White Tractor 6215 Parts Catalog 79016359
Brand: White
Model: White 6215 Tractor
Part Number: 79016359
Number of Pages: 491 Pages
Publication Information
Engine - Engine Frame & Mounting, Prior S N 602301
Engine - Engine Frame & Mounting, Eff. S N 602301
Engine - Accessory Drive Pulley
Engine - Front Gear Cover
Engine - Rocker Lever
Engine - Cylinder Block
Engine - Crankshaft & Main Bearings, Crankshaft
Engine - Crankcase Breather
Engine - Heater Coolant
Engine - Vibration Damper
Engine - Front Gear Train Accessory Drive
Engine - Fuel Drain Location, Prior Eng S N 45318311
Engine - Fuel Drain Location, Eff. Eng S N 45318311
Engine - Alternator, Brace
Engine - Alternator, Supports & Mounting
Engine - Alternator - Location, Eff. Eng S N 45318311
Engine - Alternator, Belt & Tensioner
Engine - Alternator - Drive, Eff. Eng S N 45318311
Engine - Mechanical Tach Drive Cover
Engine - Fan Drive
Engine - Fan Drive, Eff. Eng S N 45318311
Engine - Air Fuel Control Plumbing, Prior Eng S N 45318311
Engine - Air Fuel Control Plumbing, Eff. Eng S N 45318311
Engine - Fuel Filter
Engine - Fuel Inlet Tube, Prior Eng S N 45318311
Engine - Fuel Inlet Tube, Eff. Eng S N 45318311
Engine - Flywheel And Flywheel Housing
Engine - Fuel Pump Coupling, Prior Eng S N 45318311
Engine - Fuel Pump Coupling, Eff. Eng S N 45318311
Engine - Fuel Pump, Prior Eng S N 45318311
Engine - Fuel Pump, Eff. Eng S N 45318311
Engine - Fuel Lift Pump
Engine - Fuel Plumbing
Engine - Fuel Shutoff Valve, Prior Eng. S N 45318311
Engine - Fuel Shutoff Valve, Eff. Eng. S N 45318311
Engine - Injection Pump Supply
Engine - Lifting Bracket
Engine - Engine Oil Cooler
Engine - Oil Level Gauge
Engine - Lubricating Oil Pump
Engine - Cylinder Block Cover
Engine - Oil Pan
Engine - Piston And Connecting Rod
Engine - Camshaft
Engine - Fuel Injector
Engine - Fuel Injector, Service Items
Engine - Cylinder Head
Engine - Turbocharger
Engine - Starting Motor Mounting
Engine - Debris Shield, Front Crank Oil Seal
Engine - Turbocharger, Exhaust Manifold & Air Tubes, Prior
Engine - Turbocharger, Exhaust Manifold & Air Tubes, Eff.
Engine - Thermostat Housing
Engine - Turbocharger Plumbing, Eff. Eng. S N 45318311
Engine - Valve Cover
Engine - Valve Cover Hardware
Engine - Aftercooler, Prior Eng. S N 45318311
Engine - Aftercooler, Eff. Eng. S N 45318311
Engine - Aftercooler Plumbing
Engine - Corrosion Resistor
Engine - Block Vent Plumbing
Engine - Water Inlet Connection
Engine - Water Outlet Connection
Engine - Water Pump
Engine - Exhaust Connection
Engine - Service Gasket Set
Engine - Service Gasket Set, Upper Engine Set, .15mm Over
Engine - Service Gasket Set, Upper Engine Set, .50mm Over
Engine - Service Gasket Set, Lower Engine Set
Engine - Service Gasket Set, Upper Engine Set, Standard
Engine - Service Gasket Set, Upper Engine Set, .25mm Over
Engine - Fan, Radiator And Hoses, Prior S N 602301
Engine - Fan, Radiator And Hoses, Effective S N 602301
Intake And Exhaust - Air Cleaner
Intake And Exhaust - Air Cleaner Components
Intake And Exhaust - Heat Shield
Fuel System - Ether Cold Starting, Prior S N 602301
Fuel System - Ether Cold Starting, Eff 6215 S N 602301
Fuel System - Fuel Lines & Fittings, Prior 6215 S N 602301
Fuel System - Fuel Lines & Fittings, Effective S N 602301
Fuel System - Fuel Tank - Main, Prior S N 602301
Fuel System - Fuel Tank - Main, Eff S N 602301
Fuel System - Fuel Tank - Auxiliary
Fuel System - Throttle Controls, Foot Throttle
Fuel System - Throttle Controls, Engine, Prior To S N 602301
Fuel System - Throttle Controls, Engine, Eff. S N 602301
Electrical And Instruments - Alternator, Starting Motor And
Electrical And Instruments - Starting Motor, 37 Mt, Components
Electrical And Instruments - Step & Battery Box
Electrical And Instruments - Radar Speed Sensing Gun
Electrical And Instruments - Transmission & Rear Frame Wiring
Electrical And Instruments - Headlights & Grille
Electrical And Instruments - Lights - Field & Rear
Electrical And Instruments - Auxiliary Light Connector
Electrical And Instruments - Cab Electrical System
Electrical And Instruments - Instrument Panel
Electrical And Instruments - Right Hand Instruments & Gauges
Electrical And Instruments - Left Hand & Lower Instrument
Electrical And Instruments - Radio, Speakers & Antenna
Electrical And Instruments - 3 P.H. Controls
Electrical And Instruments - Sensor & Mounting
Electrical And Instruments - Pfa Diff-Lock Enhancement
Electrical And Instruments - Creeper Gear Controls
Electrical And Instruments - Connectors
Transmission - Housing
Transmission - Housing Assembly - Front
Transmission - Housing Assembly - Center
Transmission - Housing Assembly - Rear
Transmission - Gear Ratio
Transmission - Clutch Assembly - 2nd
Transmission - Clutch Assembly - 3rd
Transmission - Clutch Assembly - 4th
Transmission - Clutch Assembly - 6th
Transmission - Clutch Assembly - 7th
Transmission - Clutch Assembly - 8th
Transmission - Electric Valve
Transmission - Electric Valve - Components
Transmission - Solenoid Assembly
Transmission - Group Pump, Shaft
Transmission - Creeper Drive
Transmission - Planet Asy. 1st & 2nd Stage, Creeper Drive
Transmission - 2nd Stage, Creeper Drive
Transmission - 1st Stage, Creeper Drive
Transmission - Transmission Filter & Lines
Transmission - Thermal Bypass Valve Components
Transmission - Oil Cooler And Mounting, Prior S N 602301
Transmission - Oil Cooler And Mounting, Eff S N 602301
Transmission - Oil Cooler Lines And Fittings, Prior 6215 S N
Transmission - Oil Cooler Lines And Fittings, Eff. 6215 S N
Transmission - Rear Housing
Transmission - Sump Box
Transmission - Pinion Shaft
Transmission - Controls, Brake & Clutch Pedals
Transmission - Controls, Shift Lever & Throttle
Transmission - Controls, Park Lock Lever & Linkage
Transmission - Brakes
Transmission - Brakes, Valve & Lines, Type I, Prior 602321
Transmission - Brakes, Valve & Lines, Type Ii, Eff. S N
Transmission - Brakes, Valve Components, Prior S N 602321
Transmission - Brakes, Valve Components, Eff. S N 602321
Transmission - Trailer Braking
Transmission - Differential & Differential Lock
Transmission - Rear Axle & Planetary
P.T.O. - Drive Shaft, Clutch & Brake, Prior Rear Axle S N
P.T.O. - Drive Shaft, Clutch & Brake, Eff. Rear Axle S N
P.T.O. - 1000 Rpm
P.T.O. - 1000 Rpm, Eff. Rear Axle S N Dbfc605
P.T.O. - Pto & Differential Lock Valve, Controls & Lines
P.T.O. - Pto & Differential Lock Valve, Valve Components
Hydraulics - Hydraulic Housing & Cover
Hydraulics - Cover And Lines Electric, Eff. S N 602001
Hydraulics - Hydraulic & Lube Charge Pump
Hydraulics - Oil Filter
Hydraulics - Pump, Pressure Control Valve & Lines
Hydraulics - Pump Components
Hydraulics - Pressure Control Valve Components
Hydraulics - Servo Valve, Control Lever & Linkage, Prior S N
Hydraulics - Servo Valve Components
Hydraulics - Remote Valve, Control Levers & Linkage, Prior
Hydraulics - Remote Valve, Control Levers & Linkage, Eff. S N
Hydraulics - Remote Valve Lines And Fittings, Eff. S N
Hydraulics - Remote Valve Lines And Fittings, Eff. S N 602349
Hydraulics - Remote Valve, With Lockout
Hydraulics - Remote Valve - 4th, Prior S N 602001
Hydraulics - Remote Valve - 4th, Eff. S N 602001
Hydraulics - Remote Valve Components
Hydraulics - Valve Components - Draft Control
Hydraulics - Remote Hydraulic Lever, Couplings, Cylinders &
Hydraulics - Remote Hydraulic Lever, Coupling Components
Hydraulics - Lift Cylinder, 4-1 2 X 8-1 2, Rosenboom
Hitch, Lift And Drawbar - Three Point Hitch, Draft Sensitive
Hitch, Lift And Drawbar - Three Point Hitch, Draft Sensing
Hitch, Lift And Drawbar - Three Point Hitch, Rockshaft, Lift
Hitch, Lift And Drawbar - Three Point Hitch, Category Iii
Hitch, Lift And Drawbar - Quick Hitch, Category Iii & Iii-N
Hitch, Lift And Drawbar - Drawbar
Power Steering - Steering Column And Pedal Support
Power Steering - Control Unit And Lines, Prior S N 602301
Power Steering - Control Unit And Lines, Eff. S N 602301
Power Steering - Control Unit Components
Power Steering - Cylinder & Lines - Pfa, Prior S N 602301
Power Steering - Cylinder & Lines - Pfa, Eff S N 602301
Power Steering - Cylinder Components - Pfa
Power Steering - Cylinder Componenets, Eff.
Power Steering - Axle And Support - Pfa
Power Steering - Clutch Assembly - Pfa
Power Steering - Drive Shaft - Pfa, Prior S N 602301
Power Steering - Drive Shaft - Pfa, Eff. S N 602301
Power Steering - Differential Carrier, Ring Gear & Pinion
Power Steering - Limit Slip Differential
Power Steering - Axle - Housing, Shaft & Tie Rod
Power Steering - Joint Housing & Steering Arm
Power Steering - Wheel Hub, Spindle & Planetary Drive
Wheels - Wheels - Front
Wheels - Rear Wheels
Wheels - Rear Wheels, Dual
Frame Attachments - Tool Box
Frame Attachments - Front Weights
Frame Attachments - Rear Wheel Weights
Body - Hood, Prior S N 602301
Body - Hood, Eff. S N 602301
Body - Hood Latch, Eff. S N 602359
Body - Side Panels, Prior S N 602301
Body - Side Panels, Eff S N 601501
Body - Side Panels, 4wd, Eff S N 602301
Body - Firewall, Prior S N 602301
Body - Firewall, Eff S N 602301
Body - Fenders - Rear
Body - Front Fenders
Cab - Cab Body
Cab - Interior Trim And Sound Barriers
Cab - Door, Prior S N 601512
Cab - Door, Eff. S N 601512
Cab - Windows, Rh Side & Rear
Cab - Cab Glass Specifications
Cab - Floormats And Instructor's Seat
Cab - Console - Rh, Prior S N 602001
Cab - Console - Rh, Eff. S N 602001
Cab - Cab Mounting
Cab - Mirrors, Outside Cab
Cab - Windshield Wiper
Cab - Wiper Washer Rear
Cab - Air Ride Seat & Suspension, Seat
Cab - Air Ride Seat & Suspension, Cushions And Armrest
Cab - Air Ride Seat & Suspension, Bease And Suspension, Prior
Cab - Air Ride Seat & Suspension, Base And Suspension, Eff.
Cab - Air Conditioner, Evaporator & Heater Housing
Cab - Cab Heater
Cab - Cab Blower
Cab - A C Condenser Receiver Drier
Cab - Cab Air Conditioner, Compressor, Clutch & Pulley
Recommended Dealer Stock
