White Tractor 2050 2150 Parts Catalog 43308500
Brand: White
Model:
White 2050 Tractor
White 2150 Tractor
Part Number: 43308500
Number of Pages: 232 Pages
Group A - Front Main Frame (2wd, 4wd) (S N 204001 -)
Group A - Emblem, Decal Sets And Name Plate (2wd, 4wd)
Group B - Cylinder Head Cover And Breather (2050, 2150)
Group B - Rocker Arms And Push Rods (2050, 2150)
Group B - Cylinder Head And Valves (2050, 2150)
Group B - Crankcase (2050, 2150) (S N 204001 -)
Group B - Crankshaft And Related Parts (2050, 2150)
Group B - Camshaft (2050, 2150) (S N 204001 -)
Group B - Oil Pan And Oil Pump (2050, 2150) (S N 204001 -)
Group B - Oil Filter And Oil Cooler (2050, 2150)
Group B - Manifold (2050, 2150) (S N 204001 -)
Group B - Turbocharger (2150) (S N 204001 -)
Group B - Muffler (2050, 2150) (S N 204001 -)
Group B - Manifold Preheater (2wd, 4wd) (S N 204001 -)
Group B - Air Cleaner (2wd, 4wd) (S N 204001 -)
Group B - Main Fuel System (2wd, 4wd) (S N 204001 -)
Group B - Wheel Guard Fuel Tanks (2wd, 4wd) (S N 204001 -)
Group B - Two Wheel Guard Tanks And Main Tank (2wd, 4wd)
Group B - Auxiliary Fuel Tanks - Narrow Row Cab (2wd, 4wd)
Group B - Governor Controls (2wd, 4wd) (S N 204001 -)
Group B - Injection Pump - Injectors And Accessory-Drive
Group B - Ignition And Starter (2wd, 4wd) (S N 204001 -)
Group B - Ignition Wiring And Clips (2wd, 4wd) (S N 204001-)
Group B - Water Pump, Fan And Fan Belt (2wd, 4wd)
Group B - Cooling System (2wd, 4wd) (S N 204001 -)
Group B - Coolant Heater (2wd, 4wd) (S N 204001 -)
Group C - Rear Main Frame (2wd, 4wd) (S N 204001 -)
Group C - Transmission Pressure Lube System (2wd, 4wd)
Group C - Transmission - Planetary Final Drive (2wd)
Group C - Transmission - Planetary Final Drive (4wd)
Group C - Transmission - Non-Planetary Final Drive (4wd)
Group C - Gear Shift (2wd, 4wd) (S N 204001 -)
Group C - Brake Controls (2wd, 4wd) (S N 204001 -)
Group C - Brakes - Non-Planetary Final Drive (4wd)
Group C - Brakes - Planetary Final Drive (2wd, 4wd)
Group C - Differential (2wd, 4wd) (S N 204001 -)
Group C - Transfer Drive - Four Wheel Drive (4wd)
Group C - Over Under Hydraul-Shift (2wd, 4wd)
Group D - Belt Pulley - For 1000 Rmp Pto (2wd, 4wd)
Group E - Power Take-Off (2wd, 4wd) (S N 204001 -)
Group F - Hydra-Lectric-Stop And Depth-Stop Internal Valve
Group F - Hydra-Lectric-Stop Internal Valve Systems (A)
Group F - Depth-Stop Internal Valve Systems (B)
Group F - Remote Only, Depth-Stop External Valve Systems
Group F - Cylinder, Hoses And Connections - Hydra-Lectric
Group F - Cylinder, Hoses And Connections - Depth-Stop
Group F - Hoses And Connections - Depth-Stop External Valve
Group F - Hydraulic Oil Cooler (2wd, 4wd) (S N 204001 -)
Group H - Rear Wheels (4wd) (S N 204001 -)
Group I - Rear Wheel Rims (2wd, 4wd) (S N 204001 -)
Group J - Rear Wheel Weights (2wd, 4wd) (S N 204001 -)
Group L - Front Wheels (2wd, 4wd) (S N 204001 -)
Group O - Lights (2wd, 4wd) (S N 204001 -)
Group O - Lights - Narrow Row Cab (2wd, 4wd) (S N 204001 -)
Group O - Lights - Continental Cab (2wd, 4wd) (S N 204001 -)
Group P - Drawbar (2wd, 4wd) (S N 204001 -)
Group P - Wide Drawbar (2wd, 4wd) (S N 204001 -)
Group P - Extra Heavy Wide Drawbar (2wd, 4wd) (S N 204001 -)
Group P - 6,000-Lb. Lift Hitch (Category 3) (2wd, 4wd)
Group Q - Clutch (2wd, 4wd) (S N 204001 -)
Group R - Rear Axle - Non-Planetary Final Drive (4wd)
Group R - Rear Axle - Planetary Final Drive (2wd, 4wd)
Group S - Wheel Guards And Platforms (2wd, 4wd)
Group S - Wheel Guard Panels (2wd, 4wd) (S N 204001 -)
Group S - Step (2wd, 4wd) (S N 204001 -)
Group T - Seat (2wd, 4wd) (S N 204001 -)
Group T - Roll Bar And Seat Belt (2wd, 4wd) (S N 204001 -)
Group T - Front Frame Weights (2wd, 4wd) (S N 204001 -)
Group U - Steering (2wd, 4wd) (S N 204001 -)
Group U - Steering Mechanism - Two Wheel Drive (2wd)
Group U - Front Axle - Two Wheel Drive (2wd) (S N 204001 -)
Group U - Steering And Connections - Four Wheel Drive (4wd)
Group U - Front Axle, Carrier And Supports - Four Wheel Drive
Group W - Hood, Side Panel And Grille (2wd, 4wd)
Group W - Instrument Panel (2wd, 4wd) (S N 204001 -)
Group W - Instruments And Switches (2wd, 4wd) (S N 204001 -)
Group W - Speedometer (2wd, 4wd) (S N 204001 -)
Group W - Tachourmeter (2wd, 4wd) (S N 204001 -)
Group X - Tool Box And Tools (2wd, 4wd) (S N 204001 -)
Group Y - Cabs - Continental (2wd, 4wd) (S N 204001 -)
Group Y - Cabs - Narrow Row (2wd, 4wd) (S N 204001 -)
Group Y - Heater And Connections - Continental Cab
Group Y - Heater And Connections - Narrow Row Cab (2wd, 4wd)
Group Y - Weather Break (2wd, 4wd) (S N 204001 -)
Group Y - Converta Cab (2wd, 4wd) (S N 204001 -)
Group Y - Air Conditioner (2wd, 4wd) (S N 204001 -)
Supplement To Catalog 433085 - 2050 - 2150 Tractors
