White Tractor 1950T Parts Catalog 43309600
Brand: White
Model: White 1950T Tractor
Part Number: 43309600
Number of Pages: 258 Pages
Group A - Front Main Frame (Rc, Wht) (S N 194080 -)
Group A - Emblem, Decal Sets And Name Plate (Not Illus.)
Group B - Cylinder Head Cover And Breather (S N 194080 -)
Group B - Rocker Arms And Push Rods (S N 194080 -)
Group B - Cylinder Head And Valves (S N 194080 -)
Group B - Crankcase (S N 194080 -)
Group B - Crankshaft And Related Parts (S N 194080 -)
Group B - Camshaft (S N 194080 -)
Group B - Oil Pan, Oil Pump And Oil Filters
Group B - Manifold (S N 194080 -)
Group B - Turbocharger (S N 194080 -)
Group B - Muffler And Manifold Heat Shield (Rc, Wht)
Group B - Manifold Preheater (Rc, Wht) (S N 194080 -)
Group B - Air Cleaner (Rc, Wht) (S N 194080 - 218229)
Group B - Air Cleaner (Rc, Wht) (S N 218230 -)
Group B - Main Fuel Tank System (Rc, Wht) (S N 194080 -)
Group B - Wheel Guard Fuel Tanks (Rc, Wht) (S N 194080 -)
Group B - Wheel Guard Tanks And Main Tank (Rc, Wht)
Group B - Auxiliary Fuel Tanks - Narrow Row Cab (Rc)
Group B - Governor Controls (Rc, Wht) (S N 194080 -)
Group B - Injection Pump, Injectors And Accessory Drive
Group B - Ignition And Starter (Rc, Wht) (S N 194080 -)
Group B - Ignition Wires And Clips (Rc, Wht) (S N 194080 -)
Group B - Water Pump, Fan And Belts (Rc, Wht) (S N 194080 -)
Group B - Cooling System (Rc, Wht) (S N 194080 -)
Group B - Coolant Heater (Rc, Wht) (S N 194080 -)
Group C - Rear Frame (Rc, Wht) (S N 194080 -)
Group C - Transmission Pressure Lube System (Rc, Wht)
Group C - Transmission (Rc, Wht) (S N 194080 -)
Group C - Transmission - Four Wheel Drive (S N 194080 -)
Group C - Gear Shift (Rc, Wht) (S N 194080 -)
Group C - Brake Controls (Rc, Wht) (S N 194080 -)
Group C - Brakes (Rc, Wht) (S N 194080 -)
Group C - Differential (Rc, Wht) (S N 194080 -)
Group C - Transfer Drive - Four Wheel Drive (S N 194080 -)
Group C - Hydra-Power Drive (Rc, Wht) (S N 44200 -)
Group C - Creeper Drive (Rc, Wht) (S N 194080 -)
Group C - Over Under Hydraul-Shift (Rc, Wht)
Group D - Belt Pulley - For 540 Rpm Pto (Rc, Wht)
Group D - Belt Pulley - For 1000 Rpm Pto (Rc, Wht)
Group E - Power Take-Off (Rc, Wht) (S N 194080 -)
Group F - Hydra-Lectric-Stop And Depth-Stop Internal Valve
Group F - Hydra-Lectric-Stop And Depth-Stop Interval Valve
Group F - Remote Only, Depth-Stop External Valve Systems
Group F - Cylinder, Hoses And Connections
Group F - Cylinder, Hoses And Connections - Depth-Stop
Group F - Hydraulic Oil Cooler (Rc, Wht) (S N 194080 -)
Group H - Rear Wheels (Rc, Wht) (S N 194080 -)
Group I - Rear Wheel Rims (Rc, Wht) (S N 194080 -)
Group J - Rear Wheel Weights (Rc, Wht) (S N 194080 -)
Group L - Front Wheels (Rc) (S N 194080 -)
Group O - Lights (Rc, Wht) (S N 194080 -)
Group O - Lights - Narrow Row Cab (Rc) (S N 194080 -)
Group O - Lights - Continental Cab (Rc, Wht) (S N 194080 -)
Group P - Drawbar (Rc, Wht) (S N 194080 -)
Group P - Wide Drawbar (Rc, Wht) (S N 194080 -)
Group P - Extra Heavy Wide Drawbar (Rc, Wht) (S N 194080 -)
Group P - Three-Point Hitch (Rc, Wht) (S N 194080 -)
Group P - 6,000 Lb. Lift Hitch (Category 3) (Rc, Wht)
Group Q - Clutch (Rc, Wht) (S N 194080 -)
Group R - Rear Axles (Rc, Wht) (S N 194080 -)
Group S - Wheel Guards And Platforms (Rc, Wht) (S N 194080-)
Group S - Wheel Guard Panels (Rc, Wht) (S N 194080-)
Group S - Step (Rc, Wht) (S N 194080-)
Group T - Seat (Rc, Wht) (S N 194080-)
Group T - Roll Bar And Seat Belt (Rc, Wht) (S N 194080 -)
Group T - Front Frame Weights (Rc, Wht) (S N 194080 -)
Group U - Power Steering (Rc, Wht) (S N 194080 -)
Group U - Power Steering Mechanism - Adjustable Front Axle
Group U - Power Steering Mechanism - Wheatland (Wht)
Group U - Power Steering Mechanism - Short Wheel Base (Rc)
Group U - Front Axle - Row Crop (Rc) (S N 194080 -)
Group U - Front Axle - Adjustable Front Axle (Rc)
Group U - Front Axle - Wheatland (Wht) (S N 194080 -)
Group U - Front Axle - Short Wheel Base (Rc) (S N 194080 -)
Group U - Power Steering Connections - Four Wheel Drive
Group U - Front Axle, Carrier And Supports - Four Wheel Drive
Group W - Hood, Side Panels And Grille (Rc, Wht)
Group W - Instrument Panel (Rc, Wht) (S N 194080 -)
Group W - Instruments And Switches (Rc, Wht) (S N 194080 -)
Group W - Speedometer (Rc, Wht) (S N 194080 -)
Group W - Tachourmeter (Rc, Wht) (S N 194080 -)
Group X - Tool Box And Tools (Rc, Wht) (S N 194080 -)
Group Y - Cab - Continental (Rc, Wht) (S N 194080 -)
Group Y - Cabs - Narrow Row (Rc) (S N 194080 -)
Group Y - Heater And Connections - Continental Cab (Rc, Wht)
Group Y - Heater And Connections - Narrow Row Cab (Rc)
Group Y - Cab Plates - Continental Cab (Rc, Wht)
Group Y - Weather Break (Rc, Wht) (S N 194080 -)
Group Y - Converta Cab (Rc, Wht) (S N 194080 -)
Group Y - Air Conditioner (Rc, Wht) (S N 194080 -)
Brand: White
