White Tractor 66 Super 66 660 Series Parts Catalog S1970000
Brand: White
Model: 66 Super, 66 Series, 660 Series
Part Number: S1970000
Number of Pages: 2322 Pages
Drawbar
Wheel Guards And Extensions
Hood, Side Doors And Rear Panel
Front Frame
Name Plate And Transfers (Not Illus.)
Cylinder Head And Valve Mechanism
Crankcase (Hc & Kd)
Crankshaft And Related Parts
Oil Pan And Oil Pump
Camshaft
Engine Controls And Instruments
Hour Meter
Tachourmeter
Air Cleaner
Air Cleaner - Hc
Air Cleaner - Diesel
Precleaner Screener
Manifold Preheater
Carburetor (Schebler)
Carburetor (Zenith)
Carburetor (Carter)
Manifold
Governor
Fuel Tank, Tubing And Conections
Diesel Injection Pump, Nozzles And Accesory Drive
Starter And Lighting Equipment
Ignition And Light Wires (Not Illus.)
Clips, Clamps, And Covers (Not Illus.)
Grommets (Not Illus.)
Distributor
Generator (Hc & Kd)
Generator (Diesel)
Generator (Hc & Diesel)
Starting Motor (Hc & Kd)
Starting Motor - Hc
Starting Motor (Diesel)
Starting Motor - Diesel
Radiator And Connections
Radiator Shutter
Clutch And Clutch Controls
Transmission, Rear Frame And Platform
Transmission Gear Shift
Differential, Brake And Brake Controls
Rear Axle
Torque Converter And Reversing Gear (Reverse-O-Torc)
Reversing Gear
Steering Wheel And Shafts
Front Steering Mechanism
Front Axle (Standard And Industrial)
Front Wheels
Four Wheel Adjustable Tread (Row Crop)
Single Front Wheel (Manual Steering)
Single Front Wheel (Power Steering)
Power Steering Gear
Power Steering Hydraulic Pump And Reservoir
Mechanical Power Lift
Hydra-Lectric Lift (Hyra-Lectric 2 Cyl. And 1 Cyl.)
Hydra-Lectric Cylinder
Hydra-Lectric Hand Switch
Hydra-Lectric And Hydraulic Reservoir And Selector Valve
Hydra-Lectric And Hydraulic Pump
Hydra-Lectric And Hydraulic Cylinders And Hose Connections
Hydra-Lectric Wiring Harness
Hydraulic Cylinder
Hydra-Lectric And Hydraulic Breakaway Coupling
Hydra-Lectric And Hydraulic Basic Unit (Unit S N 70001 -)
Belt Pulley
Power Take-Off
Power Take-Off Speed Conversion Unit
Power Take-Off Clutch
Three-Point Hitch
Hydra-Hitch
Lugs
Extension Rims
Rear Wheel Weights
Tools And Tool Box
Supplement For 660 Diesel Tractors - Crankcase
Supplement For 660 Diesel Tractors - Crankshaft And
Supplement For 660 Diesel Tractors - Engine Controls And
Supplement For 660 Diesel Tractors - Fuel Tank, Tubing And
Supplement For 660 Diesel Tractors - Primary Fuel Filter
Supplement For 660 Diesel Tractors - Final Fuel Filter
Supplement For 660 Diesel Tractors - Diesel Injection Pump
Supplement For 660 Diesel Tractors - Starter And Lighting
