White Tractor 570 570 Super Parts Catalog 44802300
Brand: White
Model:
White 570 Tractor
White 570 Super Tractor
Part Number: 44802300
Number of Pages: 150 Pages
Decals (Not Illus.)
Illus. 4 - Sheet Metal
Illus. 6 - Frame Radiator And Rear Platform
Illus. 8 - Battery Box And Tool Box
Illus. 12 - Throttle Control (Diesel Model)
Illus. 14 - Throttle Control (Gas Model)
Illus. 16 - Control Panel
Illus. 20 - Brake And Clutch Pedals
Illus. 24 - Row Crop Front Axle
Illus. 28 - Standard Front Axle
Illus. 32 - Wide Adjustable Front Axle
Illus. 36 - Standard Steering
Illus. 40 - Power Steering (Part I) Steering Gear Complete - See 3118523
Illus. 44 - Power Steering (Part 2)
Illus. 48 - Power Steering Pump Pump Complete - See Mao-570
Illus. 50 - Power Steering Pump Pump Complete - See Mao-989
Illus. 52 - Water Pump Water Pump Complete - See Mko-307
Illus. 56 - Valve Rocker Arms, Push Rods, And Tappets
Illus. 60 - Cylinder Head, Cover, Valves Gasket Kit - See 3122987
Illus. 64 - Camshaft And Governor
Illus. 68 - Camshaft And Gear Housing
Illus. 70 - Bell Housing And Flywheel
Illus. 72 - Connecting Rod, Piston And Rings (-Dp1000)
Illus. 74 - Connecting Rod, Piston And Rings (Dp1001 -)
Illus. 76 - Cylinder Block, Crankshaft And Bearings
Illus. 80 - Cylinder Block, Crankshaft And Bearings
Illus. 84 - Clutch Clutch Complete - See 3112413 Facing Package - See To-18817
Illus. 88 - Oil Pump Oil Pump Complete - See Mko-679, 3115603
Illus. 96 - Manifold Muffler And Exhaust Stack - (Gas Model)
Illus. 100 - Manifold Muffler And Exhaust Stack (Diesel Only)
Illus. 101 - Oil Pan Gasket Kit - See 3122977
Illus. 102 - Fuel Injection Lines And Clamps - (Dp1001 -)
Illus. 104 - Fuel Injection System (Diesel With Bosch Pump) Fuel Pump Complete - See Mko-464, Mko-632
Illus. 106 - Fuel Injection (Diesel With Roosa Pump) Fuel Pump Complete - See Mko-566
Illus. 108 - Hand Primer Pump - (Diesel Only) Hand Primer Pump Complete - See Mko-364
Illus. 109 - Sediment Bowl (Diesel) Sediment Bowl Complete - See 9430113
Illus. 110 - Oil Filter (Diesel With Bosch Pump) Oil Filter Complete - See To-19436
Illus. 112 - Generator And Regulator Generator Complete - See To-17354b - Gas Generator Complete - See To-18386b - Diesel
Illus. 116 - Starter (Gas) Starter Complete - See To-17353
Illus. 120 - Starter (Diesel) Starter Complete - See To-17700b
Illus. 122 - Starter (Diesel) Starter - Complete - See To-17700b
Illus. 124 - Distributor (Gas) Distributor Complete - See To-17441 Coil Complete - See To-18134
Illus. 128 - Carburetor (Gas) Carburetor Complete - See To-17344 Gasket Kit - See To-16580 Repair Kit - See To-18771
Illus. 132 - Air Cleaner (Diesel) (Gas)
Illus. 134 - Collector Precleaner Collector Precleaner - Complete - See 3114743
Illus. 140 - Transmission And Accessory Drive
Illus. 144 - Monroe Seat
Illus. 146 - Torsion - Glide Seat
Illus. 148 - Shift Tower And Transmission Case
Illus. 152 - Differential, Case And Brakes
Illus. 156 - Axle, Trumpets And Final Drive Gears
Illus. 160 - Non-Adjustable Rear Wheels (Bevel Type)
Illus. 162 - Rear Wheels
Illus. 164 - Belt Pulley
Illus. 168 - Headlights
Illus. 172 - Live Power Take Off Clutch - Complete - See To-15721 Pressure Plate Asy. - See To-17677
Illus. 176 - Rolling Drawbar
Illus. 180 - Three Point Hitch
Illus. 182 - Weights
Illus. 184 - Hydraulic Shiftable Drive
Illus. 188 - Hydraulic Casting And Pump Pump - Complete - See To-16840
Illus. 192 - Hydraulic Casting And Rockshaft
Illus. 196 - Hydraulic Valve Valve Complete - See 3110243
Illus. 200 - Hydraulic Cylinder Cylinder - Complete - See 3117585
Illus. 204 - Breakaway Coupling And Hoses Coupling Complete - See 9630633 Coupling Service Kit - See To-17304
Illus. 208 - Axle Type Power Steering
Brand: White
Model:
White 570 Tractor
Decals (Not Illus.)
