White Tractor 560 Parts Catalog C820R000
Brand: White
Model: White 560 Tractor
Part Number: C820R000
Number of Pages: 125 Pages
Decals And Paint (Not Illus.)
Illus. 4 - Sheet Metal
Illus. 6 - Frame, Radiator And Rear Platform
Illus. 8 - Battery And Tool Boxes
Illus. 12 - Control Panel
Illus. 14 - Throttle Control
Illus. 16 - Throttle Control
Illus. 20 - Row Crop Front Axle
Illus. 24 - Wide Adjustable Front Axle
Illus. 28 - Standard Front Axle
Illus. 32 - Regular Steering
Illus. 36 - Power Steering - Part 1 Steering Gear - Complete - See To-17641
Illus. 40 - Power Steering - Part 2
Illus. 44 - Power Steering Pump Pump Complete - See Mao-570
Illus. 46 - Power Steering Pump Pump With Reservoir - See To-19940 Pump Less Reservoir - See Mao-989
Illus. 48 - Cylinder Head
Illus. 52 - Rocker Arm And Tappets
Illus. 60 - Block
Illus. 64 - Oil Pump Oil Pump Complete - See Mpo-908
Illus. 68 - Oil Pan
Illus. 72 - Camshaft
Illus. 76 - Water Pump Water Pump - Complete - See Mpo-717 Repair - Complete - See Mpo-1012
Illus. 80 - Air Cleaner And Venturi Air Cleaner Complete - See To-17735b
Illus. 82 - Manifold And Muffler
Illus. 84 - Brake And Clutch Pedals
Illus. 88 - Clutch Clutch - Complete - See To-18156
Illus. 92 - Bell Housing And Flywheel
Illus. 100 - Starter - Diesel Only Starter Complete - See To-17855
Illus. 102 - Starter Starter - Complete - See To-17855b
Illus. 104 - Generator Generator - Complete - See To-18339 Regulator - Complete - See To-17856
Illus. 108 - Oil Filter And Fittings Filter - Complete - See Mpo-1002 Filter - Complete - See Mpo-715
Illus. 112 - Sediment Bowl Sediment Bowl - Complete - See To-18225
Illus. 114 - Secondary Filter Filter - Complete - See Mao-152 And Mao-1007
Illus. 115 - Secondary Filter Filter - Complete - See 9430013
Illus. 116 - Fuel Pump And Lines Pump Complete - See Mao-567
Illus. 118 - Fuel Pump And Lines
Illus. 120 - Transmission And Accessory Drive
Illus. 124 - Shift Tower And Transmission Case
Illus. 128 - Differential, Case And Brakes
Illus. 132 - Axle, Trumpets And Final Drive Gears
Illus. 136 - Adjustable Rear Wheels - Bevel Type
Illus. 138 - Non Adjustable Rear Wheels - Deep Well Type
Illus. 140 - Belt Pulley Drive
Illus. 144 - Head Lights
Illus. 148 - Live Power Take Off Clutch - Complete - See To-15721 Pressure Plate Asy. - See To-17677
Illus. 152 - Rolling Drawbar
Illus. 156 - Three Point Hitch
Illus. 160 - Torsion Glide Seat
Illus. 162 - Monroe Seat
Illus. 164 - Weights
Illus. 166 - Block Heater
Illus. 172 - Hydraulic Shiftable Drive
Illus. 176 - Hydraulic Casting And Pump Pump - Complete - See To-16840
Illus. 180 - Hydraulic Casting And Rockshaft
Illus. 184 - Hydraulic Valve
Illus. 188 - Hydraulic Cylinder Cylinder - Complete - See To-13274
Illus. 192 - Breakaway Coupling And Hoses Coupling Service Kit - See To-17304
Brand: White
Illus. 60 - Block
Illus. 68 - Oil Pan
