Release To Cooling Water
9-10 Discharging Cooling System
10. Fuel System
10-1 Fuel System Diagram
10-2 Diesel Fuel Oil
10-3 Filtration System
10-4 Fuel Tank
10-5 Fuel Feed Pump
10-6 Precautions Concerning Fuel System
11. Lubricating System
11-1 Lubricating System Diagram
11-2 Lubricating Oil
11-3 Lubricating Oil Pump
11-4 Lubricating Oil Filtering System
11-5 Oil Pan
11-6 Inclined Performance
11-7 Breather System
11-8 Lubricating Oil Pressure Switch
12. Matching Test Procedure
12-1 Purpose Of Matching Test
12-2 Required Items To Be Prepared For Test
12-3 Measuring Instruments Mounting Instructions
12-4 Preparation For Matching Test Operation
12-5 Heat Balance Test
12-6 Output Matching Test
12-7 Installation State Check
12-8 Various Forms Required For Matching Test
13. Electrical System
13-1 Starting Motor
13-2 Charging Generator
13-3 Regulator
13-4 Battery
13-5 Wiring
14. Power Systems
14-1 Caution For Direct Coupling
14-2 Caution For Side Load
14-3 Selection Of V-Belts
14-4 Allowable Side Load For Main P.T.O.
14-5 Allowable Side Load For Front P.T.O.
14-6 Cautions For Hydraulic Pump Drive P.T.O.
15. Vibration Isolation Device
15-1 Principle Of Vibration Isolation
15-2 Calculation Of Rubber Isolator
15-3 Vibration Isolation Materials
16. Torsional Vibration
16-1 What Is Torsional Vibration?
16-2 Torsional Vibration Of Multi-Cylinder Engine
16-3 Actual Processing For Torsional Vibration
16-4 Avoidance And Suppression Of Torsional Vibration
16-5 Torsional Vibration Equivalent Vibration System
17. Reference Materials For Engineering Calculation
17-1 Principle Conversion Table For The Engine Specifications
17-2 Fuel Tank Holding Time
17-3 Oil Pan Holding Time
17-4 Mean Piston Speed
17-5 Total Displacement
17-6 Torque
17-7 Net Mean Effective Pressure
17-8 Fuel Injection
17-9 Cyclic Irregularity(Or Coefficient Of Speed Fluctuation)
17-10 Thermal Efficiency And Heat Loss
17-11 Generator
17-12 Hydraulic Pump(Gear)
17-13 Water Pump Driving Horsepower(Required Horsepower)
17-14 Form Characteristics Of Cooling Fan
17-15 Mesh Number And Size Of Mesh
17-16 Centigrade-Fahrenheit Temperature Conversion
17-17 Hill Climbing Horsepower And Allowable Climbing Angle
18. Conversion Factors
Brand: Yanmar
Type of Manual:
Publication Date:
Cover
Foreword
Contents
1-3 Startability
3. Specifications
5. Performance
6-1 Glow Plug
6-2 Air Heater
6-3 Block Heater
7-2 Air Cleaner
8. Exhaust System
9. Cooling System
9-4 Radiator
9-6 Thermostat
9-8 Subtank
10. Fuel System
10-4 Fuel Tank
10-5 Fuel Feed Pump
11-5 Oil Pan
13-1 Starting Motor
13-3 Regulator
13-4 Battery
13-5 Wiring
14. Power Systems
17-6 Torque
17-8 Fuel Injection
17-11 Generator
- Doosan Operation and Maintenance Manual Diesel Engine DB58, DB58S, DB58T ,DB58TI , DB58TIS
- Error codes doosan
- Doosan DX225LCA Operation and Maintenance Manual
- Doosan Diesel Engine Workshop Manual
- Doosan Diagnostic Software DMS+E-DOCTOR+CALBRATION INJECTOR DOC
- Doosan DX225LC Shop Manual
- Daewoo Doosan Solar 140LC-V Excavator Service Shop Manual
- Doosan Wheel Excavator ZF 2HL100 Transmission
- Doosan Maintenance Manual Diesel Engine DE12,DE12T,DE12TI,DE12TIS
- Doosan Common Rail Engines DL06,DL08 & DV11 Service Training
- Daewoo Doosan DB58,DB58T & DB58TI Diesel Engine Shop Manual
- Doosan E Doctor + Installation Manual
- Doosan DX140W/DX160W Operation and Maintenance Manual
- Doosan G424 Gasoline,LP Engine G424 LP Engine (Low Emission Version) G20E-3,G25E-3,G30 Service Manua
- Doosan MST M542 Spare Part Catalogue
