White Tractor 6085 Parts Catalog 79014895
Brand: White
Model: White 6085 Tractor
Part Number: 79014895
Number of Pages: 548 Pages
Publication Form Number
Engine - Crankcase
Engine - Timing Case
Engine - Front Cover
Engine - Crankshaft, Pistons And Rods
Engine - Pulleys, Engine Shaft
Engine - Crankshaft With Balancing Gear
Engine - Camshaft
Engine - Cylinder Head
Engine - Oil Pan And Filter
Engine - Oil Cooler
Engine - Oil Pump And Drive
Engine - Breather And Lines
Engine - Breather, Components
Engine - Turbocharger Lube Lines
Fuel System - Fuel Injector, Pump And Lines
Fuel System - Fuel Pump, Filter And Regulator
Fuel System - Regulator Components
Fuel System - Regulator Controls
Fuel System - Injector Components
Fuel System - Fuel Pump Components
Fuel System - Fuel Filter Components
Fuel System - Fuel Supply Lines And Sediment Bowl
Fuel System - Sediment Bowl Components
Fuel System - Fuel Injector Pump Components
Fuel System - Injection Pump Components
Fuel System - Thermo Starter, Eff. S N 1460
Engine Cooling - Water Pump And Fan
Engine Cooling - Water Manifold
Air Intake And Exhaust - Manifolds
Air Intake And Exhaust - Muffler
Clutch - Clutch Assembly-Organic 12 , Prior S N 1005
Clutch - Clutch Asssembly - Cera-Metallic 12 , Eff. S N 1005
Clutch - Clutch - Cera-Metallic 13 , Eff. S N 1431
Clutch - Clutch Control
Clutch - Clutch Throw-Out
Clutch - Cylinder Components
Clutch - Clutch Master Cylinder Components
Transmission - Gearbox
Transmission - Gearbox Support
Transmission - P.T.O. Bearing Lube Line, Upper Rear
Transmission - Reverse Gear
Transmission - Reverse Gear Shift Rail And Fork
Transmission - Reverse Gear Controls
Transmission - Hi-Lo, 30 X 30
Transmission - Hi-Lo Shift Rail And Fork, 24 X 12
Transmission - Main Shaft
Transmission - Internal Gear Control-Rails & Forks
Transmission - Gear Control - Lever & Linkage
Transmission - Synchropower Controls
Transmission - Transmission - W O Synchropower
Transmission - Cover - Gearbox W O Synchropower
Transmission - Transmission - With Synchropower
Transmission - Synchropower Hi-Lo
Transmission - Housing - Synchropower Hi-Lo
Transmission - Synchropower W Mechanical Controls
Transmission - Syncropower W Hydraulic Controls
Transmission - Hi-Lo Gears
Transmission - Creeper Gear
Transmission - Reducer Controls
Transmission - Reducer Shift Lever
Transmission - Differential
Transmission - Differential Lock Control-Mechanical
Transmission - Differential Lock Control Linkage -,
Transmission - Differential Lock Control, Electrohydraulic
Transmission - Rear Axle Housing
Transmission - Rear Axles And Planetary Reductions
Brakes - Rear Brakes
Brakes - Independent Hand Brake
Brakes - Brake Controls
Brakes - Brake Cylinder Components
Brakes - Hand Brake
Brakes - Pedal Support
Frame - Front Support, 2 Wd
Frame - Front Support, 4 Wd
Clutch - Clutch Housing
Front Axle - Adjustable Axle - 2wd
Power Steering - Power Steering Cylinder - 2wd
Power Steering - Power Steering Cylinder Components
Front Axle - Front Axle - 4wd, Prior Axle S N 5651
Front Axle - Front Axle-4wd, Eff. Axle S N 5651
Brakes - Front Brake Lines - 4wd
Brakes - Front Brake - 4wd
Power Steering - Power Steering Cylinder - 4wd
Power Steering - Power Steering Cylinder Components, 4wd
Power Steering - Power Steering Cylinder Components, With
Power Steering - Power Steering Cylinder - 4wd, Oversize With
Front Axle - Front Differential Lock - 4wd
Front Axle - Differential Lock Control - Mechanical
Front Axle - Electronic Front Differential, Locking Control
Front Axle - Front Axleshafts And Planetary, 4wd
Front Axle - Differential Lock Control-Front, Mechanical -
Front Axle - Transmission Shaft - 4wd
Front Axle - 4wd - Mechanical
Front Axle - Control - 4wd
Front Axle - Electronic Control - 4wd
Front Axle - Electronic Control Valve - 4wd, Prior
Front Axle - Front Differential Cylinder Supply Line, Prior
Front Axle - Front Differential Cylinder Supply Lines,
P.T.O - Clutch Input And Pto Shaft, Without Synchropower
P.T.O - Clutch Imput And Pto Shaft, With Synchropower
P.T.O - Hydraulic Clutch Components, With Mecanical Controls
P.T.O - Hydraulic Clutch Components, With Electrohydraulic
P.T.O - Hydraulic Clutch Control, Mechanical Controls
P.T.O - Hydraulic Clutch, Electrohydraulic Controls
P.T.O - Accumulator Components, Prior S N 1595
P.T.O - Accumulator Components, Effective S N 1595
P.T.O - Pump Drive
P.T.O - Reducer Valve And Lines, S N 1002 Only
P.T.O - Oil Flow Control Valve
P.T.O - Oil Flow Control Valve, Oil Flow Control Valve
P.T.O - Hydraulic Valve Components
P.T.O - Electronic Control P.T.O.
P.T.O - P.T.O. - 4 Speed
P.T.O - Four Speed Economy
P.T.O - P.T.O. - With Added Shafts
P.T.O - P.T.O. - Economy Control
P.T.O - P.T.O. - Ground Drive
P.T.O - Controls - Synchronized
P.T.O - P.T.O. - Synchronized
P.T.O - Oil Filter
P.T.O - Oil Supply
Power Steering - Steering Column W Adj. Steering Whl
Power Steering - Steering Tilt
Power Steering - Control Unit Lines And Hoses
Power Steering - Steering Pump Components
Power Steering - Pump, Filter And Valves
Power Steering - Oil Cooler And Lines
Power Steering - Lines - 2wd
Power Steering - Lines - 2 Cylinder - Single Acting - 4wd
Power Steering - Pump Components
Sheet Metal - Hood
Sheet Metal - Shields
Sheet Metal - Solenoid Valves Shield
Engine Cooling - Hoses And Overflow Reservoir
Engine Cooling - Fan Guard
Sheet Metal - Battery And Tool Box Supports, 2wd
Sheet Metal - Battery And Tool Box Supports, 4wd
Operator's Station - Instrument Panel
Operator's Station - Bulkheads-Without Heater, Early
Operator's Station - Bulkheads Without Heating, Late
Operator's Station - Throttle Control
Sheet Metal - Front Fenders, 2wd
Sheet Metal - Front Fenders, 4wd
Sheet Metal - Platform
Sheet Metal - Platform Supports And Steps
Operator's Station - Platform Console
Sheet Metal - Rops Safety Frame
Fuel System - Fuel Tank And Support
Intake And Exhaust - Air Cleaner
Intake And Exhaust - Air Cleaner Components
Intake And Exhaust - Pre-Filter Components
Seat - Seat - Cloth, Grammer Model Ds83h
Seat - Seat Components - Cloth
Seat - Seat - Vinyl
Seat - Seat Components - Vinyl
Electrical - Lights
Electrical - Lights Components
Electrical - Alternator, Starter And Battery
Electrical - Electrical Starting, Prior S N 1175
Electrical - Electrical Starting, Eff S N 1175 - 1594
Electrical - Fuse Box Conversion, Prior S N 1595
Electrical - Electrical Starting, Eff. S N 1595
Electrical - Relays
Electrical - Ignition Switch
Electrical - Control Box - Steering Column
Electrical - Instrument Panel Components
Electrical - Thermostarter
Electrical - Alternator Components-Marelli
Electrical - Alternator Components -- Iskra
Electrical - Alternator Components - Bosch
Electrical - Starter Components - Bosch
Electrical - Starter Components--Marelli
Electrical - Starter Components--Iskra
Electrical - Digital Clock
Wheels - Wheels - 2wd
Wheels - Wheels - 4wd, Siriac Type Rims
Wheels - Wheels - 4wd, Delachaux Type Rims
Cab - Cab Frame
Cab - Outside Mirrors And Door Latch
Cab - Windshield And Door Glass
Cab - Windows Rear And Side
Cab - Interior Trim
Cab - Interior Trim - Console
Cab - Interior Trim - Cab Roof
Cab - Cab Roof
Cab - Roof And Trim - Rops
Cab - Windshield Wiper And Washer
Cab - Windshield Wiper Components
Cooling & Heating System - A C And Ventilation Ducting
Cooling & Heating System - Cab Blower
Cooling & Heating System - Blower Components, R-12, Prior S N
Cooling & Heating System - Blower Components, Eff. S N 1566
Cooling & Heating System - A C Compressor And Belts
Cooling & Heating System - A C Condensor And Lines
Cooling & Heating System - Compressor Components, R-12
Cooling & Heating System - Heater Blower
Cooling & Heating System - Heater Control
Cooling & Heating System - Heater Blower Components
Hydraulics - Hydraulic Housing, Prior S N 1486
Hydraulics - Hydraulic Housing, Eff. S N 1486
Hydraulics - Rear Lift Pump And Lines, Prior S N 1005
Hydraulics - Rear Lift Pump And Lines, Eff S N 1005
Hydraulics - Hydraulic Pump Components
Hydraulics - Rear Lift System, Prior S N 1486
Hydraulics - Rear Lift Shaft & Arms, Effective S N 1486
Hydraulics - Hydraulic Valve And Regulator, Prior S N 1005
Hydraulics - Hydraulic Lift Valve, Effective S N 1005
Hydraulics - Inner And Outer Control, Prior S N 1762
Hydraulics - Inner And Outer Control, Eff. S N 1762
Hitch, Lift And Drawbar - Lift Controls
Hitch, Lift And Drawbar - Control Linkage
Hitch, Lift And Drawbar - Ground Control
Hydraulics - Draft Sensing
Hydraulics - Valves - 3-Way Auxiliary, Prior S N 1005
Hydraulics - Valve Components - 3-Way Auxiliary, Prior S N
Hydraulics - Valve Control - 3-Way Auxiliary, Prior S N 1005
Hydraulics - Valves - 4-Way Auxiliary, Version One, Eff S N
Hydraulics - Valve Components - 4-Way Auxiliary, Version One,
Hydraulics - Valve Control - 4-Way Auxiliary, Version One
Hydraulics - Valves - 4-Way Auxiliary, Version Two, Eff. S N
Hydraulics - Valve Components - 4-Way Auxiliary, Version Two,
Hydraulics - Valve Control - 4-Way Auxiliary, Version Two,
Hydraulics - Valve - 5-Way Auxiliary, Prior S N 1005
Hydraulics - Valve Components - 5-Way Auxiliary, Prior S N
Hydraulics - Valve Control - 5-Way Auxiliary, Prior S N 1005
Hydraulics - Valves - 6-Way Auxiliary - Optional, Version One
Hydraulics - Valve Components - 6-Way Auxiliary, Optional,
Hydraulics - Valve Control - 6-Way Auxiliary, Optional,
Hydraulics - Valves - 6-Way Auxiliary - Optional, Version Two
Hitch, Lift And Drawbar - Three-Point Hitch
Hitch, Lift And Drawbar - Swinging Drawbar
Hitch, Lift And Drawbar - Auxiliary Hydraulic Lift Cylinders,
Hitch, Lift And Drawbar - Telescopic Lower Links
Accessories - Radio Bracket
Accessories - P.T.O. Guard
Accessories - Rear P.T.O. Guard
Accessories - Front P.T.O. Guard
Accessories - Rear Fenders
Accessories - Extensions For Rear Fenders
Accessories - Valve Kit - 3 Spool Remote, Salami
Accessories - Hydraulic Couplers, Pioneer
Accessories - Tool Kit
Accessories - Front Weights
Accessories - Ether Starting Aid, 1st Type
Accessories - Ether Starting Aid, 2nd Type
Accessories - Pioneer Remote Coupler Assembly, 1st And 2nd
Accessories - Pioneer Remote Coupler Assembly, 3rd
Accessories - Coolant Heater, Block Heater
Accessories - Starter Solenoid Kit, Prior S N 1176
Accessories - Rear Wiper
Accessories - Rops Canopy
Accessories - Auxiliary Hydraulic Pump
Accessories - Harness Adapter, Iso To Sae
Decals - Speed Charts
Decals - Safety Decals
Decals - Smv Emblem
Decals - Recommended Dealer Stock
Brand: White
Engine - Crankcase
Engine - Camshaft
Engine - Oil Cooler
Brakes - Hand Brake
P.T.O - Pump Drive
P.T.O - Oil Filter
P.T.O - Oil Supply
Sheet Metal - Hood
Seat - Seat - Vinyl
Electrical - Lights
Electrical - Relays
Cab - Cab Frame
Cab - Interior Trim
Cab - Cab Roof
Decals - Smv Emblem
