White Tractor 2-155 Parts Catalog 43328300
Brand: White
Model: White 2-155 Tractor
Part Number: 43328300
Number of Pages: 270 Pages
Decals And Name Plates
Front Main Frame
Cylinder Head Cover And Breather
Rocker Arms And Push Rods
Cylinder Head And Valves
Crankcase
Oil Pressure Regulator Housing
Crankshaft And Pistons
Camshaft
Oil Pan And Oil Pump
Oil Pump
Engine Oil Lines
Oil Filter And Oil Cooler
Intake And Exhaust Manifolds
Turbocharger
Muffler
Manifold Preheater
Air Cleaner
Pre-Cleaner Screener
Lower Fuel Tank And Lines - (S N 272595 Thru 278317)
Lower Fuel Tank And Lines - (S N 278318)
Upper Tank To Lower Tank Transfer Kit
Upper Fuel Tank
Upper Fuel Tank Lines (S N 272595 Thru 278317)
Throttle Control
Injection Pump, Injectors And Lines
Nozzle And Holder Assembly
Ignition And Starter
Starting Motor
Step, Battery Box And Cables
Water Pump, Fan And Fan Belt
Engine Cooling System
Coolant Heater
Clutch
Clutch Cover
Clutch Pedal And Linkage
Over Under Hydraul-Shift Lever And Linkage
Over Under Hydraul-Shift Cover, Filter And Pump
Over Under Hydraul-Shift Oil Pump
Over Under And Hydraulic Oil Cooler And Lines
Rear Main Frame
Transmission Input Shaft
Transmission Countershaft And Reverse Idler
Transmission Pinion Shaft
Gear Shift
Park Lock Lever And Linkage
Brakes
Brake Pedals And Linkage
Brake Valve And Lines
Brake Valve
Differential And Differential Lock
Rear Axle And Planetary
Rear Wheels, Centers And Hub
Dual Wheels
Front Frame Weights
Pto Drive Shafts, Clutch And Brake
Power Take-Off
Pto And Differential Lock Valve, Controls And Lines
Hydraulic Housing And Cover
Hydraulic And Lube Charge Pump Drive
Hydraulic Pump, Filter And Lines
Pressure Valve
Servo Valve, Control Lever And Linkage
Servo Valve
Remote Valves, Control Levers And Linkage
Float Valve
Pressure Detent Valve
Cylinders, Hoses And Connections
Depth Stop Cylinder - 4 Inch
Depth Stop Cylinder - 3-1 2 Inch
Hydraulic Internal Draft Sensitivity
Rockshaft And Lift Cylinder
Three-Point Hitch (Category Iii)
Category Ii And Iii Narrow And Category Iii Wide Quick-Hitch
Drawbar
Wide Drawbar
Power Steering
Steering Column
Control Unit
Power Steering Cylinder And Lines
Power Steering Mechanism
Tie Rod
Front Axle
Front Wheels
Lights
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Auxiliary Light Connector
Instrument Panel
Instruments And Switches
Seat And Suspension
Seat Suspension
Hood And Side Panels
Grille
Tachourmeter
Electric Speedometer
Tool Box
Cab (S N 272595 Thru 272812)
Cab (S N 272813 And Later)
Cab Door And Windows
Cab Glass Specifications
Windshield Wiper
Cab Mounting
Cab Electrical System
Cab Air Conditioner - Evaporator And Heater Housing
Car Air Conditioner - Evaporator And Heater Housing
Cab Blower
Cab Heater
Cab Air Conditioner - Compressor, Evaporator And Condenser
Compressor Drive Belt Idler Pulley (S N 272595 Thru 278317)
Cab Air Conditioner - Compressor, Condenser And Evaporator
Drive Pulley And Air Conditioner Compressor
