White Tractor 1855 Parts Catalog 43311700
Brand: White
Model: White 1855 Tractor
Part Number: 43311700
Number of Pages: 456 Pages
Frame Main Frame (Rc, Wht) (S N 220000 -)
Cylinder Head Cover And Breather (Gas, Dsl) (S N 220000 -)
Rocker Arms And Push Rods (Gas, Dsl) (S N 220000 -)
Cylinder Head And Valves (Gas, Dsl)
Crankcase (S N 220000 - 244324) (Gas, Dsl)
Crankcase (S N 244325 -) (Gas, Dsl)
Crankcase - Front Cover (Gas, Dsl) (S N 220000 -)
Camshaft (Gas, Dsl) (S N 220000 -)
Crankshaft And Related Parts (Gas, Dsl)
Oil Pan, Pump And Filter (Gas, Dsl) (S N 220000 -)
Engine Oil Cooler (S N 220000 - 244324) (Dsl)
Oil Filter And Oil Cooler (S N 244324 -) (Dsl)
Diesel Engine Oil Filter
Oil Pump
Gas Engine Oil Filter
Manifold - Gas (S N 220000 -)
Muffler And Manifold Heat Shield - Gas (Rc, Wht)
Air Cleaner - Gas (Rc, Wht) (S N 220000 -)
Air Cleaner
Precleaner Screener
Manifold - Diesel (S N 220000 -)
Turbocharger - Diesel (Rc, Wht) (S N 220000 -)
Muffler And Manifold Heat Shield - Diesel (Rc, Wht)
Manifold Preheater - Diesel (Rc, Wht) (S N 220000 -)
Air Cleaner - Diesel (Rc, Wht) (S N 220000 -)
Main Fuel Tank - Gas (Rc, Wht) (S N 220000 -)
Main Fuel Tank Lines - Gas (Rc, Wht) (S N 220000 -)
Fuel Strainer
Wheel Guard Fuel Tanks - Gas (Rc, Wht) (S N 220000 -)
Wheel Guard Fuel Tank Lines - Gas (Rc, Wht) (S N 220000 -)
Auxiliary Fuel Tanks - Narrow Row Cab - Gas (Rc, Wht)
Auxiliary Fuel Tank Lines - Narrow Row Cab - Gas (Rc, Wht)
Governor Hand Lever - Gas (S N 220000 - 247283) (Rc, Wht)
Governor Hand Lever - Gas (S N 247284 -) (Rc, Wht)
Governor Controls - Gas (Rc, Wht)
Governor Shaft (165687as, 30-3044289)
Governor Housing (164471as, 30-3057798)
Carburetor
Carburetor (30-3078086, 30-3064492)
Main Fuel Tank - Diesel (Rc, Wht) (S N 220000 -)
Main Fuel Tank Lines - Diesel (Rc, Wht)
Diesel Fuel Filter
Wheel Guard Fuel Tanks - Diesel (Rc, Wht) (S N 220000 -)
Fender Fuel Tanks With Rops Cab (Rc, Wht)
Wheel Guard Fuel Tank Lines - Diesel (Rc, Wht) (S N 220000-)
Auxiliary Fuel Tanks - Narrow Row Cab - Diesel (Rc, Wht)
Auxiliary Fuel Tank Lines - Narrow Row Cab - Diesel (Rc,Wht)
Governor Hand Lever - Diesel (S N 220000 - 247283) (Rc, Wht)
Governor Hand Lever - Diesel (S N 247284 -) (Rc, Wht)
Governor Controls - Diesl (Rc, Wht)
Injection Pump, Injectors And Accessory Drive - Diesel
Injection Pump (30-3031608, 30-3151107)
Ignition And Starter (Rc, Wht)
Starting Motor
Distributor
Alternator (20-3000545, 30-3066967)
Water Pump, Fan And Fan Belt (Rc, Wht)
Coolant Heater (Rc, Wht)
Cooling System (Rc, Wht)
Rear Main Frame (Rc, Wht)
Transmission Pressure Lube System (Rc, Wht)
Transmission Lube Pump
Gear Shift (Rc, Wht)
Brake Controls (S N 220000 - 247283) (Rc, Wht)
Brake Valve And Lines (S N 247284 -) (Rc, Wht)
Brake Valve
Hand Brake (Rc, Wht)
Brakes (Rc, Wht)
Differential (Rc, Wht)
Transfer Drive - Four Wheel Drive (Rc, Wht)
Transfer Drive
Hydra-Power Drive Cover And Linkage (Rc, Wht)
Hydra-Power Drive (Rc, Wht)
Over Under Hydraul-Shift Cover, Filter And Pump (Rc, Wht)
Over Under Hydraul-Shift Lever And Linkage (Rc, Wht)
Over Under Hydraul-Shift (Rc, Wht)
Hydra-Power And Over Under Drive Oil Pump
Hydra-Power And Over Under Oil Cooler (Rc, Wht)
Power Take-Off (Rc, Wht)
Power Take-Off Clutch And Drive (Rc, Wht)
Power Take-Off Valve
Hydraulic Housing And Cover (Rc, Wht)
Hydraulic Pump, Filter And Lines (Rc, Wht)
Hydraulic Oil Filter
Unloading Valve
Pressure Valve
Hydraulic Hand Controls (Rc, Wht)
Pressure Detent Valve
Servo Valve
Float Valve
Hydraulic Internal Draft Sensitiviy (Rc, Wht)
Hydraulic Internal Draft Sensitivity (Rc, Wht)
Hydraulic External Draft Sensitivity (Rc, Wht)
Cylinder, Hoses And Connections (Rc, Wht)
Lift Cylinder
Depth Stop Cylinder - 4
Depth-Stop Cylinder - 3-1 2
Hydraulic Cooler (S N 220000 - 247473)
Hydraulic Oil Cooler Pump (Rc, Wht)
Hydraulic Air Bleed Lines And Connections
Rear Wheels (Rc, Wht)
Rear Wheel Rims (Rc, Wht)
Rear Wheel Weights (Rc, Wht)
Front Wheels (Rc, Wht)
Lights (Rc, Wht)
Lights - With Rops Cab (Rc, Wht)
Lamp - Head
Lamp - Flood
Lamp - Tail
Warning Lamp
Head Lamp
Drawbar (Rc, Wht)
Wide Drawbar (Rc, Wht)
Extra Heavy Wide Drawbar (Rc, Wht)
Three-Point Hitch (Rc, Wht)
Gear Assembly
6,000 Lb. Hitch (Category 3) (Rc, Wht)
Clutch (Rc, Wht)
Clutch Pedal And Linkage (S N 220000 - 247283) (Rc, Wht)
Clutch Cover - 13
Rear Axle (Rc, Wht)
Wheel Guards And Platform (Rc, Wht)
Platform (S N 247284 -) (Rc, Wht)
Wheel Guard Panels (Rc, Wht)
Step (Rc, Wht)
Seat (Rc, Wht)
Roll Bar And Seat Belt (Rc, Wht)
Front Frame Weights (Rc, Wht)
Power Steering (S N 220000 - 230893) (Rc, Wht)
Power Steering (S N 230894 -) (Rc, Wht)
Hydramotor
Power Steering (Rc, Wht)
Power Steering Cylinder
Power Steering Mechanism - Adjustable Front Axle (Rc, Wht)
Tie Rod
Power Steering Mechanism - Wheatland And Ricefield (Rc, Wht)
Power Steering Mechanism - Short Wheel Base (Rc, Wht)
Front Axle - Dual Wheel (Rc, Wht)
Front Axle - Adjustable Front Axle (Rc, Wht)
Front Axle - Wheatland And Ricefield (Rc, Wht)
Front Axle - Short Wheel Base (Rc, Wht)
Power Steering And Connections - Four Wheel Drive (Rc)
Power Steering Cylinder - Four Wheel Drive
Front Axle, Carrier And Supports - Four Wheel Drive (Rc)
Front Axle - Four Wheel Drive
Front Axle Drive Shaft - Four Wheel Drive
Hood, Side Panels And Grille (Rc, Wht)
Instrument Panel (S N 220000 - 247283) (Rc, Wht)
Instrument Panel (S N 247284) (Rc, Wht)
Hourmeter (Rc, Wht)
Speedometer (Rc, Wht)
Tachourmeter (Rc, Wht)
Tool Box (Rc, Wht)
Cab - Continental (Rc, Wht)
Cab (Not Illus.)
Blower
Windshield Wiper
Cab - Narrow Row (Rc, Wht)
Cab - Narrow Row (Not Illus.)
Mud Guard Kit
Heater And Connections - Continental Cab (Rc, Wht)
Heater And Connections - Narrow Row Cab (Rc, Wht)
Weather Break (Rc, Wht)
Air Conditioner (Rc, Wht)
Air Conditioner
Cab - Rops (S N 232600 -) (Rc,Wht)
Cab Door And Windows - Rops
Cab Air Filter, Blower And Control Panel - Rops
Cab Roof And Miscellaneous - Rops
Cab Glass Specifications - Rops
Cab Air Conditioner - Rops
Unit Control
Steering Column
Cab Air Conditioner - Rops (Rc, Wht)
Clutch Pedal And Linkage (S N 247284 -) (Rc, Wht)
Air Conditioner Compressor And Drive Pulley
Pressure Lube, Hydraulic And Cooler Pump Drive (S N 247474-)
Cab Heater - Rops (Rc, Wht)
Brake Pedals And Linkage (S N 247284 -) (Rc, Wht)
Emblem, Decal Sets And Name Plate (Rc, Wht) (S N 220000 -)
