White Tractor 540 Parts Catalog C814R000
Brand: White
Model: White 540 Tractor
Part Number: C814R000
Number of Pages: 105 Pages
Decals (Not Illus.)
Illus. 4 - Sheet Metal
Illus. 8 - Battery And Tool Boxes; Steel Seat
Illus. 10 - Cushion Seat (S N An5596 - )
Illus. 12 - Brake And Clutch Pedals (S N 1-)
Illus. 16 - Control Panel
Illus. 20 - Throttle Control (S N 1-)
Illus. 24 - Wide Adjustable Front End
Illus. 26 - Regular Steering
Illus. 28 - Power Steering
Illus. 32 - Power Steering Pump (S N 1-)
Illus. 36 - Block (S N 1-)
Illus. 40 - Crankshaft, Bearing And Pistons (S N 1-)
Illus. 44 - Camshaft, Valves And Tappets (S N 1-)
Illus. 48 - Governor (S N 1-)
Illus. 52 - Oil Pump (S N 1-)
Illus. 56 - Bell Housing And Flywheel
Illus. 60 - Manifold And Muffler (S N 1-)
Illus. 64 - Water Pump (S N 1-)
Illus. 68 - Air Cleaner; Sediment Bowl; Oil Filter (S N 1-)
Illus. 72 - Distributor
Illus. 76 - Carburetor
Illus. 80 - Starter And Solenoid (Serial - Am1355)
Illus. 81 - Starter (Serial Am1356 - Ap1000)
Illus. 82 - Starter (Serial Ap1000 - )
Illus. 83 - Generator (Serial Ap1001 -)
Illus. 84 - Generator (Serial - Ap1000)
Illus. 88 - Clutch (S N 1-)
Illus. 92 - Transmission (S N 1-)
Illus. 96 - Shift Towers (S N 1-)
Illus. 100 - Differential Case And Brakes
Illus. 104 - Axles, Trumpets And Final Gears
Illus. 108 - Front Wheels
Illus. 112 - Red Tail Light; Head Light; Rear Flood Light
Illus. 114 - Swinging Drawbar
Illus. 116 - Three Point Hitch (Early Models)
Illus. 118 - Three Point Hitch (Late Models)
Illus. 120 - Live Power Take-Off
Illus. 124 - Belt Pulley
Illus. 136 - Hydraulic Casting And Parts-Trailing Implements
Illus. 140 - Hydraulic Casting And Rockshaft - Mounted
Illus. 148 - Hydraulic Valve - Mounted Implements Only
Illus. 152 - Hydraulic Valve - Trailing
Illus. 156 - Hydraulic Pump
Illus. 160 - Hydraulic Cylinder - Mounted Implements Only
Illus. 164 - Hydraulic Cylinder - Trailing
Illus. 168 - Hydraulic Cylinder - Trailing
Illus. 172 - Breakaway Coupling And Hoses (S N 1-)
