White Tractor 550 Parts Catalog C845R000
Brand: White
Model: White 550 Tractor
Part Number: C845R000
Number of Pages: 144 Pages
Decals (Not Illus.)
Sheet Metal, Fuel Tank (S N 1-)
Frame, Radiator And Clutch Cover (S N 1-)
Battery And Battery Boxes (S N 1-)
Throttle Control (Diesel Model)
Throttle Control (Gas Model)
Control Panel (S N 1-)
Row Crop Front Axle (S N 1-)
Standard Front Axle (S N 1-)
Wide Adjustable Front Axle
Regular Steering (S N 1-)
Power Steering
Power Steering Gear
Power Steering Pump
Power Steering Pump And Reservoir (S N Bo1001 -)
Water Pump (S N 1-)
Valve Rocker Arm, Push Rod Tappets (S N 1-)
Cylinder Head, Cover And Valves (S N 1-)
Camshaft And Governor - Gas And Diesel With Roosa Pump
Gear Housing And Governor - Gas Only (S N Bo1001 -)
Connecting Rod, Piston And Rings (S N 1-)
Cylinder Block, Crankshaft, Bearing And Piston (S N 1-)
Bell Housing And Flywheel (S N 1-)
Oil Pump (S N 1-)
Oil Pan (S N 1-)
Manifold, Muffler And Exhaust Stack Gas Only (S N 1-)
Manifold, Muffler And Exhaust Stack Diesel Only (S N 1-)
Aircleaner - Gas Only (S N 1-)
Air Cleaner - Diesel Only (S N 1-)
Collector Precleaner (S N 1-)
Brake And Clutch Pedals (S N 1-)
Fuel Injection System - Roosa Pump (S N 1-)
Fuel Injection System - Bosch Pump
Hand Primer Pump - Diesel Only (S N 1-)
Generator (S N 1-)
Starter - Gas Only (S N 1-)
Starter - Diesel Only (S N - Bo1000)
Starter - Diesel Only (S N Bo1001 -)
Carburetor - Gas Only (S N 1-)
Distributor - Gas Only (S N 1-)
Clutch - Diesel Model (1-) - Gas Model (- Bm5000)
Clutch - Gas Model (Bn5001 -)
Transmission And Accessory Drive
Monroe Seat
Torsion - Glide Seat
Shift Tower And Transmission Case (S N 1-)
Differential, Case And Brakes
Axle, Trumpets And Final Drive Gears
Non Adjustable Rear Wheels (S N 1-)
Belt Pulley Drive (S N 1-)
Lights
Weights (S N 1-)
Live Power Take-Off And Declutch (S N 1-)
Standard Hitch
Three Point Hitch (S N 1-)
Hydraulic Pump (Year Used 5
Hydraulic Casting And Parts Trailing Implements Only
Hydraulic Casting And Rockshaft, Mounted Implements Only
Hydraulic Valve - Mounted Implements Only (Year Used 5
Hydraulic Valve - Trailing Implements Only
Hydraulic Cylinder - Mounted Implements Only
Hydraulic Cylinder - Trailing Implements Only
Breakaway Coupling And Hoses (Year Used 5
Brand: White
Decals (Not Illus.)
Power Steering
Power Steering Gear
Power Steering Pump
Water Pump (S N 1-)
Oil Pump (S N 1-)
Oil Pan (S N 1-)
Generator (S N 1-)
Monroe Seat
Lights
Weights (S N 1-)
Standard Hitch
