White Tractor G1050 Parts Catalog R2193000
Brand: White
Model: White G1050 Tractor
Part Number: R2193000
Number of Pages: 169 Pages
Crankcase - For 504a-6 Lp Gas Engine
Crankcase (For 504a-6 Diesel Engine)
Gear Case And Water Pump
Base Pan, Oil Filter And Oil Pump
Cylinder Block, Cylinder Head, And Breather
Cylinder Block, Cylinder Head, Energy Cells And Breather
Camshaft, Rocker Arms, Valves, Push Rods, And Tappets
Crankshaft, Connecting Rod, Pistons, Rings And Flywheel
Gas Manifold And Muffler
Air Cleaner
Carburetor And Regulator (Lp Gas)
Lp Gas Fuel Tank, Valves And Filter
Roosa-Master Fuel Injection Pump
Turbocharger (For D504a-6 Engines)
Diesel Fuel Tank And Filter
Governor And Control Rod - Lp-Gas
Distributor, Ignition Coil, Cables And Sparks Plugs
Throttle Controls
Fan And Hub
Water Manifolds And Thermostat
Grille And Hood
Instrument Panel And Instruments
Alternator And Starting Motor
Lamps And Wires
Clutch And Ampli-Torc Brake
Upper Sliding Gear Shaft, Pinion And Reverse Gears
2-Speed Ampli-Torc Drive
3-Speed Ampli-Torc
Side Cover Assembly
Valve Body Assembly
Transmission Case
Gear Shifting
Rear Axle, Wheel Hub And Bull Gear
Rear Wheels (Tapered Hubs)
Brakes
Dual Rear Power Take-Off
Rear Power Take-Off (1000 Rpm)
Lube Pump - Rear - 2-Speed Ampli-Torc
Lube Pump - Rear - 3-Speed Ampli-Torc
Transmission Oil Filter And Lines - 3-Speed Ampli-Torc
Transmission Oil Cooler And Lines
Steering Shaft Housing
Power Steering Pump
Steering Wheel, Motor And Lines
Steering Motor (Not Illus.)
Type E Front Axle And Wheels (Heavy Duty)
Standard Front Axle
Seat And Underride
Wheel Guard And Platform
Wheel Guard Fuel Tanks
Closed Center Hydraulic Pump
Closed Center And Type G Hydraulic Reservoir And Lines
Closed Center Valve And Lever Housing
Closed Center Valve Linkage
Closed Center Console And Control Levers
Closed Center Auxiliary Valves And Couplers
Auxiliary Valves - Closed Center Hydraulic System
Control Valve And Couplers - Type G Hydraulic System
Auxiliary Valve
3-Point Hitch
3-Point Hitch Cylinders And Lines
Semi-Mounted Plow Hitch (Quick Coupler)
20 Degree Swinging Drawbar For 3-Point Hitch
Tool Box And Tools
30 Degree Swinging Drawbar
Decals, Medallion And Name Plates
Hydraulic Cylinder
Service Bulletin Tractors F-40-7 Cab Glass (9 27 74) - Service Bulletin Tractors F-40-7 Cab Glass (9 27 74) Service Information
Factory Installed Cab (Not Illus.)
Heavy Duty Alternator (Not Illus.)
