White Tractor 950 990 995 Series Parts Catalog S1912000
Brand: White
Model:
White 950 Series Tractor
White 990 Series Tractor
White 995 Series Tractor
Part Number: S1912000
Number of Pages: 239 Pages
Drawbar (Standard) (S N 530001 -)
Drawbar (Heavy Duty) 950, 990, 995 (S N 530001 -)
Seat 950, 990 (S N 530001 -)
Seat 950, 990, 995 (S N 530001 -)
Wheel Guards And Platform 950, 990, 995
Hood (S N 530001 -)
Front Frame And Bolster (S N 530001 -)
Emblem, Transfer Sets And Name Plate
Engine, 990 And 995 (S N 530001 -)
Cylinder Head Cover And Rocker Arms
Cylinder Head And Valves
Crankcase (S N 530001 -)
Crankshaft And Related Parts (S N 530001 -)
Oil Filter (S N 530001 -)
Oil Pan And Oil Pump (Model 950 Hc And Diesel) (S N 530001-)
Camshaft (Model 950 Hc And Diesel) (S N 530001-)
Governor Controls 950 (S N 530001 -)
Governor Controls 990 And 995 (S N 530001 -)
Foot Accelerator 950, 990, 995 (S N 530001 -)
Instruments And Switches (950, 990, 995) (S N 530001 -)
Puncturing Tool
Primer Pump
Tachourmeter
Air Cleaner And Connections 950 (S N 530001 -)
Air Cleaner And Connections 990 And 995
Air Cleaner 990 And 995
Precleaner Screener
Manifold - Hc 950 (S N 530001 -)
Carburetor
Manifold Diesel (S N 530001 -)
Muffler
Governor And Linkage, 950 Hc (S N 530001 -)
Fuel Tank , Tubing And Connections 950 (S N 530001 -)
Fuel Supply Pump
Diesel Fuel Filters 950 (7as-841 And 7as-841-A)
Fuel Tank, Tubing And Connections 990 And 995
First Stage Fuel Filter 990 And 995
Heavy Duty Auxiliary Fuel Filter And Connections 990 And 995
Diesel Injection Pump, Injectors And Accessory Drive
Fuel Injector - Diesel
Ignition And Starter
Distributor
Generator
Generator Hc And Diesel
Starting Motor Hc
Starting Motor - Diesel
Lights - 950, 990, 995
Wiring, Clips And Grommets 950, 990, 995
Water Pump, Fan And Fan Belt 950, 990, 995
Radiator And Connections 950 (S N 530001 -)
Radiator And Connections 990, 995 (S N 530001 -)
Foot Clutch And Controls
Clutch Cover
Hand Clutch And Controls
Torque Converter, Clutch And Controls 995
Torque Converter
Rear Frame And Covers 950, 990, 995
Transmission 950, 990, 995
Shifter Mechanism And One Lever Gear Shift 950, 990, 995
Two Lever Gear Shift 950, 990, 995
Differential And Brakes 950, 990, 995 (S N 530001 -)
Brake Controls 950, 990, 995 (S N 530001 -)
Rear Axle 950, 990, 995
Steering Gear And Connections 950, 990, 995 (S N 530001 -)
Steering Gear
Power Steering - 950, 990, 995 (S N 530001 -)
Power Steering Pump
Power Steering Valve
Power Steering Cylinder
Front Axle 950, 990, 995 (S N 530001 -)
Front Wheels 950, 990, 995 (S N 530001 -)
Depth Control Hydraulic System
Depth Control Hydraulic Unit
Hydraulic Lock Valve
Depth Control Hydraulic Cylinder
Depth Control Breakaway Coupling
Non-Depth Control Hydraulic System 950, 990, 995
Non-Depth Control Hydraulic Pump
Non-Depth Control Hydraulic Valve
Non-Depth Control Hydraulic Cylinder
Non-Depth Control Breakaway Coupling
Hydra-Electric And Hydraulic System (S N 80826 -)
Hydra-Lectric And Hydraulic Unit (S N 80826 -)
Hydra-Lectric Cylinder
Hydraulic Cylinder
Breakaway Coupling
Belt Pulley 950, 990, 995 (S N 530001 -)
Power Take-Off 950, 990, 995 (S N 530001 -)
Power Take-Off Clutch
Rear Wheels 950, 990, 995 (S N 530001 -)
Rear Wheel Rims 950, 990, 995 (S N 530001 -)
Rear Wheel Weights 950, 990, 995 (S N 530001 -)
Tool Box 950, 990, 995 (S N 530001 -)
