White Tractor 2255 Parts Catalog 43308500
Brand: White
Model: White 2255 Tractor
Part Number: 43308500
Number of Pages: 368 Pages
Front Main Frame
Engine - Model 3150
Engine - Model 3208
Camshaft, Rocker Arm And Push Rods (Engine S N 97m2145 -)
Crankcase Covers And Housings (Engine S N 97m2145 -)
Cylinder Block (Engine S N 97m2145 -)
Cylinder Head And Valves (Engine S N 97m2145 -)
Crankshaft (Engine S N 97m2145 -)
Flywheel (Engine S N 97m2145 -)
Connecting Rods And Pistons (Engine S N 97m2145 -)
Oil Pan (Engine S N 97m2145 -)
Oil Pump And Filters (Engine S N 97m2145 -)
Air System (Engine S N 97m2145 -)
Crankcase Ventilating Valve (Engine S N 97m2145 -)
Cooling System (Engine S N 97m2145 -)
Fuel Pump And Governor (Engine S N 97m2145 -)
Fuel Injection System (Engine S N 97m2145 -)
Fuel Pump Housing
Governor
Rack Stop
Fuel Filter And Lines (Engine S N 97m2145 -)
Valve Mechanism (Engine S N 90n1336 -)
Camshaft (Engine S N 90n1336 -)
Front Housing (Engine S N 90n1336 -)
Engine Support - Front (Engine S N 90n1336 -)
Cylinder Block And Cover (Engine S N 90n1336 -)
Cylinder Head And Valves (Engine S N 90n1336 -)
Crankshaft (Engine S N 90n1336 -)
Crankshaft Pulley And Seals (Engine S N 90n1336 -)
Flywheel, Flywheel Housing And Cover (Engine S N 90n1336 -)
Connecting Rods And Pistons (Engine S N 90n1336 -)
Oil Pan And Dipstick (Engine S N 90n1336 -)
Oil Lines - Rear Sump (Engine S N 90n1336 -)
Oil Pump And Filters (Engine S N 90n1336 -)
Oil Cooler (Engine S N 90n1336 -)
Water Pump (Engine S N 90n1336 -)
Water Lines (Engine S N 90n1336 -)
Inlet Manifold (Engine S N 90n1336 -)
Exhaust Manifold (Engine S N 90n1336 -)
Positive Crankcase Ventilation Valve (Engine S N 90n1336 -)
Governor And Fuel Pump Drive (Engine S N 90n1336 -)
Governor Control (Engine S N 90n1336 -)
Fuel Injection System (Engine S N 90n1336 -)
Governor And Fuel Injection Pump Part 1 (Eng. S N 90n1336 -)
Governor And Fuel Injection Pump Part 2 (Eng. S N 90n1336 -)
Governor And Fuel Injection Pump Part 3 (Eng. S N 90n1336 -)
Governor And Fuel Injection Pump Part 4 (Eng. S N 90n1336 -)
Electric Shut-Off - Injection Pump (Engine S N 90n1336 -)
Torque Control - Injection Pump (Engine S N 90n1336 -)
Fuel Injections Lines - Part 1 (Engine S N 90n1336 -)
Fuel Injection Lines - Part 2 (Engine S N 90n1336 -)
Fuel Filter (Engine S N 90n1336 -)
Fuel Filter Lines (Engine S N 90n1336 -)
Fuel Priming Pump (Engine S N 90n1336 -)
Oil Pressure Gauge
Muffler And Manifold Heat Shields
Manifold Preheater (S N 235650 -)
Air Cleaner (S N 235650 -)
Precleaner - Aspirator
Main Fuel Tank (S N 235650 -)
Main Fuel Tank Lines (S N 235650 - 248721)
Wheel Guard Fuel Tanks (S N 235650 -)
Fender Fuel Tanks - With Cab (S N 235650 -)
Wheel Guard And Fender Fuel Tank Lines (S N 235650 -)
Governor Controls (S N 235650-247283)
Governor Controls (S N 247284 -)
Ignition And Starter (S N 235650 -)
Starting Motor
Cooling System (S N 235650 -)
Transmission Pressure Lube System (S N 235650 -)
Transmission Lube Pump
Rear Main Frame (S N 235650 -)
Transmission (S N 235650 - 248721)
Gear Shift (S N 235650 -)
Brake Controls (S N 235650 - 247283)
Brake Valve And Lines (S N 247284 -)
Brake Pedals And Linkage (S N 247284 -)
Brake Valve
Hand Brake (S N 235650 -)
Brakes (S N 235650 -)
Differential (S N 235650 -)
Transfer Drive - Four Wheel (S N 235650 -)
Over Under Hydraul-Shift Cover, Filter And Pump
Over Under Hydraul-Shift Lever And Linkage (S N 235650 -)
Over Under Hydraul-Shift (S N 235650 -)
Over Under Hydraul-Shift Oil Pump
Over Under Hydraul-Shift Oil Cooler
Power Take-Off (S N 235650 -)
Power Take-Off Clutch (S N 235650 -)
Valve - Pto
Hydraulic Housing And Cover (S N 235650 -)
Hydraulic Pump, Filter & Lines (S N 235650 -)
Hydraulic Oil Filter
Unloading Valve
Pressure Valve
Hydraulic Hand Controls (S N 235650 -)
Pressure Detent Valve
Servo Valve
Float Valve
Hydraulic External Draft Sensitivity (S N 235650 -)
Lift Cylinder
Cylinder, Hoses And Connections (S N 235650 -)
Depth Stop Cylinder - 4
Depth Stop Cylinder - 3-1 2
Hydraulic Cooler (S N 235650 - 248721)
Pressure Lube, Hydraulic And Cooler Pump Drive (S N 248722-)
Hydraulic Oil Cooler And Lines (S N 248722 -)
Hydraulic Oil Cooler Pump
Rear Wheels (S N 235650 -)
Rear Wheel Rims (S N 235650 -)
Dual Wheels (S N 235650 -)
Front Wheels (S N 235650 -)
Lights - Without Cab (S N 235650 -)
Lights - With Cab (S N 235650 -)
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Drawbar (S N 235650 -)
Wide Drawbar (S N 235650 -)
6,000 - Lb. Lift Hitch (Category 3) (S N 235650 -)
Clutch And Drive (S N 235650 -)
Clutch Pedal And Linkage (S N 235650 - 247283)
Clutch Pedal And Linkage (S N 247284 -)
Clutch Cover - 14
Rear Axle - Planetary Drive (S N 235650 -)
Planetary Hub
Wheel Guards And Platforms (S N 235650 -)
Platform (S N 247284 -)
Wheel Guard Panels (S N 235650 -)
Step (S N 235650 -)
Seat (S N 235650 -)
Suspension
Roll Bar And Seat (S N 235650 -)
Front Frame Weights (S N 235650 -)
Power Steering (S N 235650 -)
Steering Column
Control Unit
Power Steering - Two Wheel Drive
Power Steering Cylinder
Power Steering Mechanism - Two Wheel Drive (S N 235650 -)
Tie Rod
Front Axle - Two Wheel Drive (S N 235650 -)
Power Steering And Connections - Four Wheel Drive
Cylinder
Front Axle, Carrier And Supports - Four Wheel Drive
Front Axle Drive Shaft - Four Wheel Drive
Front Axle - Four Wheel Drive
Ricefield Front Axle - Four Wheel Drive
Hood, Side Panels And Grille (S N 235650 -)
Instrument Panel (S N 235650 - 247283)
Instrument Panel (S N 247284 -)
Speedometer (S N 235650 -)
Tachourmeter (S N 235650 -)
Tool Box (S N 235650 -)
Cab - Rops (S N 235650 -)
Cab Door And Windows - Rops
Cab Air Filter , Blower And Control Panel - Rops
Cab Roof And Miscellaneous - Rops
Cab Glass Specifications - Rops
Cab Air Conditioner - Rops
Cab Air Conditioner (S N 235650 -)
Air Conditioner Compressor And Drive Pulley
Cab Heater (S N 235650 -)
Brand: White
Front Main Frame
Engine - Model 3150
Engine - Model 3208
Fuel Pump Housing
Governor
Rack Stop
Oil Pressure Gauge
Starting Motor
Brake Valve
Valve - Pto
Unloading Valve
Pressure Valve
Servo Valve
Float Valve
Lift Cylinder
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Clutch Cover - 14
Planetary Hub
Step (S N 235650 -)
Seat (S N 235650 -)
Suspension
Steering Column
Control Unit
Tie Rod
Cylinder
