White Tractor 445 Parts Catalog R1157C00
Brand: White
Model: White 445 Tractor
Part Number: R1157C00
Number of Pages: 140 Pages
Crankcase - Group 1 - Gasoline, Tractor Fuel Or Lp Gas
Crankcase - Group 2 - Diesel Engine
Cylinder Block And Cylinder Head - Group 1
Cylinder Block And Cylinder Head - Group 2, Diesel Engine
Camshaft, Rocker Arms, Valves, Push Rods And Tappets
Camshaft, Connecting Rods, Pistons, Rings And Flywheel
Crankshaft, Connecting Rods, Pistons, Rings And Flywheel
Gas Manifold, Air Cleaner And Muffler
Carburetor
Carburetor And Vaporizer For Lp Gas - Group 2
Governor And Controls
Throttle Controls (For Diesel Tractors)
Fuel Tank, Supports And Strainer
Fuel Tank, Support And Gauges - Group 2 - For Lp Gas Tractor
Fuel Filter For Diesel Tractor
Fuel Injection System (For Diesel Engine)
Grille And Service Panels
Grille And Service Panel (For Lp Gas Tractors)
Distributor, Coil And Spark Plugs
Water Pump And Fan
Oil Pump And Oil Filter
Electrical Equipment - Group 1 - Generator, Starting Motor,
Electrical Equipment - Group 2 - Lamp And Wires
Electrical Equipment - Group 3 - Instrument Panel And
Clutch, Clutch Shaft And Clutch Pedal
Upper Sliding Gear Shaft, Pinion, Gears And Reverse Gears
Ampli-Torc Drive
Transmission Case, Covers And Gear Shifting Mechanism
Differential Case, Gears And Rear Axle
Brakes
Belt Pulley
Rear Power Take-Off
Front Power Take-Off
Radiator And Thermostat
Steering Gear Housing And Controls
Steering Wheel, Shafts And Supports
Front Axle, Column And Wheels (445 Tractor Type U )
Front Axle Fork And Wheels (445 Tractor Type N )
Front Axle, Steering Knuckle And Wheels (445 Type E
Front Axle And Wheels (445 Utility Tractor)
Wheelguard, Platform And Seat
Hydraulic Pump With External Plumbing
Control And Damper Valve
Hydraulic Equipment - Reservoir And Cylinder For Tractors
Hydraulic Equipment-Reservoir For Tractors With Tel-O-Flo
Reservoir (For Tractors With Tel-O-Flo Hydraulic System)
Hydraulic Equipment-Reservoir And Cylinder For Tractors With
Cylinder And Linkage-For Tractors With Tel-O-Flo Hydraulic
Hydraulic Equipment-Reservoir And Control Levers For
Hydraulic Equipment
Hydraulic Equipment-Control Levers And Linkage For Tractors
Hand Controls And Linkage
Hydaulic Equipment (Valve Assembly And Filter)
Hydraulic Equipment - Remote Mounted Jack And Depth Control
Hydraulic Equipment-Selective And Simultaneous Lift -
3 Point Hitch
3 Point Hitch Stabilizer
Swinging Drawbar
Tool Box And Tools
Brand: White
Carburetor
Water Pump And Fan
Ampli-Torc Drive
Brakes
Belt Pulley
Rear Power Take-Off
Hydraulic Equipment
3 Point Hitch
Swinging Drawbar
Tool Box And Tools
