White Tractor 1465 1470 Parts Catalog 43316600
Brand: White
Model:
White 1465 Tractor
White 1470 Tractor
Part Number: 43316600
Number of Pages: 231 Pages
Engine (S N 000001 - )
Crankcase & Cylinder Head (S N 000001 - )
Crankshaft And Flywheel (S N 000001 - )
Connecting Rods And Pistons (S N 000001 - )
Vibration Damper (S N 000001 - )
Oil Pan And Crankcase Covers (S N 000001 - )
Camshaft, Rocker Arms And Valves (S N 000001 - )
Camshaft Drive (S N 000001 - )
Oil Filter
Oil Pump, Filter And Level Gauge (S N 000001 - )
Air Cleaner And Intake Manifold (S N 000001 - )
Air Cleaner (S N 000001 - )
Exhaust Manifold (S N 000001 - )
Muffler (S N 000001 - )
Fuel Tank And Lines (S N 000001 -)
Fuel Injection System (S N 000001 - )
Fuel Injection Pump (S N 31-2901511 - 31-2900856)
Fuel Injection Pump Governor
Primer Pump
Nozzle Holder
Injection Pump Drive (S N 000001 - )
Accelerator Control Linkage (S N 000001 - )
Current Generating System (S N 000001 - )
Engine Starting Equipment (S N 000001 - )
Starting Motor
Alternator Assembly
Battery Holder (S N 000001 - )
Lighting System (S N 000001 - )
Head Lamp
Warning Lamp
Tail Lamp
Fan (S N 000001 - )
Water Pump And Lines (S N 000001 - )
Radiator (S N 000001 - )
Coolant Heater (000001 - )
Rear Main Frame (S N 000001 - )
Clutch Housing (S N 000001 - )
Transmission (S N 000001 - )
Speed Reducer Gears
Propeller Shaft (S N 000001 - )
Gear Shift - Outer (S N 000001 - )
Gear Shift - Inner (S N 000001 - )
Reduction Gear Control (S N 000001 - )
Speed Reducer Control (S N 000001 - )
Brakes And Controls (S N 000001 - )
Differential (S N 000001 - )
Differential Lock (S N 000001 - )
Hand Brake (S N 000001 - )
Transfer Drive Engagement Controls - Four Wheel Drive
Transfer Drive Case - Four Wheel Drive (S N 000001 - )
Transfer Drive Idler Unit Gears - Four Wheel Drive
Transfer Drive Shaft - Four Wheel Drive (S N 000001 - )
Belt Pulley (S N 000001 - )
Power Take-Off And Pulley Control (S N 000001 - )
Power Take-Off (S N 000001 - )
Hydraulic Lift System (S N 000001 - )
Hydraulic Lift
Hydraulic Additional Power Outlet Unit (S N 000001 - )
Hydraulic Lift Hoses And Connections (S N 000001 - )
Depth Stop Cylinder - 3-1 2 Inch
Rear Wheels And Weights (S N 000001 - )
Front Wheels (S N 000001 - )
Drawbar (S N 000001 - )
Three-Point Hitch (S N 000001 - )
Leveling Gear
Clutch Release Control (S N 000001 - )
Clutch
Rear Axle Carrier (S N 000001 - )
Axle Shafts (S N 000001 - )
Final Drive Gears (S N 000001 - )
Wheel Guards And Steps (S N 000001 - )
Seat (S N 000001 - )
Front Frame Weights (S N 000001 - )
Steering Gear (S N 000001 - )
Steering Linkage (S N 000001 - )
Steering Rod
Tie Rod
Power Steering Linkage - Four Wheel Drive (S N 000001 - )
Tie Rod - Four Wheel Drive
Steering Pump, Reservoir, And Lines (S N 000001 - )
Power Steering Pump
Power Drive - Power Steering (S N 000001 - )
Steering Cylinder
Power Steering Cylinder
Power Steering Reservoir
Front Axle (S N 000001 - )
Front Axle And Axle Shafts - Four Wheel Drive
Front Axle Shaft - Four Wheel Drive (S N 000001 - )
Front Axle Knuckle - Four Wheel Drive (S N 000001 - )
Front Axle Planetary Drive Case - Four Wheel Drive
Front Axle Differential Gear - Four Wheel Drive
Hood And Instrument Panel (S N 000001 - )
Radiator Grille And Inserts (S N 000001 - )
Instruments (S N 000001 - )
Multimeter Drive (S N 000001 - )
Tool Box (S N 000001 - )
