zizouhiche
Well-Known Member
44
4,281
Doosan Diagnostic Software DMS+E-DOCTOR+CALBRATION INJECTOR DOC
DMS
This program supplies following functions by carrying out the communication with the e-EPOS controller installed to an excavator and IBM interchangeable PC of a user.
n Monitoring : Monitors the current information/data which e-EPOS controller has.
n Graph : Shows the major sensor data of excavator as a graph, and can save the data to the hard disc, making it possible to check the status of the excavator by analyzing and comparing.
n Test : Carry out various simulation by activating the output signal from e-EPOS controller by force
n Diagnosis : Shows current failure information and past ones which e- EPOS controller has.
n History : enables to analyze the working trend or style, which shows the operating hours as per each work mode and used hours of filter & oil.
e - Doctor
Show to the user the engine failure status, history and trouble shooting manual : ‘Fault codes’.
- View monitored engine’s components working behavior & value of critical parameters :
‘Service Data’ / ‘Snap shot’.
- Save engine data for checking engine condition : ‘Service Data’ / ‘Snap shot’.
- Check power deviation between cylinders : ‘Run-up Test’.
- Check compression deviation between cylinders : ‘Compression Test’.
- Check an engine’s behavior to a set of simulated sensor inputs from the laptop : ‘Remote Control’.
CALIBRAT DATA AND DOCUMENT INJECTOR
