White Tractor 1950 Parts Catalog 43308200
Brand: White
Model: White 1950 Tractor
Part Number: 43308200
Number of Pages: 290 Pages
Group A - Front Main Frame (Rc, Ind, Wht)
Group A - Emblem, Decal Set And Name Plate
Group B - Engine (Rc, Ind, Wht) (S N 150421 -)
Group B - Oil Filter (Rc, Ind, Wht) (S N 150421 -)
Group B - Muffler And Manifold Heat Shield (Rc, Wht, Ind)
Group B - Air Cleaner (Rc, Ind, Wht) (S N 150421 -)
Group B - Main Fuel System (Rc, Ind, Wht) (S N 150421 -)
Group B - Wheel Guard Tanks (Rc, Wht) (S N 150421 -)
Group B - Two Wheel Guard Tanks And Main Tank
Group B - Governor Controls (Rc, Ind, Wht) (S N 150421 -)
Group B - Electrical System (Rc, Ind, Wht) (S N 150421 -)
Group B - Wires And Clips (Rc, Ind, Wht) (S N 150421 -)
Group B - Fan Drive And Fan Belt (Rc, Ind, Wht)
Group B - Cooling System (Rc, Ind, Wht) (S N 150421 -)
Group B - Coolant Heater (Rc, Ind, Wht) (S N 150421 -)
Group C - Rear Main Frame (Rc, Ind, Wht) (S N 150421 -)
Group C - Transmission Pressure Lube System
Group C - Transmission (Rc, Ind, Wht) (S N 150421 -)
Group C - Transmission (Reverse-O-Torc) (Ind)
Group C - Transmission (Four Wheel Drive) (Rc, Ind, Wht)
Group C - Transmission (Four Wheel Drive With Reverse-O-Torc)
Group C - Gear Shift (Rc, Ind, Wht) (S N 150421 -)
Group C - Brake Controls (Rc, Ind, Wht) (S N 150421 -)
Group C - Brakes (Rc, Ind, Wht)
Group C - Differential (Rc, Ind, Wht)
Group C - Transfer Drive - Four Wheel Drive
Group C - Hydra-Power Drive (Rc, Ind, Wht)
Group C - Hydra-Power Drive (Rc, Ind, Wht) (S N 44200 -)
Group C - Creeper Drive (Rc, Wht)(S N 150421 - 185190)
Group C - Creeper Drive (Rc, Wht) (S N 185191 -)
Group D - Belt Pulley 540 Rpm Pto (Rc, Wht) (S N 150421 -)
Group D - Belt Pulley - 1000 Rpm Pto (Rc, Wht) (S N 150421 -)
Group E - Power Take-Off (Rc, Ind, Wht) (S N 150421 -)
Group F - Hydra-Lectric-Stop And Depth-Stop Internal Valve
Group F - Hydra-Lectric-Stop & Depth-Stop Internal Valve Sys.
Group F - Remote Only Depth-Stop External Valve System
Group F - Remote Only, Depth-Stop External Valve System
Group F - Cylinder, Hoses And Connections
Group F - Hoses And Connections, Depth-Stop External Valve
Group F - Hydraulic Oil Cooler (Rc, Ind, Wht) (S N 150421 -)
Group H - Rear Wheels (Rc, Ind, Wht)
Group I - Rear Wheel Rims (Rc, Ind, Wht)(S N 150421 -)
Group J - Rear Wheel Weights (Rc, Ind, Wht) (S N 150421 -)
Group L - Front Wheels (Rc, Ind, Wht) (S N 150421 -)
Group M - Front Wheel Rims (Rc, Ind) (S N 150421 -)
Group N - Front Wheel Weights (Rc) (S N 150421 -)
Group O - Lights (Rc, Ind, Wht) (S N 150421 -)
Group P - Drawbar (Rc, Ind, Wht)
Group P - Wide Drawbar (Rc, Ind, Wht) (S N 150421 -)
Group P - Extra Heavy Wide Drawbar (Rc, Ind, Wht)
Group P - Three-Point Hitch (Rc, Ind, Wht) (S N 150421 -)
Group P - 6,000-Lb. - Lift Hitch - Category 3
Group Q - Clutch (Rc, Ind, Wht) (S N 150421 -)
Group Q - Reverse-O-Torc Drive (Ind) (S N 150421 -)
Group Q - Reverse-O-Torc Oil Cooler (Ind) (S N 150421 -)
Group R - Rear Axles (Rc, Ind, Wht)
Group S - Wheel Guards And Platforms (Rc, Ind, Wht)
Group S - Wheel Guard Panels (Rc, Ind, Wht) (S N 150421 -)
Group S - Steps (Rc, Ind, Wht) (S N 150421 -)
Group T - Seat (Ind) (S N 150421 -)
Group T - Seat (Rc, Ind, Wht) (S N 150421 -)
Group T - Front Frame Weights (Rc, Ind, Wht) (S N 150421 -)
Group U - Manual Steering (Ind, Wht) (S N 150421 -)
Group U - Power Steering (Rc, Ind, Wht) (S N 150421 -)
Group U - Power Steering (Ind, Wht) (S N 150421 -)
Group U - Manual Steering Mechanism
Group U - Power Steering Mechanism - Adjustable Front Axle
Group U - Power Steering Mechanism - Short Wheel Base
Group U - Front Axle - Dual Wheel (Rc)
Group U - Front Axle - Adjustable (Rc)
Group U - Front Axle, Wheatland, Industrial And Ricefield
Group U - Front Axle - Short Wheel Base (Rc)
Group U - Power Steering And Connections - Four Wheel Drive
Group U - Front Axle, Carrier And Supports - Four Wheel Drive
Group U - Wheel And Axle - Hpfwd (Rc) (S N 150421 -)
Group U - Wheel Hoses - Hpfwd (Rc) (S N 150421 -)
Group U - Hydraulic Unit And Manifold - Hpfwd
Group U - Drive Shaft - Hpfwd (Rc) (S N 150421 -)
Group U - Heat Exchanger And Lines - Hpfwd
Group U - Harness And Switches - Hpfwd
Group U - Quadrant Controls - Hpfwd
Group W - Hood, Side Panel And Grille (Rc, Ind, Wht)
Group W - Instrument Panel (Rc, Ind, Wht) (S N 150421 -)
Group W - Instruments And Switches (Rc, Ind, Wht)
Group W - Speedometer (Rc, Ind, Wht) (S N 150421 -)
Group W - Tachourmeter (Rc, Ind, Wht) (S N 150421 -)
Group X - Tool Box And Tools (Rc, Ind, Wht) (S N 150421 -)
Group Y - Cab (Rc, Wht) (S N 150421 -)
Group Y - Cab - Continental (S N 150421 -)
Group Y - Cab - Continental (Rc, Ind, Wht) (S N 150421 -)
Group Y - Heater And Connections (Rc, Wht) (S N 150421 -)
Group Y - Heater And Connections - Continental Cab
Group Y - Cab Plates (S N 150421 -)
Group Y - Cab Plates - Continental Cab (S N 150421 -)
Group Y - Weather Break (S N 150421 -)
Brand: White
