White Tractor 1955 Parts Catalog 43312000
Brand: White
Model: White 1955 Tractor
Part Number: 43312000
Number of Pages: 382 Pages
Front Main Frame
Cylinder Head Cover And Breather
Rocker Arms And Push Rods
Cylinder Head And Valves
Crankcase
Crankshaft And Related Parts
Camshaft
Oil Pan And Oil Pump
Oil Pump
Oil Filter And Oil Cooler
Oil Filter
Manifold - Diesel
Turbocharger
Muffler And Manifold Heat Shield - Diesel
Manifold Preheater - Diesel
Air Cleaner - Diesel
Precleaner Screener
Air Cleaner
Main Fuel Tank - Diesel
Main Fuel Tank Lines
Wheel Guard Fuel Tanks - Diesel
Wheel Guard Fuel Tank Lines - Diesel
Auxiliary Fuel Tanks - Narrow Row Cab - Diesel
Auxiliary Fuel Tank Lines - Narrow Row Cab - Diesel
Governor Hand Lever - Diesel
Governor Controls - Diesel
Injection Pump, Injectors And Accessory Drive
Fuel Injection Pump
Ignition And Starter
Starting Motor
Water Pump, Fan And Belts
Coolant Heater
Transmission Pressure Lube System
Transmission Lube Pump
Gear Shift
Brake Controls
Brake Valve
Hand Brake
Brakes
Transfer Drive - Four Wheel Drive
Transfer Drive
Hydra-Power Drive Cover And Linkage
Hydra-Power Drive
Over Under Hydraul-Shift Cover Filter And Pump
Over Under Hydraul-Shift Lever And Linkage (Rc, Wht)
Over Under Hydraul-Shift (Rc, Wht)
Hydra-Power And Over Under Drvie Oil Pump
Hydra-Power And Over Under Oil Cooler
Power Take-Off
Power Take-Off Clutch An Drive
Power Take-Off Valve
Hydraulic Housing And Cover
Hydraulic Pump, Filter And Lines
Hydraulic Oil Filter
Unloading Valve
Pressure Valve
Hydraulic Hand Controls
Pressure Detent Valve
Servo Valve
Float Valve
Hydraulic Internal Draft Sensitivity
Hydraulic External Draft Sensitivity
Cylinder, Hoses And Connections
Lift Cylinder
Depth Stop Cylinder - 4
Hydraulic Cooler (S N 220000 - 247870)
Pressure Lube, Hydraulic And Cooler Pump Drive (S N 247871-)
Hydraulic Oil Cooler Pump
Hydraulic Air Bleed Lines And Connections
Rear Wheel Rims
Rear Wheel Weights
Front Wheels
Lights
Lamp - Head
Lamp - Flood
Lamp - Tail
Warning Lamp
Head Lamp
Drawbar
Wide Drawbar
Extra Heavy Wide Drawbar
Three-Point Hitch
Gear Asy.
6,000 Lb. Lift Hitch (Category 3)
Clutch
Clutch Cover - 13
Rear Axle
Wheel Guards And Platforms
Wheel Guard Panels
Step
Roll Bar And Seat Belt
Front Frame Weights
Power Steering (Rc, Wht) (S N 220000 - 230210)
Hydramotor
Steering Column
Power Steering
Unit Control
Power Steering Cylinder
Power Steering Mechanism - Adjustable Front Axle
Tie Rod
Power Steering Mechanism - Wheatland And Ricefield
Power Steering Mechanism - Short Wheel Base
Front Axle - Dual Wheel
Front Axle - Adjustable Front Axle
Front Axle - Wheatland And Ricefield
Front Axle - Short Wheel Base
Power Steering And Connections - Four Wheel Drive
Power Steering Cylinder - Four Wheel Drive
Front Axle, Carrier And Supports - Four Wheel Drive
Front Axle - Four Wheel Drive
Front Axle Drive Shaft - Four Wheel Drive
Hood, Side Panels And Grille
Instrument Panel
Hourmeter
Speedometer
Tachourmeter
Tool Box
Cab - Continental
Cab (Not Illus.)
Blower
Windshield Wiper
Cab - Narrow Row
Mud Guard Kit
Heater And Connections - Continental Cab
Heater And Connections - Narrow Row Cab
Weather Break
Air Conditioner
Depth-Stop Cylinder - 3-1 2
Cab - Rops (Rc, Wht)
Cab Door And Windows - Rops
Cab Air Filter, Blower And Control Panel - Rops
Cab Roof And Miscellaneous - Rops
Cab Glass Specifications - Rops
Cab Air Conditioner - Rops
Cab Air Conditioner - Rops (Rc, Wht)
Air Conditioner Compressor And Drive Pulley
