White Tractor 60 80 American Series Parts Catalog 79015698
Brand: White
Model:
White 60 American Series Tractor
White 80 American Series Tractor
Part Number: 79015698
Number of Pages: 301 Pages
Decals - Decals, Emblems And Paint
Engine - Cylinder Block
Engine - Oil Pan And Oil Pump
Engine - Crankshaft And Pulley
Engine - Balancer
Engine - Front Gear Cover
Engine - Camshaft
Engine - Connecting Rod And Piston - Model 60
Engine - Connecting Rod And Piston - Model 80
Engine - Cylinder Head And Rocker Levers
Engine - Engine Oil Cooler And Filter
Engine - Flywheel And Flywheel Housing
Fuel System - Injection Pump, Injectors And Lines, Model 60
Fuel System - Injection Pump, Injectors And Lines, Model 80
Fuel System - Filter And Pump
Fuel System - Ether Cold Starting Kit
Engine Cooling - Water Pump And Fan Drive
Engine Cooling - Fan, Radiator And Hoses
Intake And Exhaust - Intake Manifold Cover & Exhaust
Intake And Exhaust - Turbocharger, Exhaust Manifold &
Intake And Exhaust - Air Cleaner
Intake And Exhaust - Air Cleaner, Components
Intake And Exhaust - Muffler And Exhaust - Up
Intake And Exhaust - Muffler And Exhaust - Down
Fuel System - Throttle Controls
Fuel System - Fuel Tank And Lines
Electrical - Alternator And Starting Motor
Electrical - Starting Motor, Delco No. 1113276
Electrical - Starting Motor, Delco No. 1998457
Electrical - Alternator, Prior S N 404422
Electrical - Alternator, Eff. S N 404422
Electrical - Alternator, 105 Amp, Eff. S N 404422
Electrical - Instrument Panel
Electrical - Radio, Speaker Plates And Grills, Prior S N
Electrical - Radio, Speaker Plates And Grills, Eff. S N 405028
Electrical - R.H. Instrument Panel, Gauges, Warning Lights And Switches
Electrical - L.H. And Lower Instrument Panel, Switches,
Electrical - Cab Electrical System
Electrical - Lights, Cab Tractor
Electrical - Lights - Rops Tractor
Electrical - Canopy Lamp Wiring - Rops Tractor
Electrical - Head Lamp
Electrical - Warning Lamp - Rops W O Canopy
Electrical - Flood Lamp, Rops
Electrical - Lights, Stadium
Clutch - Clutch Assembly
Clutch - Clutch Cover - 12 Inch
Clutch - Pedal And Linkage
Transmission - Three Speed Power Shift Transmission, Cover, Filter And Pump
Transmission - Three Speed And Hydraulic Oil Cooler, And
Transmission - Bypass Valve
Transmission - Rear Main Frame
Transmission - Transmission Input Shaft - Model 60
Transmission - Transmission Countershaft And Reverse, Idler -
Transmission - Transmission Pinion Shaft - Model 60
Transmission - Gear Shift - Model 60
Transmission - Transmission Pinion Shaft - Model 80
Transmission - Gear Shift - Model 80
Transmission - Differential
Transmission - Differential Lock, Eff. 60 S N 404422, Eff. 80
Transmission - Rear Axle - Model 60
Transmission - Rear Axle - Model 80
Brakes - Brake Assembly
Brakes - Brake - Disc
Brakes - Pedals And Linkage, Rops
Brakes - Pedals And Linkage, Cab
Wheels - Rear Wheels
P.T.O. - Power Take Off
P.T.O. - Clutch
Hydraulics - Hydraulic Housing And Cover
Hydraulics - Hydraulic Pump And Filter
P.T.O. - Power Take-Off Valve
Hydraulics - Hydraulic Filter
Hydraulics - Flow Divider
Hydraulics - Hydraulic Controls - Rops
Hydraulics - Hydraulic Controls - Cab
Hydraulics - Remote Valves And Control Levers
Hydraulics - Remote Valve - Center
Hydraulics - Remote Valve - End
Hydraulics - Remote Hydraulic Couplings And Hoses
Hitch, Lift And Drawbar - Three Point Hitch Draft Sensitivity
Hitch, Lift And Drawbar - Three Point Hitch - Model 60
Hitch, Lift And Drawbar - Three Point Hitch With Extendable
Hitch, Lift And Drawbar - Upper Link
Hitch, Lift And Drawbar - Rockshaft, Lift Arms And Lift Cylinders, Model 60
Hitch, Lift And Drawbar - Three Point Hitch - Model 80
Hitch, Lift And Drawbar - Servo Valve
Hitch, Lift And Drawbar - Drawbar - Model 60
Hitch, Lift And Drawbar - Drawbar - Model 80
Steering And Front Axles - Steering Wheel, Column And Pedal
Steering And Front Axles - Steering Column
Steering And Front Axles - Steering Control Unit And Lines -
Steering And Front Axles - Steering Dampener, Isolator &
Steering And Front Axles - Steering Control Unit, Evans
Steering And Front Axles - Steering Cylinder And Lines - 2wd
Steering And Front Axles - Front Axle Carrier And Tie Rod -
Steering And Front Axles - Tie Rod
Steering And Front Axles - Adjustable Front Axle
Steering And Front Axles - Adjustable Front Axle, High
Steering And Front Axles - Transfer Drive - Pfa
Steering And Front Axles - Front Axle And Steering Lines -
Steering And Front Axles - Limit Slip Differential, Ring Gear
Steering And Front Axles - Axle Housing And Tie Rods - Pfa
Steering And Front Axles - Steering Joint Housing And Wheel
Steering And Front Axles - Planetary Drive - Pfa
Steering And Front Axles - Steering Cylinder - Pfa
Wheels - Front Wheels - 2wd And Pfa
Seat - Seat And Suspension
Seat - Air Ride Seat And Suspension
Sheet Metal And Frame - Front Main Frame
Sheet Metal And Frame - Roll Bar And Canopy
Sheet Metal And Frame - Hood And Side Panels
Sheet Metal And Frame - Grille
Sheet Metal And Frame - Wheel Guards And Platforms, Rops
Sheet Metal And Frame - Front Fender - Pfa
Sheet Metal And Frame - Step, Battery Box And Cables
Cab - Body
Cab - Headliner And Foam Panels
Cab - Door And Windows
Cab - Cab Glass Specifications
Cab - Windshield Wiper, Prior S N 404422
Cab - Instrument Panel - Cab
Cab - Cab Mounting
Air Conditioning And Heating - Cab Heater
Air Conditioning And Heating - Cab Blower
Air Conditioning And Heating - Condenser And Evaporator
Air Conditioning And Heating - Compressor, Clutch And Pulley
Air Conditioning And Heating - Compressor Clutch
