White Tractor G1000 VISTA Parts Catalog R2154000
Brand: White
Model: White G1000 VISTA Tractor
Part Number: R2154000
Number of Pages: 147 Pages
Crankcase (For 504a-6 Lp Gas Engine)
Crankcase (For D504a-6 Diesel Engine)
Gear Case And Water Pump
Base Pan, Oil Filter And Oil Pump
Cylinder Block, Cylinder Head, And Breather
Cylinder Block, Cylinder Head, Engergy Cells And Breather
Camshaft, Rocker Arms, Valves, Push Rods, And Tappets
Crankshaft, Connecting Rod, Pistons, Rings And Flywheel
Gas Manifold And Muffler
Air Cleaner
Carburetor And Regulator (Lp-Gas)
Fuel Tank, Valves And Supports For Lp-Gas Tractors
Roosa-Master Fuel Injection Pump
Fuel Filter For Diesel Tractor
Governor And Control Rod
Throttle Lever And Linkage
Distributor, Ignition Coil, Cables And Spark Plugs
Hood And Grille
Fan And Hub
Water Manifolds And Thermostat
Instrument Panel And Instruments
Alternator And Starting Motor
Lamps And Wires
Clutch
Clutch Pedal And Linkage
Clutch Servo Valve
Clutch Booster Cylinder
Upper Sliding Gear Shaft, Pinion And Reverse Gears
Ampli-Torc Drive
Transmission Case
Gear Shifting
Console
Rear Axle, And Bull Gear
Brakes
Brake Pedals And Master Cylinders
Rear Power Take-Off
Lube Pump - Rear
Transmission Oil Filter, Cooler And Lines
Steering Gear Housing
Power Steering Pump
Steering Wheel And Motor
Steering Valve And Lines
Front Axle And Wheels For Type E Tractors
Type U Front Axle And Wheels
Standard Front Axle
Seat And Seat Suspension (Not Illustrated)
Seat Underride Support (Not Illustrated)
Wheel Guard And Platform
Hydraulic Oil Filter And Strainer Lines
Reservoir For Tractors With Tel-O-Flo Hydraulic System
Cylinder And Linkage
Valve Assembly For Tractors With Tel-O-Flo Hydraulic System
Controls And Linkage For Tractors
Hydraulic Levers And Linkage (Not Illustrated)
Depth Limit Control
3 Point Hitch For Tractors With Tel-O-Flo Hydraulic System
Remote Mounted Jack And Depth Stop
Tool Box And Tools (Not Illustrated)
20 Deg. Swinging Drawbar For 3-Point Hitch
Semi-Mounted Plow Hitch (Quick Coupler)
Decals, Medallion And Name Plates (Not Illustrated)
