White Tractors 1600 Series Parts Catalog S1924
Brand: White
Type of Machine: Tractors
Model: White 1600 Series Tractors
Part Number: S1924
Number of Pages: 279 Pages
Group A - Front Main Frame (1600 Rc, Wht, Ind, Uty) (Serial
Group A - Emblem, Transfer Sets And Name Plate (Not
Group B - Cylinder Head Cover And Breather (Gas, Lpg, Dsl)
Group B - Rocker Arm And Push Rods (Gas, Lpg, Dsl) (Serial
Group B - Cylinder Head And Valves (Gas, Lpg, Dsl) (Serial
Group B - Crankcase (Gas, Lpg, Dsl) (Serial No. 124420-)
Group B - Crankshaft And Related Parts (Gas, Lpg, Dsl)
Group B - Camshaft (Gas, Lpg, Dsl) (Serial No. 124420-)
Group B - Oil Pan And Oil Pump (Gas, Lpg, Dsl) (Serial No.
Group B - Oil Filter (1600 Rc, Wht, Ind, Uty) (Serial No.
Group B - Manifold - Gas And Lp Gas (Gas, Lpg, Dsl) (Serial
Group B - Manifold - Diesel (Serial No. 124420-)
Group B - Manifold Preheater - Diesel (1600 Rd, Wht, Ind,
Group B - Muffler (1600 Rc, Wht, Ind, Uty) (Serial No.
Group B - Air Cleaner - Gas (1600 Rc, Wht, Ind, Uty) (Serial
Group B - Air Cleaner - Diesel (1600 Rc, Wht, Ind, Uty)
Group B - Precleaner Screener
Group B - Fuel System - Gas (1600 Rc, Wht, Ind, Uty) (Serial
Group B - Fuel System - Diesel (1600 Rc, Wht, Ind, Uty)
Group B - Primary Fuel Filter
Group B - Final Fuel Filter
Group B - Hand Primer Pump
Group B - Diesel Injection Pump, Injectors And Accessory
Group B - Diesel Fuel Injector
Group B - Fuel System - Lp Gas (1600 Rc, Wht, Uty)
Group B - Lp Gas Vaporizer
Group B - Lp Gas Filter
Group B - Governor Controls (1600 Rc, Wht, Ind, Uty)
Group B - Governor Controls - Gas And Lp Gas (1600 Rc,
Group B - Governor
Group B - Carburetor
Group B - Lp Gas Carburetor And Regulator
Group B - Governor Controls - Diesel (1600 Rc, Wht, Ind,
Group B - Ignition And Starter (1600 Rc, Wht, Ind, Uty)
Group B - Distributor
Group B - Generator
Group B - Starting Motor
Group B - Wiring And Clips (1600 Rc, Wht, Ind, Uty) (Serial
Group B - Water Pump, Fan And Fan Belt (1600 Rc, Wht, Ind,
Group B - Cooling System (1600 Rc, Wht, Ind, Uty) 1 Of 2
Group B - Cooling System (1600 Rc, Wht, Ind, Uty) 2 Of 2
Group B - Coolant Heater (1600 Rc, Wht, Ind, Uty) (Serial No.
Group C - Rear Main Frame (1600 Rc, Wht, Ind, Uty) (Serial
Group C - Transmission Pressure Lube System (1600 Rc, Wht,
Group C - Transmission Pressure Lube Pump
Group C - Transmission (1600 Rc, Wht, Ind, Uty) (Serial No.
Group C - Gear Shift (1600 Rc, Wht, Ind, Uty) (Serial No.
Group C - Brake Controls - Regular (1600 Rc, Wht, Ind, Uty)
Group C - Brake Controls - Reverse-O-Torc (1600 Ind) (Serial
Group C - Brakes (1600 Rc, Wht, Ind, Uty) (Serial No.
Group C - Differential (1600 Rc, Wht, Ind, Uty) (Serial No.
Group C - Hydra-Power Drive (1600 Rc, Wht, Uty)
Group C - Hydra-Power Drive Oil Pump
Group D - Belt Pulley (Pto Driven) (1600 Rc, Wht, Uty)
Group E - Power Take-Off (1600 Rc, Wht, Ind, Uty) (Serial No.
Group E - Power Take-Off Clutch
Group F - Power Lift
Group F - Power Lift (A, E)
Group F - Power Lift - Row Crop, Wheatland And Industrial
Group F - Power Lift - Utility (A, E)
Group F - Power Lift (B, E)
Group F - Hydraulic Pump
Group F - Servo Valve
Group F - Flow Divider
Group F - Power Lift Cylinder, Hoses And Connections - Rear
Group F - Power Lift Cylinder, Hoses And Connections - Front
Group F - Power Lift Cylinder (3 Inch)
Group F - Power Lift Coupling
Group F - Power Lift Coupling (156309-As & 156310-As)
Group F - Power Lift Hydraulic Oil Cooler (1600 Rc, Wht,
Group H - Rear Wheels (1600 Rc, Wht, Ind, Uty) (Serial
Group I - Rear Wheel Rims (1600 Rc, Wht, Ind, Uty) (Serial
Group J - Rear Wheel Weights (1600 Rc, Wht, Ind, Uty) (Serial
Group L - Front Wheels (1600 Rc, Wht, Ind, Uty) (Serial
Group M - Front Wheel Rims (1600 Rc, Wht, Ind, Uty) (Serial
Group N - Front Wheel Weights (1600 Rc, Wht, Uty)
Group O - Lights (1600 Rc, Wht, Ind, Uty) (Serial Number
Group P - Drawbar (1600 Rc, Wht, Ind, Uty) (Serial Number
Group P - Three-Point Hitch (1600 Rc, Wht, Ind, Uty)
Group Q - Clutch (1600 Rc, Wht, Ind, Uty) (Serial Number
Group Q - Clutch Cover
Group Q - Reverse-O-Torc Drive (Ind) (Serial Number 124420-)
Group Q - Reverse-O-Torc Drive (1600 Ind) (Serial Number
Group Q - Forward And Reversing Gear
Group R - Rear Axle (1600 Rc, Wht, Ind, Uty) (Serial Number
Group S - Wheel Guards And Platforms (1600 Rc, Wht, Ind, Uty)
Group S - Wheel Guard Panels (1600 Wht)
Group S - Step (1600 Rc, Wht, Ind, Uty) (Serial Number
Group T - Seat (1600 Rc, Wht, Ind, Uty) (Serial Number
Group T - Seat Frame And Cushion
Group T - Seat Adjuster
Group T - Seat Suspension
Group T - Front Frame Weights (1600 Rc, Wht, Ind, Uty)
Group U - Manual Steering (1600 Rc, Wht, Ind) (Serial Number
Group U - Power Steering (1600 Rc, Wht, Ind, Uty) (Serial
Group U - Power Steering Hydromotor
Group U - Power Steering Pump
Group U - Manual Steering Mechanism - Dual Front Wheel
Group U - Power Steering Mechanism - Dual Front Wheel
Group U - Manual Steering Mechanism - Single Front Wheel
Group U - Power Steering Mechanism - Single Front Wheel
Group U - Manual Steering Mechanism - Adjustable Front Axle
Group U - Power Steering Mechanism - Adjustable Front Axle
Group U - Manual Steering Mechanism - Wheatland And
Group U - Manual Steering Gear (1ks-750-B & 1ks-750-C)
Group U - Power Steering Mechanism - Wheatland And Industrial
Group U - Power Steering Mechanism - Utility (1600 Uty)
Group U - Adjustable Front Axle (1600 Rc) (Serial Number
Group U - Front Axle - Wheatland And Industrial (1600 Wht,
Group U - Front Axle - Utility (1600 Uty) (Serial Number
Group W - Hood, Side Panel And Grille (1600 Rc, Wht, Ind Uty)
Group W - Instrument Panel (1600 Rc, Wht, Ind, Uty) (Serial
Group W - Instrument And Switches (1600 Rc, Wht, Ind, Uty)
Group W - Tachourmeter (1600 Rc, Wht, Ind, Uty) (Serial
Group X - Tool Box And Tools (1600 Rc, Wht, Ind, Uty)
Brand: White
Part Number: S1924
Group B - Governor
Group B - Generator
- White Articulated Tractor A4T 1400 A4T 1600 Series Parts Catalog PCR2214M
