Momed80
150
35,046
Yanmar Engine 3TNV 4TNV Series 3TNV82A to 4TNV106T Service Manual M9961-02E050
Brand: Yanmar
Model: Yanmar 3TNV 4TNV Series Engine
3TNV82A, 3TNV84, 3TNV84T, 4TNV84, 4TNV84T, 3TNV88, 4TNV88, 4TNV94L, 4TNV98, 4TNV98T, 4TNV106, 4TNV106T
Part Number: M9961-02E050
Number of Pages: 213 Pages
Cover
1. General
1.1 Engine Nomenclature
1.2 Specifications
1.3 Fuel Oil, Lubricating Oil And Coolant Water
1.4 Engine External Views
1.5 Structural Description
1.6 Exhaust Gas Emission Regulation
2. Inspection And Adjustment
2.1 Periodic Maintenance Schedule
2.2 Periodic Inspection And Maintenance Procedure
2.3 Adjusting The No-Load Maximum Or Minimum Speed
2.4 Sensor Inspection
2.5 Water Leak Check In Cooling Water System
2.6 Radiator Cap Inspection
2.7 Thermostat Inspection
2.8 Adjusting Operation
2.9 Long Storage
3. Troubleshooting
3.1 Preparation Before Troubleshooting
3.2 Quick Reference Table For Troubleshooting
3.3 Troubleshooting By Measuring Compression Pressure
4. Disassembly, Inspection And Reassembly Of Engines
4.1 Complete Disassembly And Reassembly
4.2 Cylinder Head: Disassembly, Inspection And Reassembly
4.3 Gear Train And Camshaft
4.4 Cylinder Block
5. Lubrication System
5.1 Lubrication System Diagram
5.2 Trochoid Pump Components
5.3 Disassembly(Reverse The Procedure Below For Assembly)
5.4 Servicing Points
5.5 Parts Inspection And Measurement
6. Cooling System
6.1 Cooling Water System
6.2 Cooling Water Pump Components
6.3 Disassembly (Reverse The Procedure Below For Assembly)
6.4 Servicing Points
7. Fuel Injection Pump/Governor
7.1 Introduction
7.2 Fuel Injection Pump
8. Turbochager: Disassembly, Inspection And Reassembly
8.1 Structure And Functions
8.2 Service Standards And Tightening Torque
8.3 Periodic Inspection Procedure
8.4 Disassembly Procedure
8.5 Washing And Inspection Procedure
8.6 Reassembly Procedure
8.7 Handling After Disassembly And Reassembly
8.8 Troubleshooting
9. Starting Motor
9.1 For 4tnv94l/ 98
9.2 For 4tnv106(T)
10. Alternator
10.1 The 40a Alternator For 3tnv84 And Other Models
11. Electric Wiring
11.1 Electric Wiring Diagram
11.2 Precaution On Electric Wiring
12. Service Standards
12.1 Engine Tuning
12.2 Engine Body
12.3 Lubricating Oil System (Trochoid Pump)
13. Tightening Torque For Bolts And Nuts
13.1 Tightening Torques For Main Bolts And Nuts
13.2 Tightening Torques For Standard Bolts And Nuts
Back-Address
